    Unsymmetrical prints and Delta printer calibration
    • sylarundefined
      sylar
      Hi!
      I have a problem with my delta printer, It will not print square/round as it should since it distorts all the prints.
      I have a duet 3D board on a Kossel printer with a IR Z-probe.
      Fist when I put it together i just ran the G32 command twice and then M500 to save everything to config override to later move the parameters to the config file, This didnt work good at all, so I manually measured in all endstops as good as I could so they had the same distance to the bed and it improved the prints marginally.
      Then I tried running mesh compensation and using G29 S1 in my Gcodes for printing and it improved to besing usable but I still get +0,08mm in X axing and +0,44mm in Y axis.
      Is there any way to easily calibrate the delta printer manually with the duet board to check if it is the Z-axis probe that is the fault ? Just as a sanity check
      Thanks!
        Here is your delta calibration bible
        https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareDeltaPrinter
        https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer
        • sylarundefined
          sylar
          I have already read that many times, it goes into the automatic delta calibration but not the manual delta calibration
          • sylarundefined
            sylar
            Hi!
            After a lot of tinkering and looking at the config file I noticed that my duet board changes the tower correction in M665, When i change X,Y and Z back to zero I get pretty symmetrical prints but the head does not move parallel to the bed anymore.
            Is it possible to make G32 skip the tower position corrections alltogether ?
            I have measured the tower positions with a caliper and they are almost perfect, all towers and rails are within 0,5mm the intire 550mm above the bed.
            Thanks
              @sylar said in Unsymmetrical prints and Delta printer calibration:
              4 - factor maybe?
              https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer#Section_Setting_up_the_bed_g_file
              Not really my forte.
