    infill idea maker
    • Marco Bonaundefined
      Marco Bona
      Hi everyone, I am trying idea maker with standard profiles taken from the library but I am having some problems with the infill which seems under extruded. Even if you reduce speed and increase flowrate, the problem persists.
      Before I used prusaslicer and everything was fine, I don't understand if it is a duet configuration problem or if it has some small bug idea maker. Do you also have this problem?
        Sounds like the cause would be in the slicer area. The firmware doesn't have a concept of infill.
