Duet 2 Wifi - Wifi not connectin but router lists the device
Hello from Germany,
I have a Vodafone Cable Router and when i setup the duet 2 wifi. The following error occurs.
But when i login to the router i find the device as conncted device. Shown in the picture.Any ideas whats going on?
M587 S"19092" P"testTest91"
ok<LF>
m587
Remembered networks:<LF>19092 IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0<LF>ok<LF>
m552
WiFi module is idle<LF>ok<LF>
m552 s1
ok<LF>
m552
WiFi module is changing mode<LF>ok<LF>
m540
MAC: 24:62:ab:15:71:e1<LF>ok<LF>WiFi reported error: Timed out while trying to connect to 19092<LF>WiFi module is idle<LF>WiFi module is idle<LF>WiFi reported error: no known networks found<LF>WiFi module is idle<LF>WiFi reported error: network scan failed<LF>WiFi module is idle<LF>WiFi reported error: network scan failed<LF>WiFi module is idle<LF>WiFi reported error: network scan failed<LF>WiFi module is idle<LF>WiFi reported error: network scan failed<LF>WiFi module is idle<LF>WiFi reported error: network scan failed<LF>WiFi module is idle<LF>WiFi reported error: network scan failed<LF>WiFi module is idle<LF>WiFi reported error: network scan failed<LF>WiFi module is idle<LF>WiFi reported error: network scan failed<LF>WiFi module is idle<LF>WiFi reported error: network scan failed<LF>WiFi module is idle<LF>WiFi reported error: network scan failed<LF>WiFi module is idle<LF>WiFi reported error: network scan failed<LF>WiFi module is idle<LF>WiFi reported error: network scan failed<LF>WiFi module is idle<LF>WiFi reported error: network scan failed<LF>WiFi module is idle<LF>WiFi reported[Warning: Maximal number of bytes per line exceeded! Check the EOL (end-of-line) settings or increase the limit in the advanced terminal settings.] -
@tifrei said in Duet 2 Wifi - Wifi not connectin but router lists the device:
please check your terminal settings to set the line ending to LF (i believe this guide says how to do it in YAT)
Others have experienced comatability issues with Vodafone routers. After having fixed your terminal, please power up the board without the SD card and run
M111 P14 S1
to enable debug for wifi, and then runM552 S1
and share the output after a while.
(feel free to put```
on a line over and under the text when you post it, helps with formatting) -
Hi bearer!
I followed your instructions!
here is the output:
M111 P14 S1 Debugging enabled for modules: WiFi(14) Debugging disabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) Display(15) LinuxInterface(16) M552 S1 WiFi: WiFi: ets Jan 8 2013,rst cause:2, boot mode:(3,7) WiFi: WiFi: load 0x4010f000, len 1384, room 16 ok WiFi: tail 8 WiFi: chksum 0x2d WiFi: csum 0x2d WiFi: v3fff168c WiFi: ~ld WiFi module started WiFi: mode : sta(24:62:ab:15:71:e1) WiFi: add if0 WiFi: wifi evt: 8 WiFi: scandone WiFi: ../src/SocketServer.cpp(353): found network 19092 WiFi: ../src/SocketServer.cpp(353): found network Verleihnix WiFi: ../src/SocketServer.cpp(353): found network dieter-powerline WiFi: ../src/SocketServer.cpp(353): found network Muckinet WiFi: ../src/SocketServer.cpp(353): found network Dieter Gastzugang WiFi: ../src/SocketServer.cpp(353): found network Vodafone Hotspot WiFi: sleep enable,type: 2 WiFi: wifi evt: 2 WiFi: scandone WiFi: state: 0 -> 2 (b0) WiFi: state: 2 -> 3 (0) WiFi: state: 3 -> 5 (10) WiFi: add 0 WiFi: aid 1 WiFi: cnt WiFi: WiFi: connected with 19092, channel 1 WiFi: dhcp client start... WiFi: wifi evt: 0 WiFi: pm open,type:2 0 WiFi reported error: Timed out while trying to connect to 19092 WiFi module is idle WiFi: state: 5 -> 0 (0) WiFi: rm 0 WiFi: pm close 7 WiFi: del if0 WiFi: usl WiFi: mode : null WiFi: wifi evt: 1 WiFi: STA disconnect: 8 WiFi: wifi evt: 8 WiFi: mode : sta(24:62:ab:15:71:e1) WiFi: add if0 WiFi: wifi evt: 8 WiFi: scandone WiFi: ../src/SocketServer.cpp(353): found network Verleihnix WiFi: ../src/SocketServer.cpp(353): found network Muckinet WiFi: ../src/SocketServer.cpp(353): found network 19092 WiFi: ../src/SocketServer.cpp(353): found network Vodafone Hotspot WiFi: sleep enable,type: 2 WiFi: scandone WiFi: state: 0 -> 2 (b0) WiFi: state: 2 -> 3 (0) WiFi: state: 3 -> 5 (10) WiFi: add 0 WiFi: aid 1 WiFi: cnt WiFi: WiFi: connected with 19092, channel 1 WiFi: dhcp client start... WiFi: wifi evt: 0 WiFi: pm open,type:2 0 WiFi reported error: Timed out while trying to connect to 19092 WiFi module is idle WiFi: state: 5 -> 0 (0) WiFi: rm 0 WiFi: pm close 7 WiFi: del if0 WiFi: usl WiFi: mode : null WiFi: wifi evt: 1 WiFi: STA disconnect: 8 WiFi: wifi evt: 8 WiFi: mode : sta(24:62:ab:15:71:e1) WiFi: add if0 WiFi: wifi evt: 8 WiFi: scandone WiFi: ../src/SocketServer.cpp(353): found network Muckinet WiFi: ../src/SocketServer.cpp(353): found network Verleihnix WiFi: ../src/SocketServer.cpp(353): found network 19092 WiFi: ../src/SocketServer.cpp(353): found network UPC3959933 WiFi: ../src/SocketServer.cpp(353): found network Vodafone Hotspot WiFi: ../src/SocketServer.cpp(353): found network UPC2746378 WiFi: sleep enable,type: 2 WiFi: scandone WiFi: state: 0 -> 2 (b0) WiFi: state: 2 -> 3 (0) WiFi: state: 3 -> 5 (10) WiFi: add 0 WiFi: aid 1 WiFi: cnt WiFi: WiFi: connected with 19092, channel 1 WiFi: dhcp client start... WiFi: wifi evt: 0 -
Unfortunately I don't have anything else to add, but that would at least have all the information available to someone else who might help - however I suspect the issue is just the ESP8266 wifi doesn't work with the Vodaphone routers (or the other way around depending on which side isn't wifi compliant)
Given the previous reports of the vodaphone device not working I'm not sure what else to say. Please try with another router to see if the Duet wifi module is actually working, or set the duet to access point mode to see if the module is working.
https://duet3d.dozuki.com/Wiki/Gcode#Section_M589_Configure_access_point_parameters
