Mini differential ir gives me problem
IR Height Sensor
    zecchi
    I've bought mini ir sensor. However this is the repetitivity test:
    This is the macros that I've used :
    I think the problem is the trigger height ( now the sensor is 3mm from the nozzle, too much 😕 )... So for now, I want to change the support in order to decrease the height between nozzle and sensor.
    Have you any advices? Thanks
      zecchi
      solved!!!
      the problem was the height beteween nozzle and probe
        matej1006
        Hello how did you calibrate your mini Ir sensor
