BLTouch wiring on Duet3 power down SBC
thats odd; the problem is very unlikely to be the black or the blue wire - if you disconnect the others I'm pretty sure you'll be fine (but obviously it won't work).
I'd start with blue+black and add red, yellow and white one by one in that order to see which one causes the issue, but admittedly its correctly wired according to the docs (preferably not making any connections live)
bltouch looks genuine, but feel free to confirm
and maybe some more pictures of the wiring, i suspect there is at least one extension wire along there somewhere?
Just verified the cables from end to end with a multimeter and they are fine. Connected Black and Blue to IO7_GND and verified that the SBC is working when connecting the other single cables. It turned out that the "problem" is the Red VCC cable. As soon as this one is connected the SBC is no longer booting.
Oh man....and yes, it's a genuine BLTouch. For pictures of the wiring it's too late. All cables are already nicely packaged
Maybe that was not so wise but I'm sure that the cables are fine from end to end.
Hm, what sort of resistance do you get if you measure from the black/blue pin and to the red pin of the bltouch (when not connected to the Duet)?
(mine has about 130k from red to both black/brown)unfortunately it seems like the sensor has an internal short in its supply
Red to Black
Red to Blue
I guess that does not look so good, right? The BLTouch worked fine a few days ago. I just moved it from an old to the new printer.
Hm, mega ohms shouldn't be a problem, but it is odd that its vastly different from mine but I suppose they could be different models. Mines been sat on a shelf for a bit, new in its box until today
It says "Smart v3.0.
Anyways, whats the value between the black and blue wire? Seems odd they should be so different unless there is a non 0 value there.
It's about 0.8 mega ohms.
That doesn't sound right, but can't say I'm too familiar with the internals and potential variation between versions.
At the end of the day two options, its damaged or wired wrong, as you seem confident the wirng is ok, I'd maybe try it back on the old printer to verify it still works (or confirm its been damaged somehow)
I have one on my workhorse which is definitely working (at least 1 hour ago
). Will try this one.
In am not knowledgable on Duet3, but could this have anything to do with 5v / 3v logic settings? (M280 Px 140/150)
I would think they should still have a common ground between the two ground pins on the bltouch.
My other BLTouch is working os it seems to be broken. Better buying a new one than investigating again for days
Thanks for your help!
