    IR Probe issue after 3.1.1 update from 3.0
    Firmware installation
    782
    • Adamfilipundefined
      Adamfilip
      Not sure what else to try.. its not working 😞
      ; homeall.g
      ; called to home all axes
      ; generated by RepRapFirmware Configuration Tool v2.1.5 on Wed Jan 08 2020 19:38:55 GMT-0500 (Eastern Standard Time)
      M400			; make sure everything has stopped before we make changes
      G91			; use relative positioning
      G1 H2 Z20 F6000    	; lift Z relative to current position
      G1 H1 Y-350 F3000 	; move quickly to Y axis endstop and stop there (first pass)
      G4 P500			; wait 500msec
      G1 Y0			; move away from home
      G1 H1 X-350 F3000 	; move quickly to X axis endstop and stop there (first pass)
      G90			; back to absolute positioning
      G1 X150 Y150 F3000 	; Centre Print head
      G30
      G1 X0 Y0 F2000 		; Head To Origin
      Config
      G90                                              ; send absolute coordinates...
      M83                                              ; ...but relative extruder moves
      M550 P"TitanXY"                                  ; set printer name
      M667 S1                                          ; select CoreXY mode
      M552 S1                                          ; enable network
      M586 P0 S1                                       ; enable HTTP
      M586 P1 S0                                       ; disable FTP
      M586 P2 S0                                       ; disable Telnet
      M569 P0 S0                                      ; physical drive 0 goes backwards
      M569 P1 S0                                    ; physical drive 1 goes backwarsa
      M569 P2 S0                                       ; Z physical drive 2 goes backwards
      M569 P3 S1                                       ; Extruder physical drive 3 goes Forwards
      M584 X0 Y1 Z2 E3                                 ; set drive mapping
      M350 X32 Y32 Z32 I0                              ; configure microstepping without interpolation
      M350 E16 I1                                      ; configure microstepping with interpolation
      M92 X400 Y400 Z1593 E409             ; set steps per mm
      M566 X600 Y600 Z20 E800 ; Set maximum instantaneous speed changes (mm/min)
      M203 X9000 Y9000 Z1500 E10000 ; Set maximum speeds (mm/min)
      M201 X1000 Y1000 Z250 E5000 ; Set accelerations (mm/s^2)
      M906 X1200 Y1200 Z1500 E1300 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M572 D0 S0.15 ; Pressure Advance                                        ; Set idle timeout
      M208 X-7 Y-22 Z0 S1                                 ; set axis minima
      M208 X312 Y331 Z300 S0                           ; set axis maxima
      M574 X1 S1 P"xstop"   ; X min active high endstop switch
      M574 Y1 S1 P"ystop"   ; Y min active high endstop switch
      M558 P1 C"zprobe.in" H5 F200 T2000            ; set Z probe type
      G31 P500 X0 Y-40 Z2.65 		; Z probe trigger offset, high Z number closer means to bed (LARGER Z MEANS CLOSER BED)
      M557 X10:290 Y10:290 S25                         ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4138   ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0                            ; create bed heater output on bedheat and map it to sensor 0
      M140 H0											; Map heated bed to heater 0
      M143 H0 S120                                     ; set temperature limit for heater 0 to 120C
      M307 H0 A61.9 C160.5 D1.3 B0 S0.5 v24.4          ; disable bang-bang mode for the nozzle heater and set PWM limit
      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                             ; create nozzle heater output on e0heat and map it to sensor 1
      M143 H1 S285; set temperature limit for heater 1 to 280C
      M307 H1 A310.2 C150.5 D3.5 B0 S1 v24.3		;NEW
      ;M307 H1 A493 C243 D3.9 B0 S0.9 v24.3          ; disable bang-bang mode for the nozzle heater and set PWM limit
      M950 F0 C"fan0" Q500                             ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                   ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                             ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T45                                ; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"fan1" Q500                             ; create fan 2 on pin fan1 and set its frequency
      M106 P2 S1 H1 T45                                ; set fan 2 value. Thermostatic control is turned on
      M563 P0 D0 H1 F0                                 ; define tool 0
      G10 P0 X0 Y0 Z0                                  ; set tool 0 axis offsets
      G10 P0 R0 S0                                     ; set initial tool 0 active and standby temperatures to 0C
        Adamfilip
        probe reading fluctuates alot.. when machine is idle.. 80-100 typical, not close to zero..
          Is this a Duet IR sensor or a clone? Was it purchased recently?
            Adamfilip
            its a Duet sensor.. not clone. purchased 4 months ago
              Adamfilip
              I reduced the trigger value from 500 down to 400 and it seems to be working again. before updating firmware it worked fine at 500
                Phaedrux Moderator @Adamfilip
                @Adamfilip said in IR Probe issue after 3.1.1 update from 3.0:
                Is it working better now?
                  Adamfilip
                  no, I spoke too soon!
                  It does trigger more consistently but its all over the place now
                  probing.JPG l)
                    Adamfilip
                    Should i use M558 P2 instead of P1?
                      Adamfilip
                      I ran a Mesh compensation sequence and I noticed that when it was probing. While watching the Z probe values.. sometimes the Probe value was around 100 between probings and other times it was zero.. makes me wonder if there is a wire issue
                        What's your wiring like? Photo? Is it running alongside anything else?
                          Adamfilip
                          I checked the wiring and one of the wires in the dupont connector was loose. I adjusted it and now its working properly. So I will consider this resolved. thanks for helping look into this.
                            Glad you figured it out.
