Problemas al hacer Home
the configurator https://configtool.reprapfirmware.org/Start changes the parameters for you. that makes it easier for beginners.
Gracias con el configurador tampoco se soluciona.
@CHARLI55 said in Problemas al hacer Home:
I have mounted a BLV CUBE and when I do home it does it in the rear left corner
btw the blv cube is supposed to home in the rear left, because that is where the switches should go.
Si en eso estoy de acuerdo pero los ejes X Y tenian que poner 0?
The homing switch location at the low end of travel will be 0, but when it's at the high end of travel, it will be 200 or whatever the max axis length is.
You should follow this guide for testing motor direction once you have the endstop switch positions defined and the homing directions defined to match.
https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_Movement_section
Try making a diagram like this to help keep things straight.
This is the position of the endstop, I don't know if it's okay or the Y-axis endstop has to be on the left front end. -
Ok, that means the Y axis endstop is at the high end of travel.
Your command in config.g should be:
M574 Y2 S1 P"ystop"
And your Y homing moves should be in the positive direction.
And X homing moves negative.
This is what I have set in config.g,
M574 X1 Y2 S1do I have to change it to ?
M574 Y2 S1 P"ystop" -
M574 X1 Y2 S1This would be correct for RRF2.
Muchas gracias
