    Duet 3 + Tool board extruders out of sync
    Firmware installation
    548
    • evomotorsundefined
      evomotors
      I have two extruder motors configured for for a mixing ratio 1 to 1. One motor connected to tool-board and another to Duet 3 driver 5.
      Motors configured like this:
      M584 X0.0 Y0.1 Z0.2:0.3:0.4 E121.0:0.5             ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                            ; configure microstepping with interpolation
      M92 X160.00 Y160.00 Z800.00 E463                   ; set steps per mm
      M567 P0 E1:1                                       ; extruder motors mixing ratio
      After 16 hours print I noticed that the differences between my extruder motors positions is not acceptable!
      Am I doing something wrong or there Is a bug in the firmware?
      • Vetiundefined
        Veti
        can you post the output of M122
        evomotorsundefined 1 Reply Last reply Reply Quote 0
          Do the extruders have different pressure advance settings?
            evomotors @dc42
            @dc42 said in Duet 3 + Tool board extruders out of sync:
            The same, like this:
            M572 D0:1 S0.074:0.074							   ; pressure advance tuning
              evomotors @Veti
              @Veti said in Duet 3 + Tool board extruders out of sync:
              Won't give you much, new job started already:
              M122
              RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (SBC mode)
              Board ID: 08DJM-956L2-G43S8-6JKDL-3SJ6L-1802G
              Used output buffers: 1 of 40 (11 max)
              Static ram: 154604
              Dynamic ram: 162888 of which 60 recycled
              Exception stack ram used: 528
              Never used ram: 75136
              Tasks: NETWORK(ready,1972) HEAT(blocked,1188) CanReceiv(suspended,3388) CanSender(suspended,1428) CanClock(blocked,1436) TMC(blocked,68) MAIN(running,2672) IDLE(ready,76)
              Owned mutexes:
              Last reset 00:25:35 ago, cause: software
              Last software reset at 2020-09-05 14:05, reason: User, spinning module LinuxInterface, available RAM 75472 bytes (slot 1)
              Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
              Error status: 0
              MCU temperature: min 43.7, current 46.2, max 46.4
              Supply voltage: min 23.8, current 23.8, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
              12V rail voltage: min 12.1, current 12.2, max 12.2, under voltage events: 0
              Driver 0: ok, reads 45092, writes 22 timeouts 0, SG min/max 0/1023
              Driver 1: ok, reads 45092, writes 22 timeouts 0, SG min/max 0/1023
              Driver 2: standstill, reads 45093, writes 22 timeouts 0, SG min/max 0/1023
              Driver 3: standstill, reads 45093, writes 22 timeouts 0, SG min/max 0/1023
              Driver 4: standstill, reads 45094, writes 22 timeouts 0, SG min/max 0/1023
              Driver 5: ok, reads 45094, writes 22 timeouts 0, SG min/max 0/486
              Date/time: 2020-09-05 14:31:10
              Slowest loop: 7.36ms; fastest: 0.14ms
              === Storage ===
              Free file entries: 10
              Hiccups: 0(0), FreeDm: 371, MinFreeDm: 285, MaxWait: 412437ms
              === MainDDARing ===
              Scheduled moves: 10998, completed moves: 10938, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: 3
              === AuxDDARing ===
              Heater 0 is on, I-accum = 0.4
              Heater 1 is on, I-accum = 0.0
              Segments left: 1
              Movement lock held by null
              HTTP* is ready with "M122" in state(s) 0
              Telnet is idle in state(s) 0
              File* is doing "G1 X265.122009 Y213.313995 E2.858500" in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              SBC is idle in state(s) 0
              Daemon* is idle in state(s) 0
              Aux2 is idle in state(s) 0
              Code queue is empty.
              === Network ===
              Slowest loop: 1.09ms; fastest: 0.01ms
              HTTP sessions: 0 of 8
              - Ethernet -
              State: disabled
              Error counts: 0 0 0 0 0
              === CAN ===
              Messages sent 17238, longest wait 3ms for type 6012
              === Linux interface ===
              State: 0, failed transfers: 0
              Last transfer: 25ms ago
              RX/TX seq numbers: 49779/49781
              SPI underruns 0, overruns 0
              Number of disconnects: 0
              Buffer RX/TX: 1680/2952-0
              === Duet Control Server ===
              Duet Control Server v3.1.1
              File:
              Buffered code: G1 X265.122 Y213.314 E2.8585
              Buffered code: G1 X265.125 Y213.314 E2.8586
              Buffered code: G1 X265.355 Y213.305 E2.8659
              Buffered code: G1 X265.503 Y213.300 E2.8706
              Buffered code: G1 X308.992 Y213.300 E4.2447
              Buffered code: G1 X309.007 Y213.301 E4.2452
              Buffered code: G1 X309.111 Y213.310 E4.2485
              Buffered code: G1 X309.220 Y213.336 E4.2520
              Buffered code: G1 X309.225 Y213.338 E4.2522
              Buffered code: G1 X309.243 Y213.346 E4.2528
              Buffered code: G1 X309.323 Y213.380 E4.2555
              Buffered code: G1 X309.412 Y213.436 E4.2589
              Buffered code: G1 X309.420 Y213.444 E4.2592
              Buffered code: G1 X309.561 Y213.585 E4.2656
              Buffered code: G1 X309.564 Y213.588 E4.2657
              Buffered code: G1 X309.578 Y213.611 E4.2665
              Buffered code: G1 X309.616 Y213.670 E4.2687
              Buffered code: G1 X309.619 Y213.675 E4.2689
              Buffered code: G1 X309.670 Y213.803 E4.2733
              Buffered code: G1 X309.678 Y213.837 E4.2744
              Buffered code: G1 X309.682 Y213.853 E4.2749
              Buffered code: G1 X309.690 Y213.888 E4.2760
              Buffered code: G1 X309.698 Y213.984 E4.2791
              Buffered code: G1 X309.700 Y214.008 E4.2798
              Buffered code: G1 X309.700 Y253.992 E5.5432
              Buffered code: G1 X309.698 Y254.016 E5.5440
              Buffered code: G1 X309.690 Y254.112 E5.5470
              Buffered code: G1 X309.682 Y254.147 E5.5482
              Buffered code: G1 X309.678 Y254.163 E5.5487
              Buffered code: G1 X309.670 Y254.197 E5.5498
              Buffered code: G1 X309.619 Y254.326 E5.5542
              Buffered code: G1 X309.615 Y254.331 E5.5544
              ==> 1528 bytes
              Code buffer space: 1184
              Full transfers per second: 32.54
              File /opt/dsf/sd/gcodes/motor_mounts.gcode is selected, processing
                evomotors
                Already see the difference in the new job.
                  deckingman @evomotors
                  @evomotors If you've got multiple extruders then you ought to set the steps per mm for each extruder. Currently you have
                  but it ought to be
                  M92 X160.00 Y160.00 Z800.00 E463:E463
                  The same applies to other commands such as M350 (although that will default to 16x), M566, M203, M201, M906 etc...
                  evomotorsundefined 1 Reply Last reply Reply Quote 2
                    evomotors @deckingman
                    @deckingman said in Duet 3 + Tool board extruders out of sync:
                    but it ought to be
                    Thank you! Doing this seem to work.
                      I am surprised, it's normally the case that if only one E value is provided, it gets duplicated to all extruders. I will check.
                        evomotors @dc42
                        ![0_1599336711016_Capture2.PNG](Uploading 100%) @dc42 said in Duet 3 + Tool board extruders out of sync:
                        Well... it seem to be working now.
                          I have just checked with the latest firmware build, and found that a single M92 E value does get duplicated to all extruders as I expected.
                            evomotors @dc42
                            It must be bug somewhere. It stopped going out of sync when I added these values for E
                            M350 X16 Y16 Z16 E16:16 I1                         ; configure microstepping with interpolation
                            M92 X160.00 Y160.00 Z800.00 E405:405               ; set steps per mm
                            M566 X1000.00 Y1000.00 Z50.00 E3000.00:3000.00         	   ; set maximum instantaneous speed changes (mm/min)
                            M203 X30000.00 Y30000.00 Z2000.00 E180000.00:180000.00       ; set maximum speeds (mm/min)
                            M201 X1800.00 Y1800.00 Z100.00 E2000.00:2000.00            ; set accelerations (mm/s^2)
                            M906 X1600 Y1600 Z1600 E900:1000 I80               ; set motor currents (mA) and motor idle factor in per cent
                              @evomotors I guess to be absolutely sure that it wasn't just a coincidence, you ought to revert the configuration back to how you had it and test again. If the problem rears it's ugly head again and is repeatable, then you have a strong case that there is indeed a bug (which might be related to having one extruder on a tool board and the other on the main board.
                              It's the only way that you'll convince @dc42 to look into it.
                                @deckingman I'm fine with it working with explicit values in config. I'm pretty sure he has lots on other stuff to do.
                                  @evomotors said in Duet 3 + Tool board extruders out of sync:
                                  I understand that but someone else might run into the same problem in the future. So if it is a bug, and if @dc42 can fix it, it will save others from having the same issues that you experienced.
                                  Having said all that, personally I try to make a habit of always explicitly declaring anything which might otherwise have a default value.
                                  evomotorsundefined 1 Reply Last reply Reply Quote 1
                                    @deckingman Good point, I will try later.
