    Duet Wifi V2 Upgrade to 3.1.1 - Wifi not working
    Firmware installation
    291
      Did you also update the wifi server firmware to 1.23? Might need a USB terminal to get a M122 result to check the version.
      You can try reflashing the wifi server as well.
      What do you have in your config.g?
      Dataro81undefined 2 Replies Last reply Reply Quote 0
      • Dataro81undefined
        Dataro81
        Tried M997 S0:1:2 to update all firmwares
        M122 command
        Tried M552 S-1, M552 S1, then M552. Just keeps showing "WiFi module is being started
        config.g (If you see any other issues, please let me know)
        ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Aug 10 2020 22:27:49 GMT-0600 (Mountain Daylight Time)
        M550 P"Kossel" ; set printer name
        M665 R220 L385 B130 H140 ; Set delta radius, diagonal rod length, printable radius and homed height
        M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
        M552 S1 ; enable network
        M586 P0 S1 ; enable HTTP
        M586 P1 S0 ; disable FTP
        M586 P2 S0 ; disable Telnet
        M92 X80.00 Y80.00 Z80.00 E663.00 ; set steps per mm
        M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
        M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
        M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
        M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
        M84 S30 ; Set idle timeout
        M208 Z0 S1 ; set minimum Z
        M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
        M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
        M574 Z2 S1 P"zstop" ; configure Z-probe endstop for low end on Z
        M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
        M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
        M557 R85 S20 ; define mesh grid
        • Dataro81undefined
          Dataro81 @Phaedrux
          @Phaedrux I flashed with wifi server firmware associated with 3.1.1. Not sure what version it is and looking at M122 output doesn't tell me the version
          • Dataro81undefined
            Dataro81 @Phaedrux
            @Phaedrux Wifi server was working prior to the upgrade so not sure what happened
              Phaedrux Moderator @Dataro81
              @Dataro81 said in Duet Wifi V2 Upgrade to 3.1.1 - Wifi not working:
              It's at the bottom in the wifi section, but if it says wifi disabled, it may not show anything else.
              When you flashed DuetWiFiServer.bin from the 3.1.1 zip file, did it give any indication that it flashed successfully?
              Dataro81undefined 3 Replies Last reply Reply Quote 0
              • Dataro81undefined
                Dataro81 @Phaedrux
                @Phaedrux Yeap, let me run M997 S0:1:2 again and attach what i see
                • Dataro81undefined
                  Dataro81 @Phaedrux
                  @Phaedrux Do you know what the syntax is to just update the webserver firmware?
                  • Dataro81undefined
                    Dataro81 @Phaedrux
                    @Phaedrux nm found the info. M997 S1
                      M997 S1 will do wifi server only
                      https://duet3d.dozuki.com/Wiki/Gcode#Section_M997_Perform_in_application_firmware_update
                      Dataro81undefined 1 Reply Last reply Reply Quote 0
                      • Dataro81undefined
                        Dataro81 @Phaedrux
                        @Phaedrux Thanks! Updating the webserver firmware singularly fixed the issue!
                          Glad that worked.
