    Spurios "sensor not work" and not enough movement faults
    Filament Monitor
    9
    25
    976
    • CTRDevelopmentsundefined
      CTRDevelopments
      I get pauses like this which I am confused about as it looks to me like it is within the limits set?
        CTRDevelopments
        Rather than me mess it up can i send the unit back to get reprogrammed? It is causing me more hassle at the moment as it keeps stopping the print for no reason
          dc42 administrators @CTRDevelopments
          @CTRDevelopments said in Spurios "sensor not work" and not enough movement faults:
          I think we can arrange that. Which country are you in?
          CTRDevelopmentsundefined chickenwomanundefined 2 Replies Last reply Reply Quote 0
            CTRDevelopments @dc42
            @dc42 UK, happy to post where ever needed. thanks
              CTRDevelopments
              @dc42 If I purchase a new unit will it come with the newest firmware? Thinking it might be cheaper than sending this one back
                I'm sorry, I missed your reply of 1 May. You are welcome to send it back to me for reprogramming at: Woodpeckers, Wearne, Langport TA10 0QQ. If you send just the PCB, in an antistatic bag and a padded bag, then it should be thin enough go as a large letter which will reduce the postage.
                  CTRDevelopments
                  DC, OK, will do thanks. It just paused my print reporting -4% movement? IS this any sort of clue as to what the issue could be?
                  • chickenwomanundefined
                    chickenwoman @dc42
                    @dc42 I bought mine about a year ago from Filastruder and gave up when it wouldn't work. I think mine is a firmware issue as well. It's probable an early one because the serial # is 015. I have my min set really low, M591 D0 P3 C3 S1 R10:130 L24.7 E3.0. It starts off fine and prints for a while with a min of 93% and then drops to 24%, stays there for a while and eventually will drop again. If I pause it without doing anything to the filament or changing anything it goes back to normal 93%. My extrusion is fine and no clogs. Would it be possible for me to exchange it with Filastruder? I know it was a year ago but I never could get to work.
                    Thanks
                      Phaedrux Moderator @chickenwoman
                      @chickenwoman said in Spurios "sensor not work" and not enough movement faults:
                      Thanks
                      Hi, sorry to hear you've had some issues, please contact Filastruder and seek an exchange. Refer them to this post as authorization. Normally it would only be a 6 month warranty window but in this instance we will do an exchange.
                      chickenwomanundefined 1 Reply Last reply Reply Quote 0
                        chickenwoman @Phaedrux
                        @Phaedrux Thank you, I appreciate it.
