    Fans in firmware v3.x
    Firmware installation
    • peirofundefined
      peirof
      next step get the fans going.
      Its a Delta printer, with 4 fans:
      • 1 Fan in always on shocket for Duet board
      • 1 Heatskin fan, termostatically, at 50º C, power on
      • 2 Layer fans
      In first place, post the config of fans for Firmware v2.x
      M106 P0 S0 I0 H-1 C"Capa 1"             ;Capa
      M106 P1 S0 I0 H1 T50 C"HeatSkin"        ;Heatskin
      M106 P2 S0 I0 H-1 C"Capa 2"             ;Capa
      Second place, the config.g for Firmware v3, generated by Web configurator:
      M950 F0 C"Capa Izq" Q500                      	; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                	; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                         	; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T45                             	; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"Capa Der" Q500                      	; create fan 2 on pin fan2 and set its frequency
      M106 P2 S0 H-1                                 	; set fan 2 value. Thermostatic control is turned off
      Not working, only works fan in always on shocket...-
      What can i try?
        dc42 administrators @peirof
        @peirof said in Fans in firmware v3.x:
        Those lines should be:
        M106 P0 C"Capa Izq" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
        Similarly the lines for fan 2 are wrong.
        • peirofundefined
          peirof
          This works....
          one more...
          Can remap one of the always on fan.... as termostaticaly controled fan? or other kind
          Where i live, in summer temperatures reach 35/40º C...
          The idea its mount a second fan over duet, and power on only in summer days....
          • peirofundefined
            peirof
            In this moment.... Fan that connect to duet Shocket FAN1, dont works.
            I have configured all 3 fans as layer fans, for have the possibility of power on by DWC, as follows:
            M950 F0 C"fan0" Q500                   ; create fan 0 on pin fan0 and set its frequency
            M106 P0 C"Capa Izq" S0 H-1             ; set fan 0 value. Thermostatic control is turned off
            M106 P1 C"Heatskin" S0 H-1             ; set fan 1 value. Thermostatic control is turned on-- M106 P1 S1 H1
            M950 F2 C"fan2" Q500                   ; create fan 2 on pin fan2 and set its frequency
            M106 P2 C"Capa Der" S0 H-1             ; set fan 2 value. Thermostatic control is turned off
            Its not wiring issue or fan issue, i have changed to other shocket (FAN0) and fan turn.... and i have connected other fan, a layer fan that works, to this shocket, and works...
            I do not think, I am not 100% sure, that it is a problem of the board, since before updating to this firmware, in fan connected to FAN1, it worked, it was that of the Heatskin.
            I don't think it's the fuse either ... if it were, no fan would go. Not? the fuse protects all fans. Not?
            What can be?
              A Former User
              @peirof said in Fan1 don't works after update to FW3.1.1:
              As I had commented in previous post, after updating to Firmware 3.x, one of the fans, the one connected to the FAN1 shocket has stopped working ...
              surely one thread is sufficient?
              On FAN2, the voltage was 20.80 ... I guess insufficient to spin the fan
              20.8v is more than likely enough to spin a fan 24v fan; but odds are its not 20.8v when you connect a fan to it.
              google "mosfet multimeter" and test the mosfet properly (when the power is off)
