i hate upgrades
If you send M552 S0, and then M552 by itself a few seconds later, what does it report?
ok i left it and now when i turned the printer on it connected but i got an error telling me to reload the web interface again
JavaScript ErrorA JavaScript error has occurred so the web interface has closed the connection to your board. It is recommended to reload the web interface now. If this happens again, please contact the author and share this error message:
Version: 1.22.6
Message: Uncaught TypeError: Cannot read property 'toFixed' of undefined
URL: http://192.168.1.5/js/dwc.js
Line: 4468:75
Error object: {} -
@kostasbmw said in i hate upgrades:
Version: 1.22.6
you should probably update this as well
https://github.com/Duet3D/DuetWebControl/releases/tag/3.1.1
https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Updating_DuetWebControl_files -
Version: 1.22.6
Line: 4468:75
Error object: {}If you are running RRF 3.1.1 on the main board (which you are according to the M122 report), then you need to run a later version of Duet web Control than 1.22.6.
Edit : @bearer beat me to it.
i m trying to locate my version on the dwci reloaded the the files in the www folder and no error
should i reflash with the firmware????
my m122m122
SENDING:M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later + DueX2
Board ID: 08DGM-917NK-F2MS4-7JKFD-3S46R-1HSDD
Used output buffers: 1 of 24 (10 max)
Static ram: 27980
Dynamic ram: 93324 of which 680 recycled
Exception stack ram used: 308
Never used ram: 8780
Tasks: NETWORK(ready,468) HEAT(blocked,1456) DUEX(suspended,160) MAIN(running,1824) IDLE(ready,80)
Owned mutexes: WiFi(NETWORK)
Last reset 00:03:40 ago, cause: power up
Last software reset at 2020-07-08 18:20, reason: User, spinning module GCodes, available RAM 11452 bytes (slot 2)
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
Error status: 0
[ERROR] Error status: 0MCU temperature: min 25.0, current 31.2, max 31.4
Supply voltage: min 23.9, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
Driver 5: standstill, SG min/max not available
Driver 6: standstill, SG min/max not available
Date/time: 2020-07-09 17:52:14
Cache data hit count 372512281
Slowest loop: 9.67ms; fastest: 0.13ms
=== Storage ===
Free file entries: 10
SD card longest read time 3.1ms, write time 0.0ms, max retries 0
Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
=== MainDDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
=== AuxDDARing ===
Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is ready with "M122" in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 39.96ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.23
WiFi MAC address 84:f3:eb:83:44:a8
WiFi Vcc 3.38, reset reason Unknown
WiFi flash size 4194304, free heap 24632
WiFi IP address 192.168.1.5
WiFi signal strength -48dBm, reconnections 0, sleep mode modem
=== DueX ===
Read count 1, 0.27 reads/min
and this is what the dwc says
Board: Duet 2 WiFi (2WiFi)
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.1.1 (2020-05-19b2)
Duet WiFi Server Version: 1.23 - WiFi -
M122 will not show DWC version, but you have DWC 1.22.6 and RRF 3.1.1.
So you need to also have DWC 3.1.1 which I linked to above. The second link has the instructions on how to extract it to the sd card as DWC is not currently working you need to put the sd card in your computer temporarily.
edit: oh, i took the error to mean dwc didn't work, pardon the detour.
@bearer
it works i putted the folder files mannually in the sd -
As you have established communication using DWC, you can just upload the version 3.1.1 DuetWebControl.zip file through the DWC Upload System Files button.
just finished and i get
Duet WiFi Server Version: 1.23i hope its ok now
The DWC version can also be found in the settings page of DWC.
