Unsolved Build troubles - 3.02 for DuetWifi
All builds of RRF3 are RTOS builds so I dropped the RTOS from the configuration name.
I haven't yet tested that latest Duet 2 build. I will do that today.
@smoki3 said in Build troubles - 3.02 for DuetWifi:
RepRapFirmware: Duet2_RTOS is not availiable anymore.
indeed, seems to have chagned to just Duet2 after git pull on the 3.02 branch
@bearer said in Build troubles - 3.02 for DuetWifi:
Yes I saw the commit on git. But not able to get the build to boot on duet2. Lets see if dc42 can figure out more detailed
It boots for me on a Duet WiFi. I have still to test it on Duet Ethernet.
@dc42 hmm wired. I there are special commands needed in the config.g?
UPDATE:
A screen /dev/tty.usbmodem1411 115200RepRapFirmware for Duet 2 WiFi/Ethernet Version 3.2-beta dated 2020-08-31b1 Executing config.g...HTTP is enabled on port 80 FTP is disabled
Okay looks like its not booting with my config:
; General preferences G90 ; Send absolute coordinates M83 ; relative extruder moves ;Panel Due M575 P1 S1 B57600 ; Network M550 P"ToolChanger" ; Set machine name M552 S1 ; Enable network M586 P0 S1 ; Enable HTTP M586 P1 S0 ; Disable FTP M586 P2 S0 ; Disable Telnet ; Drives M584 X7 Y8 Z0 E5:6:2:1 U9 V4 W3 ; Map Drives to Axis M669 K1 ; Select CoreXY mode M569 P0 S0 ; Drive 0 goes forwards M569 P1 S0 ; Drive 1 goes forwards M569 P2 S0 ; Drive 2 goes forwards M569 P3 S1 ; Drive 3 goes forwards M569 P4 S1 ; Drive 4 goes forwards M569 P5 S0 ; Drive 5 goes forwards M569 P6 S1 ; Drive 6 goes forwards M569 P7 S0 ; Drive 7 goes forwards M569 P8 S0 ; Drive 8 goes forwards M569 P9 S0 ; Drive 9 goes forwards M350 X16 Y16 Z16 E16:16:16:16 V16 W16 I1 ; Configure microstepping with interpolation M350 U8 I0 ; Configure microstepping without interpolation M92 X100 Y100 Z1600 U100 V400 W400 E409:427:427:427 ; Set steps per mm M566 X600 Y600 Z35 U2 V8 W8 E800:800:800:800 ; Set maximum instantaneous speed changes (mm/min) M203 X35000 Y35000 Z1200 U5000 V1200 W2400 E5000:5000:5000:5000 ; Set maximum speeds (mm/min) M201 X6000 Y6000 Z400 U500 V400 W400 E2500:2500:2500:2500 ; Set accelerations (mm/s^2) M906 X1650 Y1650 Z1100 U400 V1000 W1000 E1000:1000:1000:1450 I30 ; Set motor currents (mA) and motor idle factor in per cent M84 S120 ; Set idle timeout ; Axis Limits M208 X-35 Y-49 Z0 U0 V0 W0 S1 ; Set axis minima M208 X328.5 Y243 Z300 U500 V34 W34 S0 ; Set axis maxima ; Thermal Sensors M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; Set thermistor + ADC parameters for heater 0 M308 S1 P"duex.e2temp" Y"thermistor" T100000 B4725 C7.060000e-8 ; Set thermistor + ADC parameters for heater 1 M308 S2 P"e0temp" Y"thermistor" T100000 B4725 C7.060000e-8 ; Set thermistor + ADC parameters for heater 2 M308 S3 P"duex.e3temp" Y"thermistor" T100000 B4725 C7.060000e-8 ; Set thermistor + ADC parameters for heater 3 M308 S4 P"duex.e4temp" Y"thermistor" T100000 B4725 C7.060000e-8 ; Set thermistor + ADC parameters for heater 4 ; Hardware M950 H0 C"bedheat" T0 ; Bed Heater M950 H1 C"duex.e2heat" T1 ; Tool 0 Heater M950 H2 C"e0heat" T2 ; Tool 1 Heater M950 H3 C"duex.e3heat" T3 ; Tool 2 Heater M950 H4 C"duex.e4heat" T4 ; Tool 3 Heater M950 F0 C"fan0" ; Tool 1 PCF M950 F1 C"fan1" ; Tool 1 HEF M950 F3 C"duex.fan3" ; Tool 0 PCF M950 F4 C"duex.fan4" ; Tool 0 HEF M950 F5 C"duex.fan5" ; Tool 2 PCF M950 F6 C"duex.fan6" ; Tool 2 HEF M950 F7 C"duex.fan7" ; Tool 3 PCF M950 F8 C"duex.fan8" ; Tool 3 HEF M950 F9 C"duex.e5heat" ; LED ; Max Temp Protection M140 H0 M143 H0 S140 ; Set temperature limit for heater 0 to 140C M143 H1 S275 ; Set temperature limit for heater 1 to 270C M143 H2 S275 ; Set temperature limit for heater 2 to 270C M143 H3 S275 ; Set temperature limit for heater 3 to 270C M143 H4 S275 ; Set temperature limit for heater 4 to 270C ; Fanmapping M106 P3 S0 I0 F500 H-1 C"Tool 0" ; Set fan 3 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P0 S0 I0 F500 H-1 C"Tool 1" ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P5 S0 I0 F500 H-1 C"Tool 2" ; Set fan 5 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P7 S0 I0 F500 H-1 C"Tool 3" ; Set fan 7 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P9 S0 I0 F500 H-1 C"LED" ; Set LED value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P4 S1 I0 F500 H1 T75 ; Set fan 4 value for Tool 0, PWM signal inversion and frequency. Thermostatic control is turned on M106 P1 S1 I0 F500 H2 T75 ; Set fan 1 value for Tool 1, PWM signal inversion and frequency. Thermostatic control is turned on M106 P6 S1 I0 F500 H3 T75 ; Set fan 6 value for Tool 2, PWM signal inversion and frequency. Thermostatic control is turned on M106 P8 S1 I0 F500 H4 T75 ; Set fan 8 value for Tool 4, PWM signal inversion and frequency. Thermostatic control is turned on ; Endstops M915 X Y S5 H350 F0 R0 ; Set Stall detection sensitivity M915 V S2 H350 F0 R0 ; Calibration M915 W S2 H350 F0 R0 ; Cleaner M574 Y1 S3 ; Set endstops controlled by motor load detection M574 X1 S3 ; Set endstops controlled by motor load detection M574 U0 ; Set endstops controlled by motor load detection M574 V1 S3 ; Set endstops controlled by motor load detection M574 W1 S3 ; Set endstops controlled by motor load detection ; Z-Probe M558 K0 P5 C"^!zprobe.in" H3 F180 T25000 ; Z probe connected to Z endstop input G31 K0 X0 Y0 Z0.15 P500 ; Set Z probe offset + naher ran - weiter weg M557 X10:290 Y20:180 S40 ; Define mesh grid ; Tool Probe M558 K1 P8 C"!e0stop" H5 F80 T3000 ; Tool probe connected to Z endstop input G31 K1 X0 Y0 Z0 P500 ; Set Z probe offset + naher ran - weiter weg ; Tools M563 P0 D0 H1 F3 ; Define tool 0, Fan 3 M563 P1 D1 H2 F0 ; Define tool 1, Fan 0 M563 P2 D2 H3 F5 ; Define tool 2, Fan 5 M563 P3 D3 H4 F7 ; Define tool 3, Fan 7 ; PID Settings Tools M307 H1 A595.9 C199.5 D4.5 S1.00 V24.1 B0 ; Set PID settings tool 0 M307 H2 A775.0 C252.4 D8.2 S1.00 V24.1 B0 ; Set PID settings tool 1 M307 H3 A716.5 C237.1 D8.7 S1.00 V24.1 B0 ; Set PID settings tool 2 M307 H4 A567.7 C241.0 D6.7 S0.80 V24.1 B0 ; Set PID settings tool 3 M307 H0 A181.4 C631.5 D4.9 S1.00 V24.1 B0 ; Bed PID Settings ; Tools Temperatures G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C G10 P2 R0 S0 ; Set initial tool 2 active and standby temperatures to 0C G10 P3 R0 S0 ; Set initial tool 3 active and standby temperatures to 0C ; Calibrate MCU Temperature M912 P0 S-8 ; LED M106 P9 S0.5 ; DAA M593 F50 ; Pressure Advance ; M572 D3 S0.5 M572 D0:1:2 S0.05 ; Load config override M501
Is there a new WifiFirmware needed?
I am using new wifi firmware, but last time i tested it, it still worked with the old wifi firmware. Does it boot if you leave wifi disabled in config.g?
I was able to boot it without SD Card and enabled Wifi manually then I insert the SD Card, mounted it with a M21 and loaded my config.g. Now it is up.But as soon I reboot it is in a bootloop
I commented out
;M586 P0 S1 ; Enable HTTP ;M586 P1 S0 ; Disable FTP ;M586 P2 S0 ; Disable Telnet
Now it is booting
@dc42 Thanks. The ctl_access.h problem was from outdated arm tools on my end.
I commented out
Now it is booting
My Duet WiFi is booting even with M586 commands, however I am chasing other issues in 3.2 which may be related.
