    Mesh bed leveling gone wild!
    2.4k
    • my67novaundefined
      my67nova
      Just deleted the bed.g and config-override.g. Now it starts the mesh bed leveling at X-2 but still does not go past X98. Looked at the config.json and it does not match. Could this be the issue? If so do I edit it to match? It also thinks the firmware is 1.17 and I have 1.18.1
      {"board":"duetwifi10","firmware":1.17,"compatibility":2,"nvram":false,"geometry":{"type":"cartesian","mins":[0,0,0],"maxes":[200,200,180]},"drives":[{"direction":0,"microstepping":32,"microstepping_interpolation":true,"steps_per_mm":320,"instant_dv":15,"max_speed":6000,"acceleration":500,"current":800,"driver":0,"endstop_type":1,"endstop_location":1},{"direction":0,"microstepping":32,"microstepping_interpolation":true,"steps_per_mm":320,"instant_dv":15,"max_speed":6000,"acceleration":20,"current":800,"driver":1,"endstop_type":1,"endstop_location":1},{"direction":1,"microstepping":32,"microstepping_interpolation":true,"steps_per_mm":10240,"instant_dv":0.2,"max_speed":150,"acceleration":250,"current":800,"driver":2,"endstop_type":3,"endstop_location":1},{"direction":1,"microstepping":32,"microstepping_interpolation":true,"steps_per_mm":420,"instant_dv":2,"max_speed":20,"acceleration":250,"current":800,"driver":3}],"idle":{"used":true,"factor":30,"timeout":30},"homing_speed_fast":"30","homing_speed_slow":"6","travel_speed":100,"z_dive_height":5,"slow_homing":false,"probe":{"type":"unmodulated","trigger_height":2.5,"trigger_value":443,"x_offset":0,"y_offset":0,"speed":2,"deploy":false,"points":[{"x":30,"y":15,"z":0},{"x":30,"y":180,"z":0},{"x":180,"y":180,"z":0},{"x":180,"y":15,"z":0},{"x":100,"y":100,"z":0}]},"num_nozzles":1,"bed_is_nozzle":false,"bed":{"present":true,"heater":0,"use_pid":false,"width":200,"length":200},"chamber":{"present":false},"max_heater_temperature":260,"heaters":[{"scale_factor":100,"series":4700,"thermistor":100000,"beta":4138,"a":0.0005717725,"b":0.0002416626,"c":0,"channel":0},{"scale_factor":100,"series":4700,"thermistor":100000,"beta":4138,"a":0.0005717725,"b":0.0002416626,"c":0,"channel":1}],"toolchange_wait_for_temperatures":true,"generate_t_code":false,"tools":[{"number":0,"extruders":[0],"heaters":[1],"x_offset":0,"y_offset":0,"z_offset":0}],"compensation_x_offset":15,"compensation_y_offset":15,"mesh":{"x_min":30,"x_max":185,"y_min":15,"y_max":185,"spacing":20},"home_first":false,"orthogonal":{"compensation":false},"network":{"enabled":true,"name":"","password":"","dhcp":true},"fans":[{"value":"30","inverted":false,"frequency":500,"thermostatic":false},{"value":"100","inverted":false,"frequency":500,"thermostatic":true,"heaters":[0,1],"trigger_temperature":45},{"value":"100","inverted":false,"frequency":500,"thermostatic":true,"heaters":[1],"trigger_temperature":45}],"custom_settings":""}
      • my67novaundefined
        my67nova
        Just changed to M557 X10:200 Y10:200 S20. Now it goes to X165 and the Web interface mesh display on show 1 row of coordinates at X190 here is my heightmap.csv . Does anyone have any ideas? I getting ready to pull out the SLEDGEOMATIC!
        RepRapFirmware height map file v1 generated at 2017-04-19 09:36 mean error -0.09 deviation 0.16
        xmin xmax ymin ymax radius spacing xnum ynum
        10 200 10 200 -1 20 10 10
        0 -0.204 -0.179 -0.162 -0.152 -0.152 -0.162 -0.177 -0.202 -0.222
        0 -0.112 -0.095 -0.091 -0.095 -0.102 -0.119 -0.142 -0.167 -0.182
        0 -0.027 -0.022 -0.025 -0.037 -0.05 -0.071 -0.095 -0.12 -0.141
        0 0.057 0.053 0.041 0.021 0.001 -0.026 -0.056 -0.086 -0.104
        0 0.134 0.118 0.094 0.065 0.035 0.002 -0.032 -0.069 -0.097
        0 0.178 0.149 0.113 0.073 0.035 -0.007 -0.056 -0.1 -0.132
        0 0.18 0.14 0.095 0.045 -0.005 -0.059 -0.113 -0.165 -0.211
        0 0.158 0.104 0.046 -0.02 -0.079 -0.148 -0.218 -0.281 -0.333
        0 0.128 0.06 -0.007 -0.085 -0.164 -0.249 -0.329 -0.408 -0.478
        0 0.094 0.013 -0.072 -0.167 -0.259 -0.362 -0.469 -0.569 -0.653
          Looks like the firmware thinks that X10 is not reachable by the probe, hence the initial column of zeros. In the config.g file you posted earlier, the X movement limit (M208 S1 X) is -22 and the probe offset (G31 X) is +32, which puts X10 right on the boundary between reachable and not reachable. Try X11:200 in your M558 command instead of X10:200.
          • my67novaundefined
            my67nova
            That seems to work for the left side of the bed. Still does not seem right yet. This is what I just ran M557 X11:200 Y10:200 S40 and this is what I see only points on right hand row.
            this is the file RepRapFirmware height map file v1 generated at 2017-04-19 12:41 mean error -0.08 deviation 0.13
            11 200 10 200 -1 40 5 5
            0 -0.176 -0.151 -0.162 -0.202
            0 -0.021 -0.038 -0.076 -0.12
            0 0.115 0.067 0.002 -0.073
            0 0.14 0.041 -0.062 -0.167
            0 0.059 -0.09 -0.255 -0.412
            It did probe X11
            What about the config.json mismatch?
              I just spotted this in your earlier post:
              If it thinks the firmware is 1.17, chances are that it is. Send command M115 to check. If the upgrade to 1.18.1 failed, you may need to upload the latest iap4e.bin before you upload firmware 1.18.1.
              • my67novaundefined
                my67nova
                4:04:02 PM M115
                FIRMWARE_NAME: RepRapFirmware for Duet WiFi FIRMWARE_VERSION: 1.18.1 ELECTRONICS: Duet WiFi 1.0 FIRMWARE_DATE: 2017-04-09
                But the config.json says 1.17
                • my67novaundefined
                  my67nova
                  Also did you see the heightmap pic? Just one row of data show up. Does not appear to be work as it carved out my PEI !
                    I guess that may be an artifact of how DWC responds to the column of zeros. I'll ask chrishamm to check it out.
                    • my67novaundefined
                      my67nova
                      Why am I getting zeros if it is probing X11? What about the rest of the data as well?
                        Your config.json file doesn't agreed with the config.g file you posted earlier. Please post your current config.g file again.
                        The version number in config.json suggests to me that you created it before you upgraded the firmware.
                        • my67novaundefined
                          my67nova
                          Like I said they don't jive. I did the full firmware again and same thing. Ran m997 no change to config.json
                          • Sniffleundefined
                            Sniffle
                            So i was having the same issue of 0's in the first column, and only displaying part of the mesh in the mesh visualizer, I had unwittingly made my X start point value for the probe grid below my X offset and the first column was 0'd out for the 16 point grid.
                            • my67novaundefined
                              my67nova
                              I was 2mm inside the the offset and just for giggles changed it 27mm and shazaam! It started working! I guess you can't be close to the edge…..
                              • my67novaundefined
                                my67nova
                                Now to try a test print.
                                • my67novaundefined
                                  my67nova
                                  Check my Wonky first layer post; https://www.duet3d.com/forum/thread.php?id=1647
