"Bad reply format version." Not sure how to proceed.
@itslikeboo said in "Bad reply format version." Not sure how to proceed.:
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi
your upgrade to 2.05 did not go well. maybe only the wifi firmware got updated
please see
https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmwareand redo the upgrade
Thanks for the reply. I'll give it a go in the morning.
@Veti So I went through the steps of Fallback procedure 1 and replaced the binary files by wasn't able to issue a M997 S0 command to install the firmware.
>>> M997 S0 SENDING:M997 S0 [ERROR] Can't read from printer (disconnected?) (SerialException): call to ClearCommError failed [ERROR] Can't write to printer (disconnected?) (SerialException): WriteFile failed ([Error 22] The device does not recognize the command.) [ERROR] Can't write to printer (disconnected?) (SerialException): WriteFile failed ([Error 22] The device does not recognize the command.) [ERROR] Can't write to printer (disconnected?) (SerialException): WriteFile failed ([Error 22] The device does not recognize the command.) [ERROR] Can't write to printer (disconnected?) (SerialException): WriteFile failed ([Error 22] The device does not recognize the command.) [ERROR] Disconnecting after 4 failed writes. Disconnected. Continued anyway with an M115 and confirms 2.05
SENDING:M115 FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-02-09b1 So I ran an M997 S1 to install the WiFi module firmware:
Upload successful
However I still get "Bad reply format version"
WiFi reported error: no known networks found WiFi module is idle >>> M587 SENDING:M587 M587: Failed to retrieve network list Error retrieving WiFi status message: bad reply format version [ERROR] Error retrieving WiFi status message: bad reply format version WiFi module is idle WiFi reported error: no known networks found >>> M587 S"SSID" P"password" SENDING:M587 S"SSID" P"password" M587: Failed to add SSID to remembered list Error retrieving WiFi status message: bad reply format version [ERROR] Error retrieving WiFi status message: bad reply format version WiFi module is idle WiFi reported error: no known networks found And a new M122:
SENDING:M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later Board ID: 08DLM-996RU-N8PS4-7J1FG-3S86S-TBABP Used output buffers: 1 of 24 (1 max) === RTOS === Static ram: 25712 Dynamic ram: 92584 of which 416 recycled Exception stack ram used: 288 Never used ram: 12072 Tasks: NETWORK(ready,540) HEAT(blocked,1232) MAIN(running,3824) IDLE(ready,160) Owned mutexes: === Platform === Last reset 00:04:00 ago, cause: software Last software reset details not available Error status: 0 [ERROR] Error status: 0 Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest block write time: 0.0ms, max retries 0 MCU temperature: min 36.4, current 37.8, max 38.2 Supply voltage: min 0.6, current 1.6, max 1.7, under voltage events: 0, over voltage events: 0, power good: no Driver 0: ok, SG min/max not available Driver 1: ok, SG min/max not available Driver 2: ok, SG min/max not available Driver 3: ok, SG min/max not available Driver 4: ok, SG min/max not available Date/time: 1970-01-01 00:00:00 Cache data hit count 449667858 Slowest loop: 200.82ms; fastest: 0.05ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Move === Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms Bed compensation in use: none, comp offset 0.000 === DDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 === GCodes === Segments left: 0 Stack records: 1 allocated, 0 in use Movement lock held by null http is idle in state(s) 0 telnet is idle in state(s) 0 file is idle in state(s) 0 serial is ready with "M122" in state(s) 0 aux is idle in state(s) 0 daemon is idle in state(s) 0 queue is idle in state(s) 0 autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 1293.11ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0) HTTP sessions: 0 of 8 - WiFi - Network state is changing mode WiFi module is idle Failed messages: pending 0, notready 0, noresp 2 Failed to get WiFi status Socket states: 0 0 0 0 0 0 0 0 Error retrieving WiFi status message: bad reply format version [ERROR] Error retrieving WiFi status message: bad reply format version -
make sure that you are actually uploading the wifi firmware that comes with the 2.0.5.1 release
just to make sure just place the DuetWiFiServer firmware on the sd card again and upload againmake sure its named DuetWiFiServer.bin
@Veti Just wanted to thank you for helping walk me through this.
I grabbed the Duet2Firmware-2.05.1.zip file from https://github.com/Duet3D/RepRapFirmware/releases/tag/2.05.1
Copied the:
Duet2CombinedFirmware.bin
DuetWiFiServer.bin
iap4e.bininto the sys directory on the sd card and replaced it into the board. Hooked up and connected to pronterface with the same messages in the console unfortunately.
now run M997 S1 again
@Veti same as before
>>> M997 S1 SENDING:M997 S1 WiFi reported error: no known networks found WiFi module is idle Trying to connect at 230400 baud: success Erasing 4096 bytes... Erasing 212992 bytes... Uploading file... 5% complete 10% complete 15% complete 20% complete 25% complete 30% complete 35% complete 40% complete 45% complete 50% complete 55% complete 60% complete 65% complete 70% complete 75% complete 80% complete 85% complete 90% complete 95% complete Upload successful WiFi module started ok T0:27.7 /0.0 B:27.1 /0.0 WiFi reported error: no known networks found WiFi module is idle WiFi reported error: no known networks found WiFi module is idle WiFi reported error: no known networks found WiFi module is idle >>> M587 SENDING:M587 M587: Failed to retrieve network list Error retrieving WiFi status message: bad reply format version [ERROR] Error retrieving WiFi status message: bad reply format version WiFi module is idle WiFi reported error: no known networks found WiFi module is idle WiFi reported error: no known networks found I''m still not convinced this isn't pure user error on my end, I just don't know how to diagnose it.
I did it once more and when I gave the M587 command, it displayed the network. But then when I gave it again, back to the error.
SENDING:M587 Remembered networks: "SSID"=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0 WiFi reported error: no known networks found WiFi module is idle WiFi reported error: no known networks found WiFi module is idle WiFi reported error: no known networks found WiFi module is idle >>> M587 SENDING:M587 M587: Failed to retrieve network list Error retrieving WiFi status message: bad reply format version [ERROR] Error retrieving WiFi status message: bad reply format version WiFi module is idle WiFi reported error: no known networks found WiFi module is idle >>> M587 SENDING:M587 M587: Failed to retrieve network list Error retrieving WiFi status message: bad reply format version [ERROR] Error retrieving WiFi status message: bad reply format version -
configure your network again
M552 S0
M587 S"your ssid" P"your password"
M552 S1 -
>>> M552 S0 SENDING:M552 S0 ok T0:27.4 /0.0 B:27.0 /0.0 ok T0:27.4 /0.0 B:27.0 /0.0 >>> M587 S"the ssid" P"the password" SENDING:M587 S"the ssid" P"the password" ok T0:27.3 /0.0 B:27.0 /0.0 >>> M552 S1 SENDING:M552 S1 WiFi reported error: no known networks found WiFi module is idle WiFi reported error: no known networks found WiFi module is idle ok T0:27.3 /0.0 B:27.0 /0.0 Looks like it goes in and out or something.
just to make sure that its not a problem with the remembered networks
send
M588 S"*"and do
M552 S0
M552 S1
again.also does your network or password contain any special characters?
M588 gives:
>>> M588 S"*" SENDING:M588 S"*" M588: Failed to reset the WiFi module to factory settings Error retrieving WiFi status message: bad reply format version [ERROR] Error retrieving WiFi status message: bad reply format version WiFi module is idle WiFi reported error: no known networks found Network name contains a hyphen and underscore.
can you temporarily make your wifi network unencrypted and try again?
I don't think I'll be able to do that, at least for a little bit. There are some people on the network.
I'm not sure why the wifi module won't reset. That command has worked before. When I connect to pronterface and get
"ok T0:26.7 /0.0 B:26.7 /0.0"
every now and then before jumping back to
"WiFi reported error: no known networks found
WiFi module is idle"does this indicate a hardware problem?
I'm not sure if it's related but this version of the board has the external antenna. Also if it's of any help, when I first configured the board for RepRapFirmware 3, I couldn't get the DIAG pin to turn off. Not sure if it's relevant. -
that is just temperature status.
there is a problem with the wifi has problems connecting to modern routers
https://forum.duet3d.com/topic/18423/the-problem-of-connecting-duetwifi-to-modern-routers/21?_=1599414409200 -
Interesting. Well that would suck. I'll try to look into it. Maybe late tonight I'll mess with the network. But wouldn't an M588 S"*" command still work? I've never even connected to the network once.
it sometimes helps to reset the wifi module with
M552 S-1 M552 S0
beforeM558
and beforeM557
@bearer Ok, thanks, I'll give it a try
@bearer Awesome, well that seemed to do something.
>>> M552 S-1 SENDING:M552 S-1 WiFi module stopped ok T0:25.1 /0.0 B:25.8 /0.0 >>> M552 S0 SENDING:M552 S0 WiFi module started ok T0:25.1 /0.0 B:25.8 /0.0 >>> M588 S"*" SENDING:M588 S"*" ok T0:25.0 /0.0 B:25.8 /0.0 >>> M587 S"ssid" P"password" SENDING:M587 S"ssid" P"password" ok T0:25.0 /0.0 B:25.8 /0.0 I've been here for so long, I'm not sure what to do now.
M552 S1
should turn on wifi and you should be good?(
M552 S1
is all you need in config.g as well)
