    V 3.1.1 home command no OK response
    • zudyundefined
      zudy
      When using command G28 or G28 and axes (G28 X/Y/Z) there is no response from duet 3D 'ok message'. Command was done fyzically successful. Same problem was in beta versions until 3.1.0. Version 3.1.0 is correctly responding with "ok message" and after upgrade by RPi to version 3.1.1 by command sudo apt-get update & sudo apt-get upgrade the same problem appeared again. The machine is now downgraded to 3.1.0.
      Re: Software bundle 3.1.1 now available
      Re: https://github.com/Duet3D/RepRapFirmware/issues/409
      zudy created this issue in Duet3D/RepRapFirmware
      closed no 'OK' response when G28 command is used. Firmware 3.1.1 #409
        A Former User
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M555_Set_compatibility
        might be what you're looking for?
        • zudyundefined
          zudy
          Thank you @bearer for tip. But when I updated to 3.1.1 and tried all posibilities about M555 no mode response ok to G28. In version firmware 3.1.0 I set M555 P2 and G28 response ok after finished homing. In version 3.1.1 not 😞 . Do you know, if there something else to try? I am litle bit confused about only "my" problem? Because our software wait to OK response when homing is trigered. Other command work well and response ok status.
            Reported to DC42 to take a look.
