    IR Probe issue after 3.1.1 update from 3.0
    Firmware installation
    782
      Is this a Duet IR sensor or a clone? Was it purchased recently?
      • Adamfilipundefined
        Adamfilip
        its a Duet sensor.. not clone. purchased 4 months ago
          Adamfilip
          I reduced the trigger value from 500 down to 400 and it seems to be working again. before updating firmware it worked fine at 500
            Phaedrux Moderator @Adamfilip
            @Adamfilip said in IR Probe issue after 3.1.1 update from 3.0:
            Is it working better now?
              Adamfilip
              no, I spoke too soon!
              It does trigger more consistently but its all over the place now
              probing.JPG l)
                Adamfilip
                Should i use M558 P2 instead of P1?
                  Adamfilip
                  I ran a Mesh compensation sequence and I noticed that when it was probing. While watching the Z probe values.. sometimes the Probe value was around 100 between probings and other times it was zero.. makes me wonder if there is a wire issue
                    What's your wiring like? Photo? Is it running alongside anything else?
                      Adamfilip
                      I checked the wiring and one of the wires in the dupont connector was loose. I adjusted it and now its working properly. So I will consider this resolved. thanks for helping look into this.
                        Glad you figured it out.
