Trying to figure out what is giving the Bad Command error
M104 S215 T0 ; start preheating hotend
I don't think M104 takes a T parameter, but I don't think it would complain about it...
Bed is above here is home:
; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v2.1.8 on Tue May 26 2020 00:51:15 GMT-0700 (Pacific Daylight Time)
G91 ; relative positioning
G1 H1 X-240 Y-240 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F6000 ; go back a few mm
G1 H1 X-240 Y-240 F360 ; move slowly to X and Y axis endstops once more (second pass)
G90 ; absolute positioning
G1 X117 Y117 F6000 ; go to first bed probe point and home Z
G29 S1; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G90 ; absolute positioning -
I meant the actual file so we can check for bogus characters.
@Phaedrux said in Trying to figure out what is giving the Bad Command error:
Were you able to test this one?
Do you get the Bad Command error just once, or multiple times during the print? If it's multiple times then we probably need to see the whole file.
@Dragon said in Trying to figure out what is giving the Bad Command error:
Here:
It doesn't seem to cause any problems other than driving me nuts not knowing what's causing it.
@dc42 There's the whole file.
HxD revealed that yout GCode file has some non-printing characters in it at the start of what appears to be a blank line when viewed in a standard text editor. It's the line after "M109 S205 T0 ; heat to Cura Hotend". Possibly this was in your slicer start script?
PS - there are some more earlier in the file, the EF BB BF sequence. Neither of them is a valid UTF-8 character sequence.
Are you using the Cura plugin to upload the gcode file directly to the printer or are you uploading via the DWC?
What version of DWC are you using?
OK, Thanks! I believe that was it. It would only pop up once when starting but didn't affect the print.
Thanks everyone for the help!
Cheers.
