Smart effector Warranty check e3d
my magball arms arrived yesterday so iwanted to build in the smart effector into my anycubic predator but i realized while reading the documantation that threre is a place with no copper the line gone off its a line from the left pin of temp (just the connector) to the board look on picture pls it arrived so and i ddint start to build so everyting else is still packed
what should i do is it a warranty case?
and will it worked with this missing copperline? -
Looks like that trace has broken when the board was separated from the panel
The trace is for the therm4 wire so its only used if you are using a 4 wire PT100 (which no one makes AFAIK) If you are not using a PT100 in 4 wire mode it will work fine.
thx for fast reply so i want to go with a pt100 so its fine but will it get worse?
A 2 wire PT100 can still be adapted into a 4 wire PT100, so there should be no downside or deterioration.
https://duet3d.dozuki.com/Wiki/Connecting_PT100_temperature_sensors
https://duet3d.dozuki.com/Wiki/PT100_temperature_sensor_daughter_board
