    Web Control Look and feel
    Duet Web Control
    2.4k
    • Vetiundefined
      Veti
      @PR1OR said in Web Control Look and feel:
      This is all i get when uploading the config.zi
      you are still on an old version of the web ui
      see the section
      Updating DuetWebControl files
      https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
        Yes it definitely seems like your DWC files are not getting updated, or you're using a URL that leads to the old version of DWC.
        https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/DuetWebControl-SD-3.1.1.zip
        You can manually update the DWC files by unzipping that file into the /www folder on the SD card using your PC.
        Once you are all up to date you should be able to update using the web interface by uploading the main release zip file as is.
        I think this update process might have gone off the rails because you started with a beta release of 2.03. It might have gone smoother if you'd updated to 2.03 final first, and then 2.05.1, 3.0, and finally 3.1.1. Updating with the full release zip file ensure you're getting any changed IAP files and DWC files as well.
        PR1ORundefined 1 Reply Last reply Reply Quote 0
        • PR1ORundefined
          PR1OR @Phaedrux
          @Phaedrux said in Web Control Look and feel:
          Thank you!! so i have now got the web UI looking good (though it does take a couple of refreshing the pages.
          However it still isnt uploading the Config.zip file and if it is i just get the loading page on the web control panel. Is there a manual way i can put this on the SD card?
          • PR1ORundefined
            PR1OR
            Also i ran M122 to see how ever thing is now connected and i have returned this. It doesnt look right to me, i feel like it isnt reading the SD card. Does it look ok you guys?
            • Vetiundefined
              Veti
              can you try a different browser
              • PR1ORundefined
                PR1OR @Veti
                @Veti said in Web Control Look and feel:
                Still cant connect in chrome or safari. I assume it wont work on IE ive read alot that it doesnt like IE.
                :s
                • Vetiundefined
                  Veti @PR1OR
                  @PR1OR
                  what is the error you are getting in chrome? have you configured a proxy?
                  • PR1ORundefined
                    PR1OR @Veti
                    @Veti So it connects to the IP but when i click to connect to the board it just doesnt do anything. It also shows like before where the axis bit looks odd again. Saying all this i get this screen fairly frequently on firefox but after a few refreshes it normally updates, this doesnt happen in chrome or safari
                    • Vetiundefined
                      Veti
                      that is still not the web ui for version 3.1.1
                      • PR1ORundefined
                        PR1OR @Veti
                        @Veti i have fully updates to 3.1.1 now is there a g code i can input to tell me what the ui version is?
                        • Vetiundefined
                          Veti @PR1OR
                          @PR1OR
                          take out the sd card. mount it in your computer.
                          delete all files in the www folder
                          unzip the files from https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/DuetWebControl-SD-3.1.1.zip into the www folder
                          • PR1ORundefined
                            PR1OR @Veti
                            @Veti did this and now my wifi LED isnt lighting at all and i cant connect :s
                            • PR1ORundefined
                              PR1OR @PR1OR
                              @PR1OR dont worry i did it wrong. overwrote all the files by accident.
                              I have fixed that now
                              UI now looks like this
                              • Vetiundefined
                                Veti
                                that looks correct. and all the values get displayed.
                                  You can verify the DWC version in the General tab on the left side but that now looks correct for 3.1.1.
                                  You should now be able to upload the config.zip to the system tab.
                                  • PR1ORundefined
                                    PR1OR @Phaedrux
                                    @Phaedrux @Veti
                                    Thanks both i have managed to upload the Config now. However i have a feeling the person i got the zip off may have to many in the same file so now im not sure what should and should be there. Can you confirm this is right?
                                    https://youtu.be/ioaC-JRMzCQhttps://youtu.be/ioaC-JRMzCQ
                                      Ok it looks like you have the entire contents of the /www folder in your /sys folder.
                                      The sys folder should have the .bin files for the firmware and .g files for the config. Everything else with a .gz should be removed.
                                      • PR1ORundefined
                                        PR1OR @Phaedrux
                                        So should i unplug the SD card and sort in to this?
                                        .bin = sys folder
                                        .g = gcodes
                                        .gz = delete
                                        • PR1ORundefined
                                          PR1OR @PR1OR
                                          @PR1OR
                                          also delete the .json?
                                            No you can do it right from the web interface. Put a checkmark next to the .gz files and then right click and delete.
                                            Leave the .g files in the /sys folder. Those are the configuration files you would edit, particularly config.g
