    M28, writing file with comments possible?
    466
    • Kolbiundefined
      Kolbi
      UPDATE: BLUF, M28 "0:/macros/test" will create the file 'test' in the directory 'macros' but any lines beginning with comments ';' will be ignored. M559 can replace the command M28 and allows the comment lines to be written to the file, but the command differs in that it requires a 'P' before the file name such as: M559 P"0:/macros/test"
      If using the M559 command, ensure you use the P - else your config.g in /sys/ will be overwritten.
      In using the M28 command, I just realized that my expected comments in the file to be written are ignored - example follows.
      Using the following:
        M28 "0:/macros/test"                                           ; Begin writing to SD card file
        ; 0:/macros/Heat Nozzle
        ; Heat nozzle to set temp
        M291 R"Filament Handling" P"Heating nozzle for PETg, please wait." S0 T5
        T0                                                             ; Activate Hotend
        M109 S230                                                      ; set temp to 230c and wait
        M29                                                            ; Stop writing to SD card
      Results in this file:
      Is it possible to retain the comments, to get the following result?
      Thanks,
      Kolbi
        A Former User
        Look at M559 instead? (i posted to a recent thread on the topic with a caveat, and its only usable over usb, if you need it self contained then no-go)
        Kolbiundefined 1 Reply Last reply Reply Quote 0
        • Kolbiundefined
          Kolbi @A Former User
          @bearer said in M28, writing file with comments possible?:
          Most definitely a no-go...
          When executing the following:
            M559 "0:/macros/test"                                           ; Begin writing to SD card file
          It resulted in:
          M98 P"0:/macros/Maintenance/test"
          Writing to file: config.g
          And - it most definitely overwrote my config.g 😭
          ...always have a backup☺
          A Former User? 2 Replies Last reply Reply Quote 0
            A Former User @Kolbi
            @Kolbi said in M28, writing file with comments possible?:
            probably, not sure if its reliant on a stream like usb or telnet, but there does seem to be an issue where it only works with a known filesize (if you dig up the other tread from not too long ago).
            but given that the parser is meant to ignore anything after a ; you'd need to find a way to escape the ;
            woraround may be to use echo or M118 to telnet, uart or usb which if not in use will have no effect other than being human readable in the file?
              thats expected, as config.g is the default filename if not specified with the P"filename" parameter.
              • Kolbiundefined
                Kolbi
                Ah!!!!! The 'P' - I forgot the 'P'
                It works! Used the following:
                  M559 P"0:/macros/test"                                           ; Begin writing to SD card file
                And it made the file:
                  A Former User
                  thats interesting, seemed to not work with M29 from USB.
                  which version of RRF you on?
                  • Kolbiundefined
                    @bearer Running 3.1.1
                    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
                    But also, I'm not running from USB. Running a macro, to make another macro.
                    • Kolbiundefined
                      Kolbi
                      Top post edited with BLUF.
