    Extruder fan permanently spinning
    Firmware installation
    210
    • StevePS3undefined
      StevePS3
      Can someone help, my extruded fan (not part fan) just spins all the time despite the fact that it should be controlled by the thermostat. No doubt there is something amiss with my config.
      Here it is
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Aug 12 2020 12:40:08 GMT+0100 (British Summer Time)
      M550 P"CoreXY" ; set printer name
      M669 K1 ; select CoreXY mode
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P2 S0 ; physical drive 2 goes backwards
      M584 X1 Y0 Z2 E3 ; set drive mapping
      M92 X100.00 Y100.00 Z400.00 E420.00 ; set steps per mm
      M203 X18000.00 Y18000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
      M906 X700 Y700 Z600 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X280 Y280 Z300 S0 ; set axis maxima
      M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
      M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H3 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
      M106 P1 S0 H1 T45 ; set fan 1 value. Thermostatic control is turned on
      M563 P0 D0 H1 F0:1 ; define tool 0
      • StevePS3undefined
        StevePS3
        If I swap the fan from "fan1" to "fan2" then it works as expected. It seems that "fan1" is permanently outputting 24v no matter what I do to it.
          droftarts administrators @StevePS3
          @StevePS3 It could be that the fan1 Mosfet has failed open. Can you take a good, high resolution picture of your Duet, of the area around the fan1 connection? Looking for failed components.
          • StevePS3undefined
            StevePS3
            I've tried to but I keep getting "Something went wrong whilst processing server response"
            • StevePS3undefined
              StevePS3
              https://1drv.ms/u/s!At_9PCgHtKl3nnqmzL4cfrI6LOmi
                @StevePS3 said in Extruder fan permanently spinning:
                What browser are you using? I think this happens sometimes with Chrome.
                I can't see anything obviously wrong with the MOSFET.
                StevePS3undefined 1 Reply Last reply Reply Quote 0
                • StevePS3undefined
                  StevePS3 @droftarts
                  Ahh yes, Chrome.
                  No, they looked OK to me.
                    Phaedrux Moderator @StevePS3
                    Where do you have your fans actually connected?
                    Your tool has defined fan0 and fan1 as the tool fan. If fan1 is the hotend heatsink fan, then you don't want fan1 assigned to the tool as well.
                    Change M563 P0 D0 H1 F0:1 to be M563 P0 D0 H1 F0
