    Duet 3 6HC - Firmware Upgrade - Flash locked
    Firmware installation
    766
    • MartinNYHCundefined
      MartinNYHC
      Hi All,
      just want to update my brand new Duet 3 6HC. Unfortunately BOSSA still doesn' work on newer Mac OS versions, so I used the command line tool bossac.
      ./bossac -p /dev/cu.usbmodem143101 -e -w -v -b /Users/martin.ziegler/Downloads/Duet2and3Firmware-3.1.1/Duet3Firmware_MB6HC.bin
      Erase flash
      Done in 3.619 seconds
      Write 570776 bytes to flash (1115 pages)
      [===                           ] 10% (118/1115 pages)
      Flash page is locked
      Even if I use the 'u' flag to unlock the flash it does not work.
      Am I doing something wrong?
      Thanks, Martin
        AFAIR, if you use the Erase jumper then it should unlock the flash.
          MartinNYHC
          That's what I did. At least I think so 😉
          Placed the junper, powered up the board, removed the jumper and started flashing.
          Thanks, Martin
            MartinNYHC
            ./bossash
            Press Ctrl-D or enter "exit" to end session.
            Enter "help" to display a command list.
            bossa> connect /dev/cu.usbmodem143101
            Connected to device on /dev/cu.usbmodem143101
            bossa> info
            Device       : ATSAME70x20
            Version      : v1.2 Jan  6 2016 09:57:32
            Address      : 0x400000
            Pages        : 2048
            Page Size    : 512 bytes
            Total Size   : 1024KB
            Planes       : 1
            Lock Regions : 64
            Locked       : none
            Security     : false
            Boot Flash   : false
              A Former User
              Hm, could you try building one of the pull requests that is meant to potentially address that bug? Although getting stuck on flash locked isn't quite same symptom "everyone" else have reported. (save some hassle by only building the cli versionmake bossac)
              Or you could try resorting to using a virtual machine running linux or windows (at least one other user had success with virtualbox + windows) I have used ubuntu and rasbpian with success as well.
                MartinNYHC
                Compiled the master branch and it works 🙂 Thanks!
                  A Former User @MartinNYHC
                  @MartinNYHC said in Duet 3 6HC - Firmware Upgrade - Flash locked:
                  awesome; it'd be great if you could leave some instructions for other mac users to follow, or upload a binary or something as every now and then this issue pops up and there aren't that many active members that are big on macs here.
                    MartinNYHC
                    Sure. What's the best place to upload the file? The forum doens't accept these kind of file type.
                      A Former User
                      a zip file maybe - or any generic sharing service like https://wetransfer.com/ etc
                        MartinNYHC
                        Here we go....
                        bossac compiled for MacOS Mojave
                        • droftartsundefined droftarts referenced this topic
