    Mixed Fan Voltage on Duet3
    • empi00undefined
      empi00
      Can the Duet 3 handle mixed fan voltage?
      Supply the FANs directly and only go with the ground over the Duet 3?
      Hotendfan: 12V
      Part cooling: 24V
      Br
        A Former User
        Yes, but only if the Vfan jumper is set to the highest voltage, given there are to Vfan jumpers you should be able to set one to Vin/24v and one to 12v and connect the fans straight to the relevant outputs on the board?
        • empi00undefined
          empi00
          Is the questionmark at the end indicating a question or a 90% answer?
          Or should this 100% (or 99%) work? 🙂
          I just dont want to blow something, as i am missing schematics,....
          A Former User? 2 Replies Last reply Reply Quote 0
            A Former User @empi00
            @empi00 question mark indicate there might be reasons you cannot set one of the two output banks to 12v; maybe you need all but 1 output to be 24v.
            if you look at the wiring diagram you will see you can select say 24v for out4-6 and 12v for out7-9 which is so obvious that I add the question mark as to why this is not the path you chose.
            but you could select 24v for both output and wire one fans positive wire directly to a 12v supply and the negative wire to the switched output like out9 as described in https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_fans#Section_Using_12V_fans_when_VIN_is_24V
            the only thing you shouldn't do is to essenstially use 24v fan when Vin is 12v.
              @empi00 said in Mixed Fan Voltage on Duet3:
              https://github.com/Duet3D/Duet3-Mainboard-6HC
              • empi00undefined
                empi00
                ahhh, ok thank you.
                My Vin is 24 Volts.
                So I will
                • choose the Vin = Vout of out7-9.
                • wire the 24 Volt fans "straight" from the Duet3
                • wire the 12 Volt fan supply line manually to the power line. ("sub voltage" trougth a DC/DC Converter 24 Volt PSU)
                --> That i read already, but i was not sure if this was also true for the Duet3, as the chapter before was "only" for the Duet Wifi
                Seeing now the schematic, i get the reason of the "vin"...
                Otherwise the diode will die...
                Thank you!
