    Duet 2 Ethernet and SBC
    Beta Firmware
    29
    302
    34.4k
    • smoki3undefined
      smoki3 @dc42
      @dc42 the standard config 8 MHz
      • wilrikerundefined
        wilriker @smoki3
        @smoki3 Please try lowering it incrementally by dividing by two, i.e. try 4MHz, then 2MHz and so on until you either get to somewhere around 100kHz or find a working speed
        I will try to reproduce your setup next week. Just to be sure: did you power the RPi from a buck-converter off of the Duet or did you power it separately?
        Also if you only tried one of these options so far please try the other.
        I also use loose wires of around 150mm length with Dupont crimps on the ends and several JST connector pairs in between to insert/remove resistors.
        Manuel
        My Tool Collection
        smoki3undefined 1 Reply Last reply Reply Quote 0
        • smoki3undefined
          smoki3 @wilriker
          @wilriker I tried a buck converter and a USB power supply - results in the same behavior.
          As soon I disconnect the power from the duet and just plug in a USB cable it works with out any issues.
          Lowering the speed doesn't help. Tried it down to 1MHz.
          Actually I also use Dupont connectors with a cable length about 8cm.
          • smoki3undefined
            smoki3
            I now tried to lower the speed down toi 100kHz. But this also doesn't help.
            Its really as I said, as soon I plug in VIN to the Duet the SPI Bus is broken
            • smoki3undefined
              smoki3
              Is there a reason why on my duet2 ethernet capacity C99 is not equipped? Is a capacity in the 5V buck converter.
              I looked at the schematic normally there should be a 250uF capacity. Could this be a reason?
                A Former User
                which revision is the board?
                • wilrikerundefined
                  wilriker @smoki3
                  @smoki3 On my 1.03 board C99 is populated. My meter refused to measure the capacitance but it's certainly higher than "none". 😁
                  @T3P3Tony might answer this question better if that would pose a problem (I'm primarily a software guy 😂 ).
                  Manuel
                  My Tool Collection
                  • smoki3undefined
                    smoki3 @A Former User
                    @bearer Its a 1.04c
                    A Former User? 2 Replies Last reply Reply Quote 0
                      A Former User @smoki3
                      @smoki3 said in Duet 2 Ethernet and SBC:
                      1.04c
                      iirc its normal then, it was fitted to 1.04, 1.04a and 1.04b but not 1.04c.
                      also given the cpu and wifi runs off 3.3v with its own smoothing cap i'm not sure it matters, but I can try it next week if I manage to throw together a printed part with pogo pins for the wifi (edit: printed part is modelled for P50 + R50 pins, may need to drill out holes)
                        @smoki3 seems I've missplaced or run out of pogo pins, and with logistis being what it is I doubt I'll test it any time soon.
                        maybe you could try soldering a regular radial through hole capacitor to the pads and see if it helps? (or see if Tony has anything to add)
                        • smoki3undefined
                          @bearer I don't have capacitor by hand
                          • wilrikerundefined
                            wilriker @smoki3
                            @smoki3 First of all I can confirm that with external PSU I see the same behavior. I need to check the cause of that next.
                            Manuel
                            My Tool Collection
                              A Former User @wilriker
                              @wilriker said in Duet 2 Ethernet and SBC:
                              with external PSU
                              as in external 5v?
                              • wilrikerundefined
                                wilriker @A Former User
                                @bearer As in external 24V going to VIN of the board.
                                Manuel
                                My Tool Collection
                                • wilrikerundefined
                                  wilriker
                                  So what I can see is that it does not have anything to do with the internal 5V regulator. If I connect the Duet via USB to the RPi and remove the jumper for internal 5V, i.e. I_5V_EN (completely or put it on E_5V_EN - does not matter) the same problem occurs. So VIN is somehow messing with SPI as soon as it get's to fast transfers as it seems. Still checking.
                                  Manuel
                                  My Tool Collection
                                  smoki3undefined 1 Reply Last reply Reply Quote 1
                                    A Former User
                                    Hm, will try to repeat test with 24v and get the scope out, was under the impression I had used Vin but could be organic bitrot..
                                    • smoki3undefined
                                      smoki3 @wilriker
                                      @wilriker I also tried to disable the internal 5V converter by removing the the jumper. But I also does not help
                                      • smoki3undefined
                                        smoki3
                                        Is the ethernet module also working over SPI?
                                        • wilrikerundefined
                                          wilriker @smoki3
                                          Yes, it does.
                                          Manuel
                                          My Tool Collection
                                          • smoki3undefined
                                            smoki3 @wilriker
                                            @wilriker Then its even more wired that it is working with the ethernet module and not with a raspberry
