Endstop Question
put M574 into the web ui console and post the output
@kgrigio said in Endstop Question:
M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0tempunrelated buy you have not configured your thermistor correctly
M574
Endstop configuration:
X: none
Y: none
Z: none -
this indicates that your config was not read.
is the config you posted from your lokal computer or from the duet located in the sys folder ?
What is on the duet, at least I think. I uploaded the system files from my configuration zip file. Do I need to do anything once I upload them to make them "take"
please go to the web ui
file managment -> system.
and click on the config.g file and verifiy that they are identical
What I pasted above is from the file management -> systems -> config.g file, but I just figured it out. When I opened the file, I then hit save and it now works.
This begs the question, when I upload a new configuration.zip file why wouldn't this automatically save and start being used? Do I need to go in and save every time I upload? Do I need to save all the files?
you need to restart the duet to read the initial configuration. when editing the config.g after saving it will ask you to do so.
so any config changes require a restart.
Perfect. Thanks for the help. Now on to fix the other items, like the endstops you pointed out.
has the output of M574 changed?
Yes, now I am reading as follows
M574
X: low end switch connected to pin xstop
Y: low end switch connected to pin ystop
Z: low end Z probeOn the thermistors you mentioned above. What didn't I configure correctly? I haven't looked at this closely yet as I am going between this and helping my kids with virtual school today. Thanks again for the help.
B4138 is the default. that type of thermistor has not been used in years.
you need to figure out which thermistor is used in your printer.
creality tend to use epcop 100k thermistors.
https://github.com/MarlinFirmware/Configurations/blob/import-2.0.x/config/examples/Creality/CR-10 V2/Configuration.h
and marlin uses that as well.so try the values from this guide
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+2:+Configuration/38
but use R4700 for the duet wifi -
Perfect. Thanks.
