    Layer count
    37
    5.9k
    • InSanityundefined
      InSanity
      The object is 0.2mm X 251 layers so yes 50.2 mm high. The printer is showing 150mm and 750 layers. This is a direct slice right from S3D 3.1.1 without any types of edits. Sliced, saved, upload, print. It seams to sometimes work and sometimes not. I see 750 layers often.
      Here is the G-Code for your reference: The File
      Jeff
      Duet WiFi Powered FFCP with E3D legends hotend system. BLTouch grid leveling.
      • Merlinundefined
        Merlin
        David,
        Sorry did not respond to your request of Jan 13th.
        Somehow I am not getting advised when threads I have contributed too are updated.
        Where do I reset this?
        As you have now released 1.17c with the MH layer fix I assume you no longer need any more gcode examples.
          Merlin, please let us know whether 1.17c fixes the problem. I was not able to test the fix.
          • InSanityundefined
            InSanity
            Any ideas on the S3D layer count issue? I did a print last night with the same 750 layers showing when it shouldn't have been.
            Thanks,
            Jeff
            • Shotfireundefined
              Shotfire
              WebControl seems to be displaying inaccurate info while printing.
              1. The progress Bar is stuck saying "Layer 2 of 440" and not incrementing ; Cura say theres only 100 layers
              2. Filament usage is also way off; Cura says 11.975m WebControl shows 49.2252
              Size:
              12.8 MiB
              Object Height:
              110 mm
              Layer Height:
              0.25 mm / 0.25 mm
              Filament Usage:
              49225.2 mm
              Generated by:
              Cura_SteamEngine 2.5.0
              Here's the first part of the code
              ;FLAVOR:RepRap
              ;TIME:4651
              ;Filament used: 11.9751m
              ;Layer height: 0.2
              ;Generated with Cura_SteamEngine 2.5.0
              M190 S110
              M104 S245
              M109 S245
              ;Start of START Code
              M561 ; Clear any bed transform
              G28 ;Home All Axis
              G29 ;Bed Mesh
              G90 ; absolute positioning
              G92 E0 ; zero extruders
              M106 S0 ;Set Cooling Fan to 0
              G1 X235 Y3 Z1 F3000 E0.3 ; Position to Wipe
              G1 X15 Y3 Z0.3 F3000 E25.00 ; Wipe
              G1 E23 F2000
              ;LAYER_COUNT:100
              ;LAYER:0
              M107
              G0 F9000 X22 Y15.501 Z0.18
              ;TYPE:SKIRT
                @Shotfire, can you make that file available to me via Dropbox or similar?
                • burtoogleundefined
                  burtoogle
                  Hi shotfire, is your print spiralized? Webcontrol doesn't show the correct info when printing a Cura spiralized model.
                  • Shotfireundefined
                    Shotfire
                    @burtoogle, No, I'm just printing a a new box for the DuetWif right now. But it happens on every print I do no matter what size or shape
                      burtoogle
                      That's weird, I'm using Cura 2.5 and the layer stats + time prediction all work as they should.
                        burtoogle
                        I would also like to take a look at one of your gcode files that are misbehaving. As DC says, can you put it on Dropbox or similar.
                        • Shotfireundefined
                          Shotfire
                          I have put it on my dropbox but I don't use dropbox very much, I think I need your email address to give you access
                            burtoogle
                            Using the dropbox website you can make the file public and then copy a link which can be pasted into the forum here.
                            • Nuffeundefined
                              Nuffe
                              My DWC has been today stuck with 1399 layers. Third print today. Even with different browser sessions. DWC seem to have some problems updating layer counts between different prints if the same session/browser window is used, but now this one happens even with different computers. And I have not had a print with 1399 layers.
                              • Nuffeundefined
                                Nuffe
                                @Nuffe:
                                this was explained in David's earlier comment. I had newly created end code section using G1.
                                • Shotfireundefined
                                  Shotfire
                                  Link to File - https://www.dropbox.com/s/qmof43tgvdw58kx/DR2_Doug_duet_wifi_case_1_May-2017_V1%20v2_PetG.gcode?dl=0
                                    I'll try to make time to look at it tomorrow. Today was taken up with finishing the 1.19alpha firmware release.
                                      burtoogle
                                      I have looked at your gcode and it seems to me that it doesn't match the snippet you show in your message of 1st May. The filament used in the file is what DWC reports (49.2252m). Other than that, it doesn't have an M82 to set the extruder into absolute mode (you have that elsewhere, right?). Looking at the Duet code it seems to me that the only way the layer count could not get incremented would be if you had a very small nozzle diameter specified because then the following would never be true:
                                      liveCoordinates[Z_AXIS] < platform->GetNozzleDiameter() * 1.5
                                      So with your layer height of 0.25mm, if the nozzle diameter was smaller than 0.1666 (unlikely), layer changes won't get detected.
                                      One other comment which isn't related to the layer report problem but is related to Cura 2.5 is that Cura now has a new option to expand areas of skin into infill which is useful when you have small areas of infill underneath features such as pillars (which you have in your print). If you are not yet using the expand skin into infill option, I recommend that you do. If your gcode example has been generated with that option enabled then something is wrong and I need to fix it!!
                                      Finally, from the file name I guess you're using PETG. I have found that if I keep combing enabled (Cura feature to avoid retracts and speed up movement) when printing PETG that the nozzle tends to pick up filament and after a while it gets deposited as a hard lump onto the print. So, for PETG, I turn off combing completely.
                                        The only issue I can see with that gcode file is the common one, that you have a G1 Z command in your end gcode that is confusing the object height detection. It's this line:
                                        G1 Z110 F1200 ;Move Z Down
                                        The workaround is to start the comment on that line with ;E or ; E for example:
                                        G1 Z110 F1200 ;E Move Z Down
                                        • pcsentinelundefined
                                          pcsentinel
                                          Also noticed that if you do a spiral vase print then you get weird layer reporting
                                            deckingman
                                            @pcsentinel:
                                            You will do. If you think about it, there is either only one layer or an almost infinite number of layers, depending on how you look at it.
