    No Axis Movement
    Firmware installation
    1.6k
    • Vetiundefined
      Veti @1d1
      @1d1 said in No Axis Movement:
      B4138 matches room temp
      that is because most thermistors used in 3d printer are 100k at room temperature. it does change at higher temperature and could easily result in temperatures being off by 40C
      Just tried M564 G92 directly -
      those are 2 different commands
      • 1d1undefined
        1d1
        Yes. I tried individually and separately. Not worried about thermistors right now. Thanks for your help. I appreciate your time and thoughts.
        • Vetiundefined
          Veti
          what parameter did you use for M564 ?
          • 1d1undefined
            1d1
            Perhaps my board is boinked?
            • 1d1undefined
              1d1
              For M 564 I just tried "home all"
              • Vetiundefined
                Veti @1d1
                i dont undestand what you mean
                M564 requires a parameter. on its own it does nothing.
                bearer posted a link to the documentation. if you had read that you would have seen that you need to issue
                M564 S0 H0
                edit: It states
                On some types of printer (e.g. Delta and SCARA), movement before homing may be prohibited regardless of the H parameter.
                • Vetiundefined
                  Veti
                  can you post your homedelta.g ?
                  • 1d1undefined
                    1d1
                    I entered M564 in the UI Gcode console, then tried to home. After sending the M564 it told me that movement outside the bed not possible, but homing was.
                    As for documentation link, I didn't and still don't see one. I'll add the M564 S0 H0 to the config.
                    Home delta g: ; homedelta.g
                    ; called to home all towers on a delta printer
                    ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 23 2020 23:27:15 GMT-0700 (Pacific Daylight Time)
                    G91 ; relative positioning
                    G1 H1 X251 Y251 Z251 F3600 ; move all towers to the high end stopping at the endstops (first pass)
                    G1 H2 X-5 Y-5 Z-5 F3600 ; go down a few mm
                    G1 H1 X10 Y10 Z10 F360 ; move all towers up once more (second pass)
                    G1 Z-5 F9000 ; move down a few mm so that the nozzle can be centred
                    G90 ; absolute positioning
                    G1 X0 Y0 F9000 ; move X+Y to the centre
                    • Vetiundefined
                      Veti @1d1
                      @1d1
                      look at bearer's post. the commands G92 and M564 are links.
                      is there a response when you send G28?
                      • 1d1undefined
                        1d1
                        No action with the M564 S0 H0 in either config.g or homedelta g
                        • Vetiundefined
                          Veti @1d1
                          @1d1
                          no as i posted thats not allowed on a delta
                          • 1d1undefined
                            1d1
                            I'll try it. Didn't realize those were links....
                            • 1d1undefined
                              1d1
                              Movement! Not the correct movement, but all three axes moved From G92 X0 Y0 Z0 with the extruder at the bed, and centered.
                                droftarts administrators @1d1
                                M574 X2 Y2 Z2 S0 ; set active high endstops
                                Have you got active low (normally open, or NO), or active high endstops (normally closed, NC)? See https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Microswitch
                                If you send M117, and the endstop reports triggered already, it may explain lack of movement. Change S0 to S1.
                                If you change anything in config.g, you need to reset the board, or send M98 P"config.g" to use those changes. Or input gcodes (temporarily, until the next reset) in the gcode console/command line.
                                • 1d1undefined
                                  1d1
                                  I've verified the endstops as being NC (changed to S1) and both X and Y move normally. Z isn't moving at all and the endstops are not triggering the axis movements of X and Y. On the board, the endstop lights are on and go off when manually triggering each end stop switch. For M117, the endstops are not triggered until I push them and each one is registering on the proper tower.
                                  I'm going to try Z on a different driver...
                                  • 1d1undefined
                                    1d1
                                    OK. Z works fine on X driver, so I think the Z is bad. Can I run Z from E1 if I change the position in the config?
                                      Can you post the results of M122 and send M98 P"config.g" and post any error messages that come up?
                                        Phaedrux Moderator @1d1
                                        Yes, you'd change the M574 z to use the driver number you want.
                                          M584 Z4
                                          • 1d1undefined
                                            1d1
                                            Closer yet. All axis moving normally now with Z on E1 (4). But the endstops are still not stopping movement or triggering. Yes, I changed the z end stop to E1.
                                            Here is M122:
                                            RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS) running on Duet WiFi 1.02 or later
                                            Board ID: 08DGM-956GU-DJMSN-6JTDA-3S46Q-TUQHH
                                            Used output buffers: 3 of 20 (8 max)
                                            Static ram: 28380
                                            Dynamic ram: 95928 of which 16 recycled
                                            Exception stack ram used: 276
                                            Never used ram: 6472
                                            Task NETWORK ready, free stack 324
                                            Task HEAT blocked, free stack 1256
                                            Task MAIN running, free stack 3592
                                            Last reset 00:01:34 ago, cause: software
                                            Last software reset at 2020-09-15 17:08, reason: User, spinning module GCodes, available RAM 6472 bytes (slot 0)
                                            Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
                                            Error status: 0
                                            Free file entries: 10
                                            SD card longest block write time: 0.0ms
                                            MCU temperature: min 32.3, current 32.6, max 32.9
                                            Supply voltage: min 24.1, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0
                                            Date/time: 2020-09-15 17:09:43
                                            Slowest loop: 4.79ms; fastest: 0.07ms
                                            Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
                                            Bed compensation in use: none
                                            Segments left: 0
                                            Movement lock held by null
                                            http is idle in state(s) 0
                                            telnet is idle in state(s) 0
                                            file is idle in state(s) 0
                                            serial is idle in state(s) 0
                                            aux is idle in state(s) 0
                                            daemon is idle in state(s) 0
                                            queue is idle in state(s) 0
                                            Code queue is empty.
                                            === Network ===
                                            Slowest loop: 72.51ms; fastest: 0.01ms
                                            HTTP sessions: 1 of 8
                                            • WiFi -
                                              Network state is running
                                              WiFi firmware version 1.21
                                              WiFi MAC address 5c:cf:7f:76:71:a9
                                              WiFi Vcc 3.29, reset reason Turned on by main processor
                                              WiFi flash size 4194304, free heap 13864
                                              WiFi IP address 192.168.1.54
                                              WiFi signal strength -44dBm, reconnections 0, sleep mode modem
                                              and M98 "config.g"... nothing comes up
