    Controlling a 24VDC contactor via duet 3?
    • astrnundefined
      astrn
      Hi everyone.
      I would like to know if its possible to control 110VAC / 24VDC (Coil voltage) contactor via duet 3 fan outputs (OUT7 thru OUT9 with flyback diodes). Does it damage the board during on/off sequence?
      I measured the coil power draw and its around 6-8W total (About 0.3 amps) when its active.
      This is the contactor that I would like to turn on/off.
      https://www.automationdirect.com/adc/shopping/catalog/motor_controls/iec_contactors_-z-starters-z-overloads/fuji_contactors-z-_overloads/9_to_25_amp/sc-e05g-24vdc
      • BoAundefined
        BoA
        2-pin KK connectors labelled OUT7 thru OUT9: these are intended for fans. Maximum recommended current 2.5A each. Flyback diodes are built-in to these outputs.
        Should be fine. Just select V_FUSED with jumper. I would use SSR instead.
        • astrnundefined
          astrn
          Sorry for my noob question but I am no electronics/electrical engineer. I checked the specs and it should be fine on the paper. What concerns me if there will be a sudden current spike that flyback diodes cannot handle (I dont know if flyback diodes has max current limit?) when contactor turns on/off. I cannot measure it since it happens too fast. I dont know if anyone tried a similar thing before.
          • astrnundefined
            astrn
            The contactor is actually going to power the heatbed SSR. I added the contactor as a safety measure if SSR gets break and start heating the bed as it is own. Duet 3 is supposed to turn on/off contactor when its printing only.
            • BoAundefined
              BoA
              Not sure what kind of "sudden current spike" You have in mind.
              In general mentioned diode is to block negative voltage when switching inductive loads off (like contactor coil), and the contactor current (110VAC) is not flowing through them.
              • astrnundefined
                astrn
                Got it. I probably misunderstood the whole flyback diode concept wrong :). I will go ahead and try it. Thanks. Still learning 🙂
                • astrnundefined
                  astrn
                  Connected it and it works fine. Thanks!
