i hate upgrades
Duet Web Control
1.1k
    kostasbmw @A Former User
    @bearer
    i followed instructions ..i missed one to uncomment the m552 s1
    the thing is to reset the wifi because without it nothing to do......
    i dont know if i can do something through the sd card
      A Former User @kostasbmw
      @kostasbmw said in i hate upgrades:
      WiFi Server Version: 1.21
      did you upgrade this along the way?
      download and place DuetWiFiServer.bin (v1.23) on the sd-card in the /sys folder and run
      M552 S0
      M997 S1
      M588 S"*"
      confirm the updated version and a blank wifi module with
      M122
      M587
      undefined 1 Reply Last reply 9 Jul 2020, 12:01 Reply Quote 0
        @bearer said in i hate upgrades:
        M552 S0
        M997 S1
        M588 S"*"
        M122
        M587
        m552 s0
        ok
        m997 s1
        Trying to connect at 230400 baud: success
        Erasing 4096 bytes...
        Erasing 212992 bytes...
        Uploading file...
        5% complete
        10% complete
        15% complete
        20% complete
        25% complete
        30% complete
        35% complete
        40% complete
        45% complete
        50% complete
        55% complete
        60% complete
        65% complete
        70% complete
        75% complete
        80% complete
        85% complete
        90% complete
        95% complete
        Upload successful
        ok
        m588 s"*"
        Error: M588: Failed to reset the WiFi module to factory settings
        ok
        m122
        RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later + DueX2
        Board ID: 08DGM-917NK-F2MS4-7JKFD-3S46R-1HSDD
        Used output buffers: 1 of 24 (1 max)
        Static ram: 27980
        Dynamic ram: 93324 of which 680 recycled
        Exception stack ram used: 320
        Never used ram: 8768
        Tasks: NETWORK(ready,396) HEAT(blocked,1456) DUEX(suspended,160) MAIN(running,1816) IDLE(ready,80)
        Owned mutexes:
        Last reset 00:02:20 ago, cause: power up
        Last software reset at 2020-07-08 18:20, reason: User, spinning module GCodes, available RAM 11452 bytes (slot 2)
        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
        Error status: 0
        MCU temperature: min 25.7, current 30.4, max 30.5
        Supply voltage: min 23.9, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
        Driver 5: standstill, SG min/max not available
        Driver 6: standstill, SG min/max not available
        Cache data hit count 263916142
        Slowest loop: 9.65ms; fastest: 0.14ms
        === Storage ===
        Free file entries: 10
        SD card longest read time 3.1ms, write time 0.0ms, max retries 0
        Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
        === MainDDARing ===
        Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
        === AuxDDARing ===
        Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
        Segments left: 0
        Movement lock held by null
        HTTP is idle in state(s) 0
        Telnet is idle in state(s) 0
        File is idle in state(s) 0
        USB is ready with "m122" in state(s) 0
        Aux is idle in state(s) 0
        Trigger is idle in state(s) 0
        Queue is idle in state(s) 0
        Daemon is idle in state(s) 0
        Code queue is empty.
        === Network ===
        Slowest loop: 1193.73ms; fastest: 0.00ms
        HTTP sessions: 0 of 8
        • WiFi -
          Network state is disabled
          WiFi module is disabled
          === DueX ===
          Read count 1, 0.43 reads/min
          ok
          m587
          Error: M587: Failed to retrieve network list
          ok
          m552
          ok
          m552 s0
          ok
          WiFi module started
          this is what i get with m587
          If you send M552 S0, and then M552 by itself a few seconds later, what does it report?
            kostasbmw
            ok i left it and now when i turned the printer on it connected but i got an error telling me to reload the web interface again
            JavaScript Error
            A JavaScript error has occurred so the web interface has closed the connection to your board. It is recommended to reload the web interface now. If this happens again, please contact the author and share this error message:
            Version: 1.22.6
            Message: Uncaught TypeError: Cannot read property 'toFixed' of undefined
            URL: http://192.168.1.5/js/dwc.js
            Line: 4468:75
            Error object: {}
            ? undefined 2 Replies Last reply 9 Jul 2020, 14:48 Reply Quote 0
              Version: 1.22.6
              you should probably update this as well
              https://github.com/Duet3D/DuetWebControl/releases/tag/3.1.1
              https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Updating_DuetWebControl_files
                dc42 administrators @kostasbmw
                JavaScript Error
                Version: 1.22.6
                Line: 4468:75
                Error object: {}
                If you are running RRF 3.1.1 on the main board (which you are according to the M122 report), then you need to run a later version of Duet web Control than 1.22.6.
                Edit : @bearer beat me to it.
                undefined 1 Reply Last reply 9 Jul 2020, 14:51 Reply Quote 0
                  kostasbmw @dc42
                  i m trying to locate my version on the dwc
                  i reloaded the the files in the www folder and no error
                  should i reflash with the firmware????
                  my m122
                  m122
                  SENDING:M122
                  Used output buffers: 1 of 24 (10 max)
                  Static ram: 27980
                  Exception stack ram used: 308
                  Never used ram: 8780
                  Tasks: NETWORK(ready,468) HEAT(blocked,1456) DUEX(suspended,160) MAIN(running,1824) IDLE(ready,80)
                  Owned mutexes: WiFi(NETWORK)
                  Last reset 00:03:40 ago, cause: power up
                  Error status: 0
                  [ERROR] Error status: 0
                  MCU temperature: min 25.0, current 31.2, max 31.4
                  Supply voltage: min 23.9, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                  Date/time: 2020-07-09 17:52:14
                  Cache data hit count 372512281
                  Slowest loop: 9.67ms; fastest: 0.13ms
                  === Storage ===
                  === MainDDARing ===
                  === AuxDDARing ===
                  Segments left: 0
                  USB is ready with "M122" in state(s) 0
                  === Network ===
                  Slowest loop: 39.96ms; fastest: 0.00ms
                  HTTP sessions: 1 of 8
                  • WiFi -
                    Network state is active
                    WiFi firmware version 1.23
                    WiFi MAC address 84:f3:eb:83:44:a8
                    WiFi Vcc 3.38, reset reason Unknown
                    WiFi flash size 4194304, free heap 24632
                    WiFi IP address 192.168.1.5
                    WiFi signal strength -48dBm, reconnections 0, sleep mode modem
                    === DueX ===
                    Read count 1, 0.27 reads/min
                  and this is what the dwc says
                  Board: Duet 2 WiFi (2WiFi)
                  Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.1.1 (2020-05-19b2)
                  Duet WiFi Server Version: 1.23
                    A Former User
                    M122 will not show DWC version, but you have DWC 1.22.6 and RRF 3.1.1.
                    So you need to also have DWC 3.1.1 which I linked to above. The second link has the instructions on how to extract it to the sd card as DWC is not currently working you need to put the sd card in your computer temporarily.
                    edit: oh, i took the error to mean dwc didn't work, pardon the detour.
                    undefined 1 Reply Last reply 9 Jul 2020, 14:56 Reply Quote 1
                      @bearer
                      it works i putted the folder files mannually in the sd
                        As you have established communication using DWC, you can just upload the version 3.1.1 DuetWebControl.zip file through the DWC Upload System Files button.
                        undefined 1 Reply Last reply 9 Jul 2020, 14:58 Reply Quote 0
                          kostasbmw @dc42
                          just finished and i get
                          i hope its ok now
                            The DWC version can also be found in the settings page of DWC.
                            21 out of 24
