3.2b1 Duet 3 (DCS is not started)
Firmware installation
10
38
1.4k
    bcrazycramer
    After updating to 3.2b1 when I try to connect to the web control page I get these errors:
      Dougal1957
      I get the same
        BoA
        My works fine.
        undefined 1 Reply Last reply 15 Sept 2020, 18:02 Reply Quote 0
          Dougal1957 @BoA
          @BoA did you do anything other than the update/upgrade?
          undefined 1 Reply Last reply 15 Sept 2020, 18:03 Reply Quote 0
            BoA @Dougal1957
            @Dougal1957 Nope. Updated firmware first, then DWC. Standalone setup if that matters.
            undefined 2 Replies Last reply 15 Sept 2020, 18:04 Reply Quote 0
              Dougal1957 @BoA
              @BoA so you didn't do it via the Pi then?
              undefined 1 Reply Last reply 15 Sept 2020, 18:05 Reply Quote 0
                Dougal1957 @BoA
                @BoA said in 3.2b1 Duet 3 (DCS is not started):
                @Dougal1957 Nope. Updated firmware first, then DWC. Standalone setup it that matters.
                Yes that matters both myself and bcrazycramer do use the pi
                  BoA @Dougal1957
                  @Dougal1957 I am running standalone mode.
                    chrishamm administrators
                    I suspect there may be a permission issue going on because we changed from root to a dedicate dsf user in the latest pre-release. My best guess how to resolve this, run
                    sudo rm -f /var/run/dsf/dcs.sock
                    and wait a few seconds.
                    If that doesn't help, please check the DCS log first:
                    sudo journalctl -u duetcontrolserver -f
                    and if that keeps running, check the DWS log:
                    sudo journalctl -u duetwebserver -f
                    If it doesn't help, please post the last 20 lines or so from each log dump.
                    Duet software engineer
                    ? 1 Reply Last reply 16 Sept 2020, 17:32 Reply Quote 0
                      Dougal1957
                      @chrishamm said in 3.2b1 Duet 3 (DCS is not started):
                      Sep 15 19:35:13 duet3 DuetControlServer[10966]: at DuetControlServer.Model.PeriodicUpdater.Run() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Model/PeriodicUpdater.cs:line 39
                      Sep 15 19:35:13 duet3 DuetControlServer[10966]: [info] Application has shut down
                      Sep 15 19:35:14 duet3 systemd[1]: duetcontrolserver.service: Succeeded.
                      Sep 15 19:35:19 duet3 systemd[1]: duetcontrolserver.service: Service RestartSec=5s expired, scheduling restart.
                      Sep 15 19:35:19 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 386.
                      Sep 15 19:35:19 duet3 systemd[1]: Stopped Duet Control Server.
                      Sep 15 19:35:19 duet3 systemd[1]: Started Duet Control Server.
                      Sep 15 19:35:20 duet3 DuetControlServer[10988]: Duet Control Server v3.2.0-beta1
                      Sep 15 19:35:20 duet3 DuetControlServer[10988]: Written by Christian Hammacher for Duet3D
                      Sep 15 19:35:20 duet3 DuetControlServer[10988]: Licensed under the terms of the GNU Public License Version 3
                      Sep 15 19:35:21 duet3 DuetControlServer[10988]: [info] Settings loaded
                      Sep 15 19:35:21 duet3 DuetControlServer[10988]: [info] Environment initialized
                      Sep 15 19:35:21 duet3 DuetControlServer[10988]: [warn] Kernel SPI buffer size is smaller than RepRapFirmware buffer size (4096 configured vs 8192 required)
                      Sep 15 19:35:21 duet3 DuetControlServer[10988]: [info] Connection to Duet established
                      Sep 15 19:35:22 duet3 DuetControlServer[10988]: [info] IPC socket created at /var/run/dsf/dcs.sock
                      Sep 15 19:35:22 duet3 DuetControlServer[10988]: [fatal] Abnormal program termination
                      Sep 15 19:35:22 duet3 DuetControlServer[10988]: [fatal] Periodic updater task faulted
                      Sep 15 19:35:22 duet3 DuetControlServer[10988]: System.UnauthorizedAccessException: Access to the path is denied.
                      Sep 15 19:35:22 duet3 DuetControlServer[10988]: ---> System.IO.IOException: Permission denied
                      Sep 15 19:35:22 duet3 DuetControlServer[10988]: --- End of inner exception stack trace ---
                      Sep 15 19:35:22 duet3 DuetControlServer[10988]: at System.IO.DriveInfo.CheckStatfsResultAndThrowIfNecessary(Int32 result)
                      Sep 15 19:35:22 duet3 DuetControlServer[10988]: at System.IO.DriveInfo.get_TotalSize()
                      Sep 15 19:35:22 duet3 DuetControlServer[10988]: at DuetControlServer.Model.PeriodicUpdater.UpdateVolumes() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Model/PeriodicUpdater.cs:line 144
                      Sep 15 19:35:22 duet3 DuetControlServer[10988]: at DuetControlServer.Model.PeriodicUpdater.Run() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Model/PeriodicUpdater.cs:line 39
                      Sep 15 19:35:22 duet3 DuetControlServer[10988]: [error] IPC#2: Failed to assign connection processor
                      Sep 15 19:35:22 duet3 DuetControlServer[10988]: System.Threading.Tasks.TaskCanceledException: A task was canceled.
                      Sep 15 19:35:22 duet3 DuetControlServer[10988]: at DuetAPI.Utility.JsonHelper.ReceiveUtf8Json(Socket socket, CancellationToken cancellationToken) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetAPI/Utility/JsonHelper.cs:line 140
                      Sep 15 19:35:22 duet3 DuetControlServer[10988]: at DuetControlServer.IPC.Connection.ReceivePlainJson() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/IPC/Connection.cs:line 233
                      Sep 15 19:35:22 duet3 DuetControlServer[10988]: at DuetControlServer.IPC.Server.GetConnectionProcessor(Connection conn) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/IPC/Server.cs:line 173
                      Sep 15 19:35:22 duet3 DuetControlServer[10988]: [info] Application has shut down
                      Sep 15 19:35:22 duet3 systemd[1]: duetcontrolserver.service: Succeeded.
                      Sep 15 19:36:39 duet3 DuetWebServer[443]: Executed action DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer) in 17.4835ms
                      Sep 15 19:36:39 duet3 DuetWebServer[443]: info: Microsoft.AspNetCore.Routing.EndpointMiddleware[1]
                      Sep 15 19:36:39 duet3 DuetWebServer[443]: Executed endpoint 'DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer)'
                      Sep 15 19:36:39 duet3 DuetWebServer[443]: info: Microsoft.AspNetCore.Hosting.Diagnostics[2]
                      Sep 15 19:36:39 duet3 DuetWebServer[443]: Request finished in 18.1791ms 101
                      Sep 15 19:36:40 duet3 DuetWebServer[443]: info: Microsoft.AspNetCore.Hosting.Diagnostics[1]
                      Sep 15 19:36:40 duet3 DuetWebServer[443]: Request starting HTTP/1.1 GET http://duet3/rr_connect?password=reprap&time=2020-9-15T19%3A36%3A40 application/json
                      Sep 15 19:36:40 duet3 DuetWebServer[443]: info: DuetWebServer.Middleware.CustomEndpointMiddleware[0]
                      Sep 15 19:36:40 duet3 DuetWebServer[443]: No endpoint found for GET request via /rr_connect
                      Sep 15 19:36:40 duet3 DuetWebServer[443]: info: Microsoft.AspNetCore.Hosting.Diagnostics[2]
                      Sep 15 19:36:40 duet3 DuetWebServer[443]: Request finished in 0.6246ms 404
                      Sep 15 19:36:40 duet3 DuetWebServer[443]: Request starting HTTP/1.1 GET http://duet3/machine
                      Sep 15 19:36:40 duet3 DuetWebServer[443]: info: Microsoft.AspNetCore.Routing.EndpointMiddleware[0]
                      Sep 15 19:36:40 duet3 DuetWebServer[443]: Executing endpoint 'DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer)'
                      Sep 15 19:36:40 duet3 DuetWebServer[443]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[3]
                      Sep 15 19:36:40 duet3 DuetWebServer[443]: Route matched with {action = "Get", controller = "WebSocket"}. Executing controller action with signature System.Threading.Tasks.Task Get() on controller DuetWebServer.Controllers.WebSocketController (DuetWebServer).
                      Sep 15 19:36:40 duet3 DuetWebServer[443]: fail: DuetWebServer.Controllers.WebSocketController[0]
                      Sep 15 19:36:40 duet3 DuetWebServer[443]: [WebSocketController] DCS is not started
                      Sep 15 19:36:40 duet3 DuetWebServer[443]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[2]
                      Sep 15 19:36:40 duet3 DuetWebServer[443]: Executed action DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer) in 24.4179ms
                      Sep 15 19:36:40 duet3 DuetWebServer[443]: info: Microsoft.AspNetCore.Routing.EndpointMiddleware[1]
                      Sep 15 19:36:40 duet3 DuetWebServer[443]: Executed endpoint 'DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer)'
                      Sep 15 19:36:40 duet3 DuetWebServer[443]: Request finished in 25.1331ms 101
                      Sep 15 19:36:41 duet3 DuetWebServer[443]: info: Microsoft.AspNetCore.Hosting.Diagnostics[1]
                      Sep 15 19:36:41 duet3 DuetWebServer[443]: Request starting HTTP/1.1 GET http://duet3/rr_connect?password=reprap&time=2020-9-15T19%3A36%3A41 application/json
                      Sep 15 19:36:41 duet3 DuetWebServer[443]: info: DuetWebServer.Middleware.CustomEndpointMiddleware[0]
                      Sep 15 19:36:41 duet3 DuetWebServer[443]: No endpoint found for GET request via /rr_connect
                      Sep 15 19:36:41 duet3 DuetWebServer[443]: info: Microsoft.AspNetCore.Hosting.Diagnostics[2]
                      Sep 15 19:36:41 duet3 DuetWebServer[443]: Request finished in 0.5723ms 404
                      Sep 15 19:36:41 duet3 DuetWebServer[443]: Request starting HTTP/1.1 GET http://duet3/machine
                      Sep 15 19:36:41 duet3 DuetWebServer[443]: info: Microsoft.AspNetCore.Routing.EndpointMiddleware[0]
                      Sep 15 19:36:41 duet3 DuetWebServer[443]: Executing endpoint 'DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer)'
                      Sep 15 19:36:41 duet3 DuetWebServer[443]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[3]
                      Sep 15 19:36:41 duet3 DuetWebServer[443]: Route matched with {action = "Get", controller = "WebSocket"}. Executing controller action with signature System.Threading.Tasks.Task Get() on controller DuetWebServer.Controllers.WebSocketController (DuetWebServer).
                      Sep 15 19:36:41 duet3 DuetWebServer[443]: fail: DuetWebServer.Controllers.WebSocketController[0]
                      Sep 15 19:36:41 duet3 DuetWebServer[443]: [WebSocketController] DCS is not started
                      Sep 15 19:36:41 duet3 DuetWebServer[443]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[2]
                      Sep 15 19:36:41 duet3 DuetWebServer[443]: Executed action DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer) in 20.2086ms
                      Sep 15 19:36:41 duet3 DuetWebServer[443]: info: Microsoft.AspNetCore.Routing.EndpointMiddleware[1]
                      Sep 15 19:36:41 duet3 DuetWebServer[443]: Executed endpoint 'DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer)'
                      Sep 15 19:36:41 duet3 DuetWebServer[443]: Request finished in 20.8581ms 101
                      ^C
                      is this enough chris it just seems to be cycling
                      Doug
                        Thanks, it's indeed a permission issue - not sure why this problem didn't show up during our internal tests though. You need to change the service file /usr/lib/systemd/system/duetcontrolserver.service in order to fix it to
                        [Unit]
                        Description=Duet Control Server
                        [Service]
                        ExecStart=/opt/dsf/bin/DuetControlServer
                        TimeoutStopSec=15
                        Restart=always
                        RestartSec=5
                        Type=simple
                        User=dsf
                        Group=dsf
                        UMask=0002
                        CapabilityBoundingSet=CAP_SYS_PTRACE CAP_DAC_READ_SEARCH
                        AmbientCapabilities=CAP_SYS_PTRACE CAP_DAC_READ_SEARCH
                        [Install]
                        WantedBy=basic.target
                        Note the new permission CAP_DAC_READ_SEARCH. I'll update the DCS package again tomorrow.
                        undefined undefined 2 Replies Last reply 15 Sept 2020, 18:53 Reply Quote 0
                          Dougal1957 @chrishamm
                          [Unit]
                          [Service]
                          TimeoutStopSec=15
                          Restart=always
                          RestartSec=5
                          Type=simple
                          User=dsf
                          Group=dsf
                          UMask=0002
                          [Install]
                          Chris can you put that in simple layman's terms please How do I do that?
                          undefined 1 Reply Last reply 15 Sept 2020, 19:00 Reply Quote 0
                            bcrazycramer @chrishamm
                            Thank you! That fixed it.
                              chrishamm administrators @Dougal1957
                              @Dougal1957 Sure thing, run
                              sudo curl https://pkg.duet3d.com/duetcontrolserver.service -o /usr/lib/systemd/system/duetcontrolserver.service
                              sudo systemctl daemon-reload
                                Dougal1957
                                Fixed now thanks (one of the guys in a discord I am in suggested how I could edit it with NANO Thanks Luke
                                  bcrazycramer
                                  Do you know why this isn't working?
                                  pi@duet3:~$ sudo /opt/dsf/bin/DuetWebServer
                                  crit: Microsoft.AspNetCore.Server.Kestrel[0]
                                  Unable to start Kestrel.
                                  System.IO.IOException: Failed to bind to address http://[::]:80: address already in use.
                                  ---> Microsoft.AspNetCore.Connections.AddressInUseException: Address already in use
                                  ---> System.Net.Sockets.SocketException (98): Address already in use
                                  at System.Net.Sockets.Socket.UpdateStatusAfterSocketErrorAndThrowException(SocketError error, String callerName)
                                  at System.Net.Sockets.Socket.DoBind(EndPoint endPointSnapshot, SocketAddress socketAddress)
                                  at System.Net.Sockets.Socket.Bind(EndPoint localEP)
                                  at Microsoft.AspNetCore.Server.Kestrel.Transport.Sockets.SocketConnectionListener.Bind()
                                  at Microsoft.AspNetCore.Server.Kestrel.Transport.Sockets.SocketTransportFactory.BindAsync(EndPoint endpoint, CancellationToken cancellationToken)
                                  at Microsoft.AspNetCore.Server.Kestrel.Core.KestrelServer.<>c__DisplayClass21_01.<<StartAsync>g__OnBind|0>d.MoveNext() --- End of stack trace from previous location where exception was thrown --- at Microsoft.AspNetCore.Server.Kestrel.Core.Internal.AddressBinder.BindEndpointAsync(ListenOptions endpoint, AddressBindContext context) --- End of inner exception stack trace --- at Microsoft.AspNetCore.Server.Kestrel.Core.Internal.AddressBinder.BindEndpointAsync(ListenOptions endpoint, AddressBindContext context) at Microsoft.AspNetCore.Server.Kestrel.Core.ListenOptions.BindAsync(AddressBindContext context) at Microsoft.AspNetCore.Server.Kestrel.Core.AnyIPListenOptions.BindAsync(AddressBindContext context) at Microsoft.AspNetCore.Server.Kestrel.Core.Internal.AddressBinder.EndpointsStrategy.BindAsync(AddressBindContext context) at Microsoft.AspNetCore.Server.Kestrel.Core.Internal.AddressBinder.BindAsync(IServerAddressesFeature addresses, KestrelServerOptions serverOptions, ILogger logger, Func2 createBinding)
                                  at Microsoft.AspNetCore.Server.Kestrel.Core.KestrelServer.StartAsync[TContext](IHttpApplication1 application, CancellationToken cancellationToken) Unhandled exception. System.IO.IOException: Failed to bind to address http://[::]:80: address already in use. ---> Microsoft.AspNetCore.Connections.AddressInUseException: Address already in use ---> System.Net.Sockets.SocketException (98): Address already in use at System.Net.Sockets.Socket.UpdateStatusAfterSocketErrorAndThrowException(SocketError error, String callerName) at System.Net.Sockets.Socket.DoBind(EndPoint endPointSnapshot, SocketAddress socketAddress) at System.Net.Sockets.Socket.Bind(EndPoint localEP) at Microsoft.AspNetCore.Server.Kestrel.Transport.Sockets.SocketConnectionListener.Bind() --- End of inner exception stack trace --- at Microsoft.AspNetCore.Server.Kestrel.Transport.Sockets.SocketConnectionListener.Bind() at Microsoft.AspNetCore.Server.Kestrel.Transport.Sockets.SocketTransportFactory.BindAsync(EndPoint endpoint, CancellationToken cancellationToken) at Microsoft.AspNetCore.Server.Kestrel.Core.KestrelServer.<>c__DisplayClass21_01.<<StartAsync>g__OnBind|0>d.MoveNext()
                                  at Microsoft.AspNetCore.Server.Kestrel.Core.Internal.AddressBinder.BindAsync(IServerAddressesFeature addresses, KestrelServerOptions serverOptions, ILogger logger, Func2 createBinding) at Microsoft.AspNetCore.Server.Kestrel.Core.KestrelServer.StartAsync[TContext](IHttpApplication1 application, CancellationToken cancellationToken)
                                  at Microsoft.AspNetCore.Hosting.GenericWebHostService.StartAsync(CancellationToken cancellationToken)
                                  at Microsoft.Extensions.Hosting.Internal.Host.StartAsync(CancellationToken cancellationToken)
                                  at Microsoft.Extensions.Hosting.HostingAbstractionsHostExtensions.RunAsync(IHost host, CancellationToken token)
                                  at Microsoft.Extensions.Hosting.HostingAbstractionsHostExtensions.Run(IHost host)
                                  at DuetWebServer.Program.Main(String[] args) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetWebServer/Program.cs:line 24
                                  Aborted
                                  pi@duet3:~$
                                  undefined 1 Reply Last reply 15 Sept 2020, 19:07 Reply Quote 0
                                    chrishamm administrators @bcrazycramer
                                    @bcrazycramer It looks like there is another web server running on the same port (80). Do you have Apache or another HTTP server installed on your system? If not, try rebooting the Pi and check if that makes a difference.
                                    PS: DWS will usually run in the background as its own service, so there should be no need to start it manually. Follow my last reply describing the usage of journalctl to figure out why DCS/DWS isn't started.
                                      bcrazycramer
                                      I get the same after rebooting.
                                      I'm not using the Raspberry Pi for anything else except the Duet 3. I do have VNC enabled and SSH.
                                      undefined undefined 2 Replies Last reply 15 Sept 2020, 19:22 Reply Quote 0
                                        @bcrazycramer Please see my earlier post where I mention journalctl.
                                        [edit]Sorry, linking posts doesn't seem to work too well[/edit]
                                        undefined 1 Reply Last reply 15 Sept 2020, 19:24 Reply Quote 0
                                          Dougal1957 @bcrazycramer
                                          @bcrazycramer I get the same as well not that I have a clue what it means!
                                          6 out of 38
