    Duet 2 Ethernet and SBC
    Beta Firmware
    29
    302
    32.6k
    • smoki3undefined
      smoki3
      ../src/Libraries/Fatfs/diskio.c:51:10: fatal error: ctrl_access.h: No such file or directory
         51 | #include "ctrl_access.h"
      compilation terminated.
      make: *** [src/Libraries/Fatfs/diskio.o] Error 1
      make: *** Waiting for unfinished jobs....
      I get this when I try to build DuetIAP. Building in mac.
      A Former User? wilrikerundefined 2 Replies Last reply Reply Quote 0
        A Former User @smoki3
        @smoki3 said in Duet 2 Ethernet and SBC:
        i got the same, but as long as you can use Bossa to do any programming after the inital flashing you don't need the IAP binary
        • smoki3undefined
          smoki3
          So tested my PCB today. Its working fine. 🙂 So I just miss the IAP that I can flash the duet trough DWC.
          • smoki3undefined
            smoki3
            With SBC there is no SD card needed in the duet right?
              it explicitly needs to not have a SD card with a config.g on it. (at least for now (RRF3.2), been some discussion on changing that)
              smoki3undefined 1 Reply Last reply Reply Quote 0
              • smoki3undefined
                smoki3 @A Former User
                @bearer said in Duet 2 Ethernet and SBC:
                I got it 😄 I removed the SD Card now my config is working
                  A Former User @wilriker
                  @wilriker said in Duet 2 Ethernet and SBC:
                  @Dougal1957 DSF is absolutely the same. It does neither know nor care if it's a D3 or a D2 on the other end.
                  not 100% accurate .. if one were to suffer from pendanticitis(?) .. upon first connection it says "Welcome to your new Duet 3" .
                  ...good thing i don't 😎
                  • smoki3undefined
                    @bearer Have you found a solution building DuetIAP?
                    maybe @wilriker can help us?
                      sort of; wait for 3.2 release candidates as I don't really need it.
                      I just send M997 P"ERASE" M999 P"ERASE" and upload firmware with bossac from the pi.
                      • wilrikerundefined
                        wilriker @A Former User
                        I just send M997 P"ERASE" and upload firmware with bossac from the pi.
                        It's actually M999 P"ERASE". 😉
                        Anyway, I remember I had that compiler error as well. I just don't remember what I did to fix that. I can most likely only check on Monday in more detail. Meanwhile I try to upload my IAP binary to Dropbox and then share here.
                        EDIT: find the IAP here: https://www.dropbox.com/s/rkcb3chqk878nkm/Duet2_SBCiap_2SBC.bin?dl=0
                        Manuel
                        My Tool Collection
                          'aint that the truth, I should stick to copy/paste. luckily there is always a pedantic around:)
                          • wilrikerundefined
                            wilriker @smoki3
                            That's a victim of recent refactorings. Currently looking into how to fix it best.
                            Manuel
                            My Tool Collection
                            • smoki3undefined
                              smoki3
                              @dc42 @wilriker
                              After some testing with the sbc configuration, I have problems with homing my tool changer.
                              I have configured 3 additional axes. However I do a home all, all axes getting homes besides the last "W" axes and the printer hangs forever. After some time the printer then resets itself automatically.
                              If I home all axes separately it is working fine so far. Also the whole configuration what working fine before.
                              I also made a short video:
                              https://photos.app.goo.gl/1YnQmdPAnkXtDG2X8
                              Is there a possibility to grab logs why it is crashing?
                              UPDATE:
                              [info] Starting macro file /sys/homew.g on channel Aux
                              [warn] Lost connection to Duet (Timeout while waiting for transfer ready pin)
                              [warn] Bad header checksum (expected 0x0000, got 0xb5c3)
                              [warn] Note: RepRapFirmware didn't receive valid data either (code 0x00000005)
                              [warn] Restarting transfer because the number of maximum retries has been exceeded
                              [warn] Bad header checksum (expected 0x0000, got 0x7532)
                              [warn] Bad header checksum (expected 0x0000, got 0x606a)
                              [warn] Bad header checksum (expected 0x0000, got 0x006d)
                              [warn] Bad header checksum (expected 0x0000, got 0xcacc)
                              [warn] Bad header checksum (expected 0x0000, got 0x6ac5)
                              [warn] Bad header checksum (expected 0x0000, got 0xa075)
                              [warn] Bad header checksum (expected 0x0000, got 0x606c)
                              [warn] Bad header checksum (expected 0x0000, got 0xaacb)
                              [warn] Bad header checksum (expected 0x0000, got 0xc074)
                              [warn] Note: RepRapFirmware didn't receive valid data either (code 0x0002005f)
                              [info] Connection to Duet established
                              [info] Aborted macro file /sys/homew.g
                              [warn] Aux: ==> Cancelling unfinished starting code: M98 P"/sys/homew.g"
                              [info] Aborted macro file homeall.g
                              [warn] Controller has been reset
                              [info] Starting macro file config.g on channel Trigger
                              [error] Failed to merge JSON: {"key":"inputs","flags":"d99vn","result":[{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50.0,"inMacro":false,"lineNumber":0,"name":"HTTP","stackDepth":0,"state":"idle","volumetric":false},{"axesRelative":false,"compatibility":"Marlin","distanceUnit":"mm","drivesRelative":false,"feedRate":50.0,"inMacro":false,"lineNumber":0,"name":"Telnet","stackDepth":0,"state":"idle","volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50.0,"inMacro":false,"lineNumber":0,"name":"File","stackDepth":0,"state":"idle","volumetric":false},{"axesRelative":false,"compatibility":"Marlin","distanceUnit":"mm","drivesRelative":false,"feedRate":50.0,"inMacro":false,"lineNumber":0,"name":"USBchan","stackDepth":0,"state":"idle","volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50.0,"inMacro":false,"lineNumber":0,"name":"Aux","stackDepth":0,"state":"idle","volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":true,"feedRate":50.0,"inMacro":true,"lineNumber":51,"name":"Trigger","stackDepth":1,"state":"idle","volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50.0,"inMacro":false,"lineNumber":0,"name":"Queue","stackDepth":0,"state":"idle","volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50.0,"inMacro":false,"lineNumber":0,"name":"LCD","stackDepth":0,"state":"idle","volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50.0,"inMacro":false,"lineNumber":0,"name":"SBC","stackDepth":0,"state":"idle","volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50.0,"inMacro":false,"lineNumber":0,"name":"Daemon","stackDepth":0,"state":"idle","volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50.0,"inMacro":false,"lineNumber":0,"name":"Aux2","stackDepth":0,"state":"idle","volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50.0,"inMacro":false,"lineNumber":0,"name":"Autopause","stackDepth":0,"state":"idle","volumetric":false}]}
                                 System.Text.Json.JsonException: Failed to deserialize property [InputChannel].Name (type CodeChannel) from JSON "USBchan"
                               ---> System.Text.Json.JsonException: The JSON value could not be converted to DuetAPI.CodeChannel. Path: $ | LineNumber: 0 | BytePositionInLine: 9.
                                 at System.Text.Json.ThrowHelper.ThrowJsonException()
                                 at System.Text.Json.Serialization.Converters.JsonConverterEnum`1.Read(Utf8JsonReader& reader, Type typeToConvert, JsonSerializerOptions options)
                                 at System.Text.Json.JsonPropertyInfoNotNullable`4.OnRead(ReadStack& state, Utf8JsonReader& reader)
                                 at System.Text.Json.JsonPropertyInfo.Read(JsonTokenType tokenType, ReadStack& state, Utf8JsonReader& reader)
                                 at System.Text.Json.JsonSerializer.ReadCore(JsonSerializerOptions options, Utf8JsonReader& reader, ReadStack& readStack)
                                 at System.Text.Json.JsonSerializer.ReadCore(Type returnType, JsonSerializerOptions options, Utf8JsonReader& reader)
                                 at System.Text.Json.JsonSerializer.Deserialize(String json, Type returnType, JsonSerializerOptions options)
                                 at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 321
                                 --- End of inner exception stack trace ---
                                 at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 336
                                 at DuetAPI.Machine.ModelCollectionHelper.UpdateFromJson(IList list, Type itemType, JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelCollection.cs:line 243
                                 at DuetAPI.Machine.MachineModel.UpdateFromFirmwareModel(String key, JsonElement jsonElement) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetAPI/Machine/MachineModel.cs:line 162
                                 at DuetControlServer.Model.Updater.Run() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Model/Updater.cs:line 197
                              • wilrikerundefined
                                wilriker
                                So building IAP is fixed on dev-wilriker branch in DuetIAP repo.
                                @smoki3 First of all you can ignore the error at the end of your log excerpt. That will be fixed in the next DSF version and has nothing to do with resets. The Bad checksum statements on the other hand really are the cause of the reboot.
                                Can you please post again which resistors you use on which line and also both your DCS config.json as well as (if you use an actual Raspberry Pi) it's /boot/config.txt.
                                Manuel
                                My Tool Collection
                                • smoki3undefined
                                  smoki3 @wilriker
                                  @wilriker
                                  I use 360 Ohms in MISO MOSI and SPCK. No additional resistors on NPSC0 and EDR because the duet 2 already have 2.2kOhms on board.
                                  I am using a RPI 3:
                                  Boot config:
                                    GNU nano 3.2                    /boot/config.txt
                                  # For more options and information see
                                  # http://rpf.io/configtxt
                                  # Some settings may impact device functionality. See link above for details
                                  # uncomment if you get no picture on HDMI for a default "safe" mode
                                  #hdmi_safe=1
                                  # uncomment this if your display has a black border of unused pixels visible
                                  # and your display can output without overscan
                                  #disable_overscan=1
                                  # uncomment the following to adjust overscan. Use positive numbers if console
                                  # goes off screen, and negative if there is too much border
                                  #overscan_left=16
                                  #overscan_right=16
                                  #overscan_top=16
                                  #overscan_bottom=16
                                  # uncomment to force a console size. By default it will be display's size minus
                                  # overscan.
                                  #framebuffer_width=1280
                                  #framebuffer_height=720
                                  # uncomment if hdmi display is not detected and composite is being output
                                  #hdmi_force_hotplug=1
                                  # uncomment to force a specific HDMI mode (this will force VGA)
                                  #hdmi_group=1
                                  #hdmi_mode=1
                                  # uncomment to force a HDMI mode rather than DVI. This can make audio work in
                                  # DMT (computer monitor) modes
                                  #hdmi_drive=2
                                  # uncomment to increase signal to HDMI, if you have interference, blanking, or
                                  # no display
                                  #config_hdmi_boost=4
                                  # uncomment for composite PAL
                                  #sdtv_mode=2
                                  #uncomment to overclock the arm. 700 MHz is the default.
                                  #arm_freq=800
                                  # Uncomment some or all of these to enable the optional hardware interfaces
                                  #dtparam=i2c_arm=on
                                  #dtparam=i2s=on
                                  dtparam=spi=on
                                  # Uncomment this to enable infrared communication.
                                  #dtoverlay=gpio-ir,gpio_pin=17
                                  #dtoverlay=gpio-ir-tx,gpio_pin=18
                                  # Additional overlays and parameters are documented /boot/overlays/README
                                  # Enable audio (loads snd_bcm2835)
                                  dtparam=audio=on
                                  [pi4]
                                  # Enable DRM VC4 V3D driver on top of the dispmanx display stack
                                  dtoverlay=vc4-fkms-v3d
                                  max_framebuffers=2
                                  [all]
                                  #dtoverlay=vc4-fkms-v3d
                                  /opt/dsf/conf/config.json:
                                    "LogLevel": "info",
                                    "SocketDirectory": "/var/run/dsf",
                                    "SocketFile": "dcs.sock",
                                    "Backlog": 4,
                                    "SocketPollInterval": 2000,
                                    "BaseDirectory": "/opt/dsf/sd",
                                    "NoTerminateOnReset": false,
                                    "HostUpdateInterval": 4000,
                                    "MaxMessageAge": 60,
                                    "SpiDevice": "/dev/spidev0.0",
                                    "SpiFrequency": 8000000,
                                    "SpiTransferTimeout": 500,
                                    "MaxSpiRetries": 3,
                                    "SpiPollDelay": 25,
                                    "GpioChipDevice": "/dev/gpiochip0",
                                    "TransferReadyPin": 25,
                                    "BufferedPrintCodes": 32,
                                    "BufferedMacroCodes": 16,
                                    "MaxBufferSpacePerChannel": 1536,
                                    "ModelUpdateInterval": 250,
                                    "MaxMachineModelLockTime": -1,
                                    "FileBufferSize": 8192,
                                    "FileInfoReadLimitHeader": 12288,
                                    "FileInfoReadLimitFooter": 262144,
                                    "MaxLayerHeight": 0.9,
                                    "LayerHeightFilters": [
                                        "Pattern": "^\\s*layer_height\\D+(?<mm>(\\d+\\.?\\d*))",
                                        "Options": 17
                                        "Pattern": "Layer height\\D+(?<mm>(\\d+\\.?\\d*))",
                                        "Options": 17
                                        "Pattern": "layerHeight\\D+(?<mm>(\\d+\\.?\\d*))",
                                        "Options": 17
                                        "Pattern": "layer_thickness_mm\\D+(?<mm>(\\d+\\.?\\d*))",
                                        "Options": 17
                                        "Pattern": "layerThickness\\D+(?<mm>(\\d+\\.?\\d*))",
                                        "Options": 17
                                    "FilamentFilters": [
                                        "Pattern": "filament used\\D+(((?<mm>\\d+\\.?\\d*)mm)(\\D+)?)+",
                                        "Options": 17
                                        "Pattern": "filament used\\D+(((?<m>\\d+\\.?\\d*)m([^m]|$))(\\D+)?)+",
                                        "Options": 17
                                        "Pattern": "filament length\\D+(((?<mm>\\d+\\.?\\d*)\\s*mm)(\\D+)?)+",
                                        "Options": 17
                                        "Pattern": "filament used \\[mm\\]\\D+((?<mm>\\d+\\.?\\d*)(\\D+)?)+",
                                        "Options": 17
                                        "Pattern": "material\\#\\d+\\D+(?<mm>\\d+\\.?\\d*)",
                                        "Options": 17
                                        "Pattern": "Filament used per extruder:\\r\\n;\\s*(?<name>.+)\\s+=\\s*(?<mm>[0-9.]+)",
                                        "Options": 17
                                    "GeneratedByFilters": [
                                        "Pattern": "generated by\\s+(.+)",
                                        "Options": 17
                                        "Pattern": "Sliced by\\s+(.+)",
                                        "Options": 17
                                        "Pattern": "(KISSlicer.*)",
                                        "Options": 17
                                        "Pattern": "Sliced at:\\s*(.+)",
                                        "Options": 17
                                        "Pattern": "Generated with\\s*(.+)",
                                        "Options": 17
                                    "PrintTimeFilters": [
                                        "Pattern": "estimated printing time .*= ((?<h>(\\d+))h\\s*)?((?<m>(\\d+))m\\s*)?((?<s>(\\d+))s)?",
                                        "Options": 17
                                        "Pattern": "TIME:(?<s>(\\d+\\.?\\d*))",
                                        "Options": 17
                                        "Pattern": "Build time: ((?<h>\\d+) hour(s)?\\s*)?((?<m>\\d+) minute(s)?\\s*)?((?<s>(\\d+) second(s)?))?",
                                        "Options": 17
                                        "Pattern": "Estimated Build Time:\\s+((?<h>(\\d+\\.?\\d*)) hour(s)?\\s*)?((?<m>(\\d+\\.?\\d*)) minute(s)?\\s*)?((?<s>(\\d+\\.?\\d*)) second(s)?)?",
                                        "Options": 17
                                    "SimulatedTimeFilters": [
                                        "Pattern": "Simulated print time\\D+(?<s>(\\d+\\.?\\d*))",
                                        "Options": 17
                                  Where do I find the config jsons ?
                                    in /opt/dsf/conf/config.json
                                    • smoki3undefined
                                      @bearer but the have to be two as far I got it right
                                      • wilrikerundefined
                                        wilriker @smoki3
                                        @smoki3 The second file http.json is for the DWS (Duet Web Server) not relevant for the problem here.
                                        This is a shot in the dark but please try adding
                                        # Fix core frequency to have constant SPI clock speed
                                        core_freq=250
                                        core_freq_min=250
                                        to your /boot/config.txt and reboot the RPi. It might be that Duet 2 does not like RPi's default SPI frequency shenanigans (neither do I 😂 )
                                        Manuel
                                        My Tool Collection
                                        • smoki3undefined
                                          smoki3 @wilriker
                                          core_freq=250
                                          core_freq_min=250
                                          So this doesn't help. Same behaviour as before
                                          It wired because it only happens while homing.
                                          • smoki3undefined
                                            smoki3
                                            If I try to flash the firmware over DWC I also get checksum error
                                            ed
                                            [warn] Bad header checksum (expected 0x40cc, got 0xe30e)
                                            [warn] Note: RepRapFirmware didn't receive valid data either (code 0x00000004)
                                            [warn] Bad header checksum (expected 0xc340, got 0xa71d)
                                            [warn] Bad header checksum (expected 0x40cc, got 0xcdbd)
                                            [warn] Bad header checksum (expected 0x0040, got 0x5620)
                                            [warn] Bad header checksum (expected 0x0000, got 0x4260)
                                            [info] Flashing RepRapFirmware
                                            [info] Verifying checksum
                                            [error] Firmware checksum verification failed
                                            [error] Could not flash the firmware binary after 3 attempts. Please install it manually via bossac.
                                            [warn] Bad header checksum (expected 0x80ac, got 0xbe3b)
                                            [info] Application has shut down
