Z-probe idea
Like this?
M558 P4 X0 Y0 Z0 H5 F120 T6000 I1
Yes.
On my other machine I installed the Mini IR sensor and got it working last night ran a print and worked flawlessly. Go to do another print today and the probe will not stop once it is triggered and keeps going down for about another 3-5mm before moving back up and going to the next spot. Each location does the same thing.
Here is what I was using.. no changes from last night.
M558 P1 X0 Y0 Z0 H5 F120 T6000 I1
G31 P600 X0 Y-19.5 Z1.497Edit.
In the sensor box for the Z-Probe it has 1000 when it is not triggered. Not sure if it was like that last night or not. -
If it's David's mini IR probe, you should be using P500, not 600.
Ahh your right. Not sure what happened there. Even still I set that to 500 and when I do G30 S-1 it says Error: Z probe already triggered at start of probing move. z-probe still says 1000 in machine status. Thought there might be some IR interference like it says on the how to page so I turned off all the lights and darkened the windows. Still says 1000 at about 15mm above the bed.
Does the led on the sensor flash 4 times at startup, and after that turn on when the sensor is triggered and off when it is not?
If yes then the OUT wire from the sensor is not properly connected to the input pin on the Z probe connector.
Yes it flashes 4 times and then goes off. When the probe gets close to the bed the light comes on but just keeps going. I have it running a print at the moment but will check the wires again. Perhaps the terminal is not secure on the wire.
If you post photos of how both ends of the Z probe cable are connected, I can check your wiring.
Checked the wire connectors for continuity to each end and all is good.
Update: So just for the heck of it I decided to remove the I1 from the M558 command and now it is working.
What I am using.
; Z Probe
M558 P1 X0 Y0 Z0 H5 F120 T6000 ; Set Z probe type to switch, the axes for which it is used and the probe + travel speeds
G31 P500 X0 Y-19.5 Z1.497 ; Set Z probe trigger value, offset and trigger height
