    Delta: temporarily lift work envelope restriction
    • vwegertundefined
      vwegert
      I have a Delta printer driven using a Duet Wifi. I would like to add a "waste bucket" next to the printing surface with a silicone wiper to clean the nozzle. I have some space left there, but the firmware will not let the nozzle leave the circular work area. Is there a way to (temporarily) disable this restriction?
      Baenwortundefined 1 Reply Last reply Reply Quote 0
      • Vetiundefined
        Veti
        set the R value of M665 to a higher value and set it back afterwards. Maybe B as well.
        another solution would be to mount the wiper on a servo and move the wiper in using the server.
        • Baenwortundefined
          Baenwort @vwegert
          @vwegert the B value controllable the work area radius. It acts as a safety but otherwise doesn't affect anything but how far out the platform can move.
          I wouldn't adjust the R value as that affects the G32 calibration.
            M564 S0 should do what you want.
            vwegertundefined 1 Reply Last reply Reply Quote 1
            • vwegertundefined
              vwegert @dc42
              @dc42 said in Delta: temporarily lift work envelope restriction:
              It does, thank you very much
