BL touch Working on duet2wifi but not on duex5
Firmware installation
    Hiroaki
    Hello.
    I am trying to use a BL touch on my 3D printer.
    First of all, I connected my BL touch to pin 31(heater 7), 5V and ground on the Duet2wifi and worked perfectly.
    Now I have connected a Duex5 expansion board and reconnected a BL touch to PWM5 on the Duex5 board.
    My RR Firmware is 2.05.
    According to use a Duex5 board, I changed the parameters in config.g, deployprobe.g and retractprobe.g files as follows.
    M307 H7->H3 A-1 C-1 D-1
    M280 P7->P3 I1->(erase) S10
    M280 P7->P3 I1->(erase) S90
    When I turned the swich on the BL touch doesn't light up.
    Are there anything else I need to modify?
    Please help me.
      fcwilt
      I believe the H7 and P7 is correct for PWM5 on the Duex5 board.
      undefined 1 Reply Last reply 24 Jul 2020, 12:14 Reply Quote 0
        Hiroaki @fcwilt
        @fcwilt Thank you for your post.
        I have tried H7, P7,P7 but it didn't light up...
        This means that the PWM port is not giving any power......
        I am really confused...
        undefined 1 Reply Last reply 24 Jul 2020, 15:39 Reply Quote 0
          fcwilt @Hiroaki
          @Hiroaki said in BL touch Working on duet2wifi but not on duex5:
          I checked my setup and this is what I have:
          M307 H7 A-1 C-1 D-1 ; step 1 - disable E6 heater to enable PWM5 - PWM signal still appears on E6 connector
          M558 P9 H2 F600 T12000 A5 S0.01 R0.2 ; step 2 - set probe configuration - part 1
          G31 X0 Y24.5 Z1.475 P25 ; step 3 - set probe configuration - part 2
          M280 P7 S160 ; clear BLTouch alarm (if any)
          undefined 1 Reply Last reply 25 Jul 2020, 01:19 Reply Quote 0
            Hiroaki
            This post is deleted!
              Hiroaki @fcwilt
              @fcwilt
              Good morning.
              Thank you so much.
              I have found that there was no jumper on the duex5 board which is to set 5V aux select.
              No other jumper is on the Duex5 board now.
              I hope it's ok...
              2 out of 6
