    Unexpected token a in JSON at position 251
    Duet Web Control
    594
      jay_s_uk
      What issues were you having when you upgraded to RRF3?
      curlypaulundefined 1 Reply Last reply Reply Quote 0
      • curlypaulundefined
        curlypaul @jay_s_uk
        @jay_s_uk I haven't tried RRF3 yet, But with 2.05 and 2.04 my second set of motors didn't move as expected
        in this post here...
        link text
          jay_s_uk
          have you thought about trying a newer version of DWC? I believe 2.07 should work ok.
          If you don't like it, you can easily go back to 1.22.6 as well.
            dc42 administrators @curlypaul
            @curlypaul said in Unexpected token a in JSON at position 251:
            link text
            I can't tell from that thread what actually changes when you upgrade from 2.02 to 2.05. Please start a new thread about that, and include the config.g and homing files that work with 2.02 in that thread.
              curlypaul @dc42
              When i get it up and ruuning again I will certainly do that with the seperate thread.
              Still the same issue with DWC 2.07...
              Checked through config.g to see if messed anything, but literally all i changed were E steps/mm
                jay_s_uk
                can you get an output of M122? It would be interesting to see what your wifi signal is
                  curlypaul @jay_s_uk
                  @jay_s_uk
                  M122 dump is in the second post.
                  It's about 3m away from Unifi access point, i have another printer (duet) right next to this printer running ok
                    jay_s_uk
                    Missed that.
                    -46db is perfectly fine so that's not the issue.
                    Best to follow dc42's advice and work out where the issues lie when upgrading from 2.02 to 2.05.1
                      deckingman @curlypaul
                      Long shot here but logically, if all you did was edit something in config.g, then the issue must either be something to do with that edit, or it's just an unfortunate co-incidence. If it was me, I would comment out the line that was edited, then carefully type it again. Just in case a hidden character has crept in somewhere that is screwing things up. Maybe post your config.g just in case one of us can spot something that you might have missed.
                        curlypaul
                        I changed the E steps on second extruder from 802, to 401 as swapped from 0.9 to 1.8deg motor
                        M584 X3 Y4 Z2 E7:6 U0 V1 P4                       		; set drive mapping
                        M350 X16 Y16 U16 V16 Z16 E16:16 I1                  		; configure microstepping with interpolation
                        M92 X160 Y160 U160 V160 Z2560 E402:401   			; set steps per mm
                        M566 X1200 Y1200 U1200 V1200 Z25 E2500:2500			; set maximum instantaneous speed changes (mm/min)
                        M203 X20000 Y20000 U20000 V20000 Z600 E9000:9000		; set maximum speeds (mm/min)
                        M201 X1000 Y1000 U1000 V1000 Z500 E3000:3000      		; set accelerations (mm/s^2)
                        M906 X1200 Y1200 U1200 V1200 Z1500 E900:E900 I30   		; set motor currents (mA) and motor idle factor in per cent
                        M84 S60                                         		; Set idle timeout
                          curlypaul
                          Deleted the lot and typed it all in again
                          Working now
                          Goodness knows what that was all about
                          Thankyou to those that chipped in 🙂
                            Working now
                            I recall that a few RRF versions ago, I fixed a bug which caused invalid JSON to be generated in some configurations. Looks like you hit it.
                              curlypaul @dc42
                              @dc42 - thanks i think !? 🙂
                              I kind of hope i 'hit 'it' in a way
