    "DCS is not started" error - Duet3
    Duet Web Control
    1.1k
      T3P3Tony administrators @Neufra
      @Neufra said in "DCS is not started" error - Duet3:
      The "diag"-LED is constantly on! (but only very dimm/weak)!
      This is not right. What do you have plugged in to the Duet? Try with nothing plugged (including the Pi) and jsut powered with USB.
      • Neufraundefined
        Neufra
        The Diag-LED is still always dimm. I tried with and without the SD card, Plugged into the PC or a Phonecharger... no change
          @Neufra with 5V USB power applied put a jumper on the Erase jumper, then take it back off and power cycle the board. It should not now show up as a BOSSA programming port. you then need to re flash the firmware on the board (use v3.1.1 from the github release).
          https://github.com/Duet3D/RepRapFirmware/releases
          After that it should then show up as a Duet 3 and the diag light should be flashing.
          Carloundefined 1 Reply Last reply Reply Quote 0
          • Carloundefined
            Carlo @T3P3Tony
            @T3P3Tony
            I get the same error on both 2 and 3 duets unless I use a specific micro usb cable which I have now set aside for just using on duet boards but with that cable connects 1st time ..may be of help?
            • Neufraundefined
              Neufra
              I just tried many different things, including different cables, but I just can´t get a conection to the board.. I mean, BOSSA and SAM-BA show the serial port, but I get the same error massages as befor (the pictures further up).
              Is there something im just forgetting about?
              • Carloundefined
                Carlo @Neufra
                @Neufra
                Is the board still in the enclosure or on the bench ...best have it on the bench nothing connected but usb honestly I have 10s of cables only 1 that works dunno why.. the others work with everything else I try them with.
                • Neufraundefined
                  Neufra
                  the board is on my desk.
                  Nothing except for the USB-cable, and the SD card is plugged in.
                  The cable i´m currently using was included with my duet 2...
                  I´ll try all of my other cables, maybe one of them works...
                  • Carloundefined
                    Carlo @Neufra
                    @Neufra
                    Take the card out you dont need it in to flash the firmware
                    • Neufraundefined
                      Neufra
                      I took it out now. It didn´t change much.
                      (and I´m still swapping cable around 👍 )
                      @T3P3Tony said in "DCS is not started" error - Duet3:
                      But it does, why´s that?
                      • Neufraundefined
                        Neufra
                        Good News:
                        it turned out, that the USB port I used was the Problem.
                        After trying all of my micro-USB cables, I thougt: "okay let´s just try a diffrent USB-port!".
                        Now the diag-LED is blinking as it shoud!
                        Thanks for your help so far!
                        What should I do now, in order not to "break" it again?
                        Carloundefined 1 Reply Last reply Reply Quote 1
                        • Carloundefined
                          Carlo @Neufra
                          @Neufra
                          You updated the firmware ? go to the online rep rap configuration tool and build your configs
                          • Neufraundefined
                            Neufra
                            I don´t know what I originaly did... I messed something up, and than nothing worked anymore 😞 !
                            I´ll make my configs now.
                            • Carloundefined
                              Carlo @Neufra
                              @Neufra
                              Follow the documentation and take your time make sure its all wired correctly following that documentation.
                              • Neufraundefined
                                Neufra
                                Everything on the softwareside works perfectly now!
                                Thanks everyone for your help! 😁
                                  BTW I found out yesterday that "DCS is not started" is a misleading message. I also get it if DCS is unable to communicate with the Duet.
                                    A Former User @Neufra
                                    fatal: unable to access 'https://github.com/shumatech/BOSSA/': Could not resolve host: github.com
                                    thats odd, your Pi managed to resolve pastebin.com but not github.com - sounds like have some gremlins on your network. but it is good feedback to improve the scritpt:)
                                    /dev/ttyACM0 not found******
                                    just out of curiosity, was this with the same usb cable you succeeded with in the end?
                                    I didn´t use version 3.0 first...
                                    when you get a new duet with a pre 3.0 it will break compatibility with dsf without either manually updating to 3.0 before using apt upgrade, or use bossa or sam-ba after apt upgrades to 3.1.1. shame this isn't highlighted better.
                                    too bad about the series of unfortunate events sort of speak, but glad you got it sorted in the end 👍
                                    Neufraundefined 1 Reply Last reply Reply Quote 0
                                    • Neufraundefined
                                      Neufra @A Former User
                                      @bearer said in "DCS is not started" error - Duet3:
                                      no, I belive that was a different cable and the "non working USB-port".
                                      (It worked when I used a different USB - port. At first I used the port on the backside of my Keyboard (I use a "Corsair K70 LUX"), that woked with the duet2, but not with the 3! In the end, I plugged the duet directly into the front of my PC and using the included cable from the duet2!)
                                      I didn´t kwon that unfortunately...
                                      But now everything works, and I have some more knowlage for next time 👍 😀
                                      Thanks again for your help!
