    Cheap WiFi Webcam: ESP32 + OV2640 camera
    Duet Web Control
    10
    28
    7.0k
    • arhiundefined
      arhi @A Former User
      @bearer said in Cheap WiFi Webcam: ESP32 + OV2640 camera:
      @arhi said in Cheap WiFi Webcam: ESP32 + OV2640 camera:
      cheapest wired solution
      does esp32 + enc26j80 (from memory) fit the bill? or even esp with SLIP ?
      dunno what's SLIP ?
      I'm testing ESP32-CAM with ENC26J80 but having some issues getting it work for (for now)
      trying to find solution that's good & not too expensive... I had very high hopes for itead camera as most of their stuff is open source or if not open sourced by them open source by "some crazy dude on github" 😄 but .. no 😞 .. (still not gave up on them, testing the latest hack I found trying to rebuild the whole linux to put mine there ... maybe there is a way to have everything custom except blob for camera but that I can deal with, major problem I have is I once already got my lan intruded trough PRC camera that I could not update - that's why I wanna go wired only we'll see)
      difference between rpi1 and rpi3 in price are minor while huge in performance so with rpi3 I can then offload a whole bunch of stuff from zoneminder to rpi.. and I can use all those rpi's in network for bunch of other stuff I normally use rpi's so the camera's can also be a cluster nodes 😄 .. so money well spent ..
      we'll see if I manage to get esp32-cam to work with enc that's 7$ total for the whole device, that's cheaper than the power supply for the pi 😄
      what's that slip thing?
      p.s. I have also W5500 here that I will test if I give up on ENC
        A Former User @arhi
        dunno what's SLIP
        modem without the modem bit 😉 serial 1/3rd down the page https://www.tldp.org/HOWTO/NET3-4-HOWTO-7.html
        I've had success with the enc28j60 for both esp and (antique) pi's but the speed is in the low hundreds kb/s range.
        • arhiundefined
          arhi @A Former User
          @bearer that's kinda slow, I'd like to have a video stream worth watching 😄
            A Former User @arhi
            it is slow, but the resolution of the espcam isn't something to write home about either, so might work - both options.
            • arhiundefined
              arhi @A Former User
              @bearer enc work is under way so I'll try to get it to work, also w5500 (I think that one is used on duet) so we'll see how it will behave
              • arhiundefined
                arhi @A Former User
                Looks like I need to write Ethernet library myself (modify existing one). They use "SPI" object and that's not available on esp32-cam, those pins are attached to the camera module. There should be HSPI available but for that I need to do a lot of search/replace + some initialization to use HSPI port on the esp .. we'll see .. should be simple but..
                  A Former User
                  hmm, bummer, only tried it with the esp8266 eons ago.
                  i think i've seen some nutjob implement ethernet with just a line driver and some magnetics
                  https://www.youtube.com/watch?v=XKnyAYKP434
                  • arhiundefined
                    arhi @A Former User
                    @bearer interesting project but dunno if any of my switches support 10baseT and since this is for 8266 again need to rewrite it to fit esp32 .. I'll see how quickly I can fork the Ethernet library to make it use that HSPI that is supposedly available on esp32-cam (actually, first I'll just see if I can output anything on esp32-can via that hspi before I start editing that library).. we'll see .. W5500 is el cheapo, could be a good fit here.. and having both wifi and eth in a camera with sd card could be useful, even without sdcard..
                    I was hoping I will be able to find an open source camera out there for 20$ or under but 😞
                      A Former User
                      I'd thunk it'd work with any 10/100/1000 switch, I'd be surprised if people are makings switches that can only do 100/1000.
                      Anyways ,yeah, I was a little lolwhat? when i saw that video the first time, gotta love clever people with too much time on their hands :')
                      • arhiundefined
                        arhi @A Former User
                        @bearer 10b2 is completely different framing, the protocol is totally different from 100b2 and 1000b2. I know my small switches don't do 10b2 (learned that the hard way, had to find some old hub with 100b2 uplink channel to connect some old silicon graphics and sun machines some time ago), dunno about my big managed switches if they do .. anyhow not making that, I don't think it's worth it... will see if I can get this esp32-cam to work somehow with w5500 and if not moving away from that... still have not tried that hacked firmware for the itead camera, found some additional data on that might be useful we'll see, or I'll brick one (thats why I purchased 2 😄 )
                        • arhiundefined
                          arhi @arhi
                          ha, after a lot of search and replace...
                          ets Jun  8 2016 00:22:57
                          rst:0x1 (POWERON_RESET),boot:0x1b (SPI_FAST_FLASH_BOOT)
                          configsip: 0, SPIWP:0xee
                          clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
                          mode:DIO, clock div:1
                          load:0x3fff0018,len:4
                          load:0x3fff001c,len:1216
                          ho 0 tail 12 room 4
                          load:0x40078000,len:9720
                          ho 0 tail 12 room 4
                          load:0x40080400,len:6352
                          entry 0x400806b8
                          Ethernet WebServer Example
                          server is at 192.168.89.11
                          new client
                          GET / HTTP/1.1
                          Host: 192.168.89.11
                          Connection: keep-alive
                          Cache-Control: max-age=0
                          Upgrade-Insecure-Requests: 1
                          User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/83.0.4103.116 Safari/537.36
                          Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9
                          Accept-Encoding: gzip, deflate
                          Accept-Language: en-US,en;q=0.9
                          DNT: 1
                          😄 ethernet working with W5500 on ESP32-CAM 😄 ... now to send image trough web somehow 😄
                          • arhiundefined
                            arhi
                            yeah, it works. ESP32-CAM + W5500 streaming jpegs 😄
                            • arhiundefined
                              arhi
                              If anyone is crazy enough to need this 🙂
                              https://github.com/arhi/EthernetSPI2
