dual extruder setup
@dc42 I redid it with duet 3 this morning and selected the standalone mode. fixed the thermistor value. the diag led light stays flashing, the panel due will stay on the "connecting" mode unless i swap the in/pins like i mentioned in my previous comment.
with out all the motors and what not selected the hot ends should still show up as if they are there and the connecting should switch to busy or ready? -
@Phaedrux yup- i redid it this morning already- see my response to DC
Update your firmware first off.
Upload this zip file as is to the /sys folder in DWC
https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zipThe diag light will pulse steadily in normal use.
The paneldue should say idle when it is connected and ready to go. You will need
M575 P1 S1 B57600
in your config.g to enable support for PanelDue in recent firmwares.Post your new config.g.
@Phaedrux Do i have to be using web control for this with standalone? Right now it's not an option due to no ports- I'm at work. I could find a longer cord and go to the next room if need be.
if not do i just unzip that folder into the SD Card into that same directory? -
@Phaedrux
New config file. it just reads busy and the temp boxes for the extruder are gone unless i switch the two io pins. then they come back but it sits on connecting
; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Aug 04 2020 13:08:09 GMT-0500 (Central Daylight Time); General preferences
M550 P"My Printer" ; set printer name; Network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0.4 S1 ; physical drive 0.4 goes forwards
M584 X0.0 Y0.1 Z0.2 E0.3:0.4 ; set drive mapping
M92 X80.00 Y80.00 Z400.00 E420.00:420.00 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X900 Y900 Z200 S0 ; set axis maxima; Endstops
M574 X1 S1 P"io0.in" ; configure active-high endstop for low end on X via pin io0.in
M574 Y1 S1 P"io1.in" ; configure active-high endstop for low end on Y via pin io1.in
M574 Z1 S1 P"io2.in" ; configure active-high endstop for low end on Z via pin io2.in; Z-Probe
M558 P5 C"^io3.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
M308 S1 P"temp1" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin temp1
M308 S2 P"temp2" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 2 as thermistor on pin temp2
M950 H2 C"out2" T2 ; create nozzle heater output on out2 and map it to sensor 2
M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency
M106 P0 S1 H1 T45 ; set fan 0 value. Thermostatic control is turned on
M950 F1 C"out4" Q500 ; create fan 1 on pin out4 and set its frequency
M106 P1 S1 H2 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
M563 P0 S"Head 1" D0 H1 F0 ; define tool 0
M563 P1 S"head 2" D1 H2 F0 ; define tool 1
G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C; Custom settings are not defined
M575 P1 S1 B57600 ; enable support for PanelDue -
@kaduhn1 said in dual extruder setup:
Yes.
You could do the manual firmware update process if you only have access to the board via USB terminal. Extract the zip file, copy just the firmware bin file to the SD card in the /sys folder. Connect via USB and send M997 S0.
https://duet3d.dozuki.com/Wiki/Gcode#Section_M997_Perform_in_application_firmware_update
For the DWC files, download this zip file and extract it to the /www folder
https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/DuetWebControl-SD-3.1.1.zip
Once you are updated, send M115 to confirm and then try sending M98 P"config.g" and report any errors.
@Phaedrux i downloaded that zip folder and unzipped it and they're mostly .gz f files and nothing named firmware.bin or similar.
Should i be downloading this firmware bin from DC's github?https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet3Firmware_MB6HC.bin
@Phaedrux
ok so i unzipped that same file again and now a bunch of .bin files are showing up. I'll copy the duet 3 mb6hc to the sys folder and do the m997 etc -
@Phaedrux copied the Duet3Firmware_MB6HC.bin into the SYS folder, did the M997 S0 and its give me this error
Error: M997: Firmware binary "Duet3Firmware_MB6HC.bin" not found<LF>ok<LF> -
It would be substantially easier if we had network access to DWC.
yeah I'll have to get IT involved for that though. Why do i need to update the firmware for a brand new board though? Shouldn't it still work.
I do have a Ethernet to USB connector for a PLC but that was a pain to figure too. probably not worth the hassle. -
There have been many improvements and fixes for RRF3 between the release candidates. Version 3.1.1 is the latest nad has been proven to be quite stable. So it's strongly recommended to update just to eliminate any potential problems that have already been fixed.
Just in case there was something wrong with the file, try downloading this one
Compare the size. It should be 557 KB. Make sure it is within the /sys folder.
Also, just to make sure you have all the other required files present, download these from the 3.0 release and place them in the /sys folder as well.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet3iap_sd_MB6HC.bin
https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet3iap_spi_MB6HC.bin
https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet3_SDiap_MB6HC.bin
When you have all those files in place in /sys try M997 S0 again.
Otherwise your new config looks alright. I'm not sure of your hardware so I can't say if it's all correct or not, but you should be able to do some commissioning testing.
Going to get IT to hook it up to the network and go form there.
@Phaedrux Good news- after much formatting and getting the card to read and what not it's finally working on dwc. both hot end showing up, sits at idle.
followed the update firmware from the settings menu and selected the file you posted and i still getM997 S0
I tried putting all 3 of those files in the /sys folder too and put it back in the board and same thing.
I may just leave it until i get the rest of the printer built and hooked up and see how it runs? -
Now that you're on the network and have access to DWC you can try the simpler firmware update method.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zipThat should prompt a firmware update and reboot.
@Phaedrux Still saying firmware binary Duet3firmware_MB6HC.bin not found. but it's right there in the folder
Strange. Let's try installing the 3.0 release via the zip file first to ensure all the correct files in place, and then installing the 3.1.1 release.
Download this zip file and then upload it as is to the /sys folder via DWC.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zipThen do the same with the 3.1.1 zip file after it reboots.
If that still does not work, you may need to flash the firmware using USB connection and bossa.
@Phaedrux I'll try that next week- wasn't in this week after a big storm came through.
