    Duet 3 + Tool board stops mid-print and reports 100% complete
    Firmware installation
    • evomotorsundefined
      evomotors
      9/6/2020, 4:14:49 PM	M122 B121
      Diagnostics for board 121:
      Board TOOL1LC firmware 3.1.0 (2020-05-15b1)
      Never used RAM 8.5Kb, max stack 584b
      HEAT 1048 CanAsync 1392 CanRecv 1380 TMC 188 AIN 524 MAIN 2308
      Last reset 00:14:50 ago, cause: power up
      Driver 0: standstill, SG min/max 0/20, read errors 0, write errors 0, ifcount 13, reads 49738, writes 13, timeouts 1, DMA errors 0, failedOp 0x80
      Moves scheduled 25, completed 25, hiccups 0
      VIN: 24.2V
      MCU temperature: min 48.6C, current 62.2C, max 62.3C
      Ticks since heat task active 174, ADC conversions started 889143, completed 889142, timed out 0
      Last sensors broadcast 00000002 found 1 177 ticks ago
      Free CAN buffers: 36
      NVM user row b1d088a9 fffff8bb 20002a18 b
      TSENS 001847 GAIN 014ffc OFFS 00273f CAL 1f2a
      9/6/2020, 4:14:32 PM	M122
      RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (SBC mode)
      Board ID: 08DJM-956L2-G43S8-6JKDL-3SJ6L-1802G
      Used output buffers: 1 of 40 (11 max)
      Static ram: 154604
      Dynamic ram: 162928 of which 60 recycled
      Exception stack ram used: 520
      Never used ram: 75104
      Tasks: NETWORK(ready,1972) HEAT(blocked,1188) CanReceiv(suspended,3388) CanSender(suspended,1428) CanClock(blocked,1436) TMC(blocked,68) MAIN(running,2672) IDLE(ready,76)
      Owned mutexes:
      Last reset 00:14:33 ago, cause: power up
      Last software reset at 2020-09-06 20:50, reason: User, spinning module LinuxInterface, available RAM 75624 bytes (slot 1)
      Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
      Error status: 0
      MCU temperature: min 38.0, current 43.6, max 43.7
      Supply voltage: min 23.8, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.1, current 12.2, max 12.3, under voltage events: 0
      Driver 0: standstill, reads 2465, writes 20 timeouts 0, SG min/max 0/420
      Driver 1: standstill, reads 2465, writes 20 timeouts 0, SG min/max 0/1015
      Driver 2: standstill, reads 2466, writes 20 timeouts 0, SG min/max 0/1013
      Driver 3: standstill, reads 2466, writes 20 timeouts 0, SG min/max 0/999
      Driver 4: standstill, reads 2466, writes 20 timeouts 0, SG min/max 0/1005
      Driver 5: standstill, reads 2467, writes 20 timeouts 0, SG min/max 0/492
      Date/time: 2020-09-06 21:14:31
      Slowest loop: 8.49ms; fastest: 0.13ms
      === Storage ===
      Free file entries: 10
      Hiccups: 0(0), FreeDm: 375, MinFreeDm: 367, MaxWait: 416505ms
      === MainDDARing ===
      Scheduled moves: 482, completed moves: 482, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      HTTP* is ready with "M122" in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon* is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 0.83ms; fastest: 0.01ms
      HTTP sessions: 0 of 8
      - Ethernet -
      State: disabled
      Error counts: 0 0 0 0 0
      === CAN ===
      Messages sent 4528, longest wait 3ms for type 6012
      === Linux interface ===
      State: 0, failed transfers: 0
      Last transfer: 23ms ago
      RX/TX seq numbers: 25913/25914
      SPI underruns 0, overruns 0
      Number of disconnects: 1
      Buffer RX/TX: 0/0-0
      === Duet Control Server ===
      Duet Control Server v3.1.1
      File:
      Buffered code: G1 X247.109 Y320.100 E11.7503
      Buffered code: G1 X245.109 Y318.100 E11.8378
      Buffered code: G1 X178.109 Y318.100 E13.9103
      Buffered code: G1 X171.900 Y311.891 E14.1819
      Buffered code: G1 X171.900 Y268.888 E15.5120
      Buffered code: G1 X168.904 Y265.893 E15.6431
      Buffered code: G1 X168.899 Y249.127 E16.1617
      Buffered code: G1 X171.900 Y246.117 E16.2932
      Buffered code: G1 X171.900 Y203.109 E17.6235
      Buffered code: G1 X178.109 Y196.900 E17.8951
      Buffered code: G1 X178.275 Y197.300 F18000
      Buffered code: G92 E0.0000
      Buffered code: G1 X245.275 Y197.300 E2.0724 F1800
      Buffered code: G1 X247.275 Y195.300 E2.1599
      Buffered code: G1 X267.725 Y195.300 E2.7925
      Buffered code: G1 X269.725 Y197.300 E2.8800
      Buffered code: G1 X336.725 Y197.300 E4.9524
      Buffered code: G1 X342.700 Y203.275 E5.2138
      Buffered code: G1 X342.700 Y246.275 E6.5439
      Buffered code: G1 X345.700 Y249.275 E6.6751
      Buffered code: G1 X345.700 Y265.725 E7.1839
      Buffered code: G1 X342.700 Y268.725 E7.3152
      Buffered code: G1 X342.700 Y311.725 E8.6452
      Buffered code: G1 X336.725 Y317.700 E8.9066
      Buffered code: G1 X269.725 Y317.700 E10.9790
      Buffered code: G1 X267.725 Y319.700 E11.0665
      Buffered code: G1 X247.275 Y319.700 E11.6991
      Buffered code: G1 X245.275 Y317.700 E11.7866
      Buffered code: G1 X178.275 Y317.700 E13.8590
      Buffered code: G1 X172.300 Y311.725 E14.1204
      Buffered code: G1 X172.300 Y268.722 E15.4505
      Buffered code: G1 X169.304 Y265.727 E15.5816
      ==> 1524 bytes
      Code buffer space: 4096
      Full transfers per second: 15.00
      File /opt/dsf/sd/gcodes/test-fixed.gcode is selected, processing
        Can you provide the M122 for the mainboard as well?
        And can you try enabling the debug mode?
        https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Monitoring_optional
        Does this happen with every print?
        Can you share the gcode file as well?
        evomotorsundefined 1 Reply Last reply Reply Quote 0
          evomotors @Phaedrux
          @Phaedrux said in Duet 3 + Tool board stops mid-print and reports 100% complete:
          M122 is for both, main board starts at line 17
          evomotorsundefined 1 Reply Last reply Reply Quote 1
            evomotors @evomotors
            @evomotors said in Duet 3 + Tool board stops mid-print and reports 100% complete:
            It doesn't happens on every print, the same gcode file did work when I started printing again from the beginning. It happened to me 3 or 4 times since I upgraded to Duet board few weeks ago.
            I will enable diagnostics
