    When uploading a file, view appears infinite.
    Duet Web Control
    280
    • fiveblade007undefined
      fiveblade007
      I am a duet wifi user.
      I set up a duet board yesterday and am using it well.
      I think it is a good and good board.
      I have a question.
      When uploading a file to the duet board, the same file appears to be infinite.
      Actually, when I look at the micro SD card on my computer, there is only one file, but it looks infinite on the duet board web screen.
      Is there any way to solve it?
        Can you share a screenshot of what you're describing?
          fiveblade007
            fiveblade007
              Can you send M122 and report the results? Also check the version of DWC installed by looking in settings > general.
              I think you may need to update your firmware and DWC version.
              fiveblade007undefined 1 Reply Last reply Reply Quote 0
                fiveblade007 @Phaedrux
                @Phaedrux
                THK For your kindness 😉
                M122
                Used output buffers: 4 of 32 (9 max)
                RepRapFirmware for Duet 2 WiFi/Ethernet version 1.21 running on Duet WiFi 1.02 or later
                Board ID: 08DLM-996AL-K65SW-6J9F2-3S06N-1V7LZ
                Static ram used: 16152
                Dynamic ram used: 100504
                Recycled dynamic ram: 2128
                Stack ram used: 1224 current, 4448 maximum
                Never used ram: 7840
                Last reset 00:00:27 ago, cause: power up
                Last software reset at 2020-07-31 14:19, reason: User, spinning module GCodes, available RAM 7760 bytes (slot 1)
                Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
                Error status: 0
                Free file entries: 10
                SD card longest block write time: 0.0ms
                MCU temperature: min 33.1, current 37.0, max 37.2
                Supply voltage: min 23.9, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0
                Date/time: 2020-08-01 08:53:09
                Slowest main loop (seconds): 0.015654; fastest: 0.000046
                MaxReps: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
                Bed compensation in use: none
                Segments left: 0
                Movement lock held by null
                http is idle in state(s) 0
                telnet is idle in state(s) 0
                file is idle in state(s) 0
                serial is idle in state(s) 0
                aux is idle in state(s) 0
                daemon is idle in state(s) 0
                queue is idle in state(s) 0
                Code queue is empty.
                === Network ===
                Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
                HTTP sessions: 1 of 8
                • WiFi -
                  Network state is running
                  WiFi firmware version 1.23
                  WiFi MAC address 8c:aa:b5:d4:63:4c
                  WiFi Vcc 3.39, reset reason Turned on by main processor
                  WiFi flash size 4194304, free heap 24584
                  WiFi IP address 192.168.0.12
                  WiFi signal strength -49dBm, reconnections 0, sleep mode modem
                  Socket states: 2 0 0 0 0 0 0 0
                  === Expansion ===
                  Phaedrux Moderator @fiveblade007
                  @fiveblade007 said in When uploading a file, view appears infinite.:
                  You're running a very old version of the firmware. 1.21
                  Time to upgrade to at least 2.05.1 along with DWC 2.0.7 found here: https://github.com/Duet3D/RepRapFirmware/releases/tag/2.05.1
                  Best to check the releases notes as well since a few things will have changed since 1.21.
                  https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md
                  https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
                    fiveblade007
                    thank for your kindness. I did it & solve the problem 😉
                      Glad that helped. Now that you're current with 2.05.1 it's time to start considering the move to RRF3.
