    New Duet WiFi firmware 1.19beta1
    Firmware installation
    12
    38
    5.0k
    • Kulitorumundefined
      Kulitorum
      Maybe I should be more specific - the U axis never moves. Not using the panel and not using the web interface. It is never powered.
      • vhowardundefined
        vhoward
        So. I tried the update to the beta again. It did connect this time and gave me an ajax error a few seconds later. This is what it said.
        Communication Error
        An AJAX error has been reported, so the current session has been terminated.
        Please check if your printer is still on and try to connect again.
        Error reason: SyntaxError: JSON.parse: unexpected character at line 1 column 1 of the JSON data
        And here is the output from M122.
        M122
        SENDING:M122
        Used output buffers: 1 of 32 (7 max)
        Static ram used: 20356
        Dynamic ram used: 95748
        Recycled dynamic ram: 2680
        Stack ram used: 3680 current, 4504 maximum
        Never used ram: 7784
        Last reset 00:05:03 ago, cause: power up
        Last software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
        Spinning module during software reset: GCodes, available RAM 32812 bytes (slot 0)
        Error status: 0
        [ERROR] Error status: 0
        Free file entries: 10
        SD card longest block write time: 0.0ms
        MCU temperature: min 17.9, current 23.5, max 26.8
        Supply voltage: min 12.1, current 12.2, max 12.4, under voltage events: 0, over voltage events: 0
        Driver 0: standstill
        Driver 1: standstill
        Driver 2: standstill
        Driver 3: standstill
        Driver 4: standstill
        Date/time: 2017-05-22 17:39:21
        Slowest main loop (seconds): 0.013398; fastest: 0.000036
        MaxReps: 0, StepErrors: 0, MaxWait: 0ms, Underruns: 0, 0
        Bed compensation in use: none
        Probe change coordinates:
        Bed heater = 0, chamber heater = -1
        Segments left: 0
        Movement lock held by null
        http is idle in state(s) 0
        telnet is idle in state(s) 0
        file is idle in state(s) 0
        serial is ready with "M122" in state(s) 0
        aux is idle in state(s) 0
        daemon is idle in state(s) 0
        queue is idle in state(s) 0
        Code queue is empty.
        Network state is running
        WiFi firmware version 1.19-beta1
        WiFi MAC address a0:20:a6:16:ea:67
        WiFi Vcc 3.06, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 40344
        WiFi IP address 192.168.1.10
        WiFi signal strength -38db
        HTTP sessions: 1 of 8
        Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
        Plus when I hooked up to it via usb, only the extruder would and heaters would operate. It would not home any of the axis'.
        I have rolled it back to 1.18.1 again and the wifi won't connect but it operates normally via usb.
        • tomasfundefined
          tomasf
          @dc42:
          Did you check that the network password was entered correctly, and surround it in quotes?
          Yes, several times.
            Kulitorum
            Did you miss my comment, With 1.19beta1 my U axis stopped working. - two posts up.
              Yes I did miss that. I'm hoping to do another release today so I will look into that.
              • joestefanoundefined
                joestefano
                Is there anyway to see all the lines of M122 on a 7" Panel Due? My IP address changes and without being able to see it with M552, I have to hook up to pronterface with usb just to find it.
                • Forgvn77undefined
                  Forgvn77
                  I second that, I need the full output from M552 on the Panel Due so I don't have connect via USB.
                  Thanks!
                  Velleman K8200, Geeetech G2S Pro (x2), Geeetech Rostock 301 retrofitted with Duet
                  Make A Difference!
                  • elmoretundefined
                    elmoret
                    No need to hook up USB, just either check your router or use an app like Fing on your phone.
                    Or set your router up to assign a static IP by MAC address.
                    • Forgvn77undefined
                      Forgvn77
                      I am at work and have no access to my router or network scan. Nslookup does not want to report the ip for the printer. It would be immensely helpful to be able to view the ip address of the printer on the Panel Due 4.3. As of now I have not been able to do that at all. M552 S1 does not report the ip on the Panel Due. Is there another M command that shows the ip of the printer?
                      Make A Difference!
                      • Dougal1957undefined
                        Dougal1957
                        M552 with no params reports the IP address
                        • Forgvn77undefined
                          Forgvn77
                          M552 with no params reports the name of the access point I am connected to on the Panel Due display, but does not report the ip unfortunately.
                          Make A Difference!
                            Dougal1957
                            ah it does on the DWC stby and I'll just check it on mine
                              Dougal1957
                              M552 on my PanelDUE does give me the IP Address
                              it reports the configured IP address (This is ignored of course) and the Actual IP address
                              • minimundefined
                                minim
                                @vhoward:
                                Communication Error
                                M122
                                SENDING:M122
                                Error status: 0
                                Segments left: 0
                                This has the same software reset code as I have 😮
                                  joestefano
                                  I didn't think you could set a static IP in the config with a duetwifi. David had told me that awhile back. Has that changed?
                                  • elmoretundefined
                                    elmoret
                                    Static IP should be set it in your wireless router using the Duet Wifi's MAC address.
                                      In 1.19 you can set up a static IP address in the connection parameters you give in the M587 command. See https://duet3d.com/wiki/G-code#M587:_Add_WiFi_host_network_to_remembered_list.2C_or_list_remembered_networks.
                                      • cbusilloundefined
                                        cbusillo
                                        Is there a beta for the Ethernet board? I am on 1.19alpha and I am unable to get mesh leveling to work. It will probe the bed and even save the height map file. It is non compensating for my bed at all during the print and M122 says "Bed compensation in use: none". This is right after running G29 or G29 S1
                                        • pkmundefined
                                          pkm
                                          I'm not sure I want to upgrade to 1.19. The web-server works OK for me.
                                          Can I just upgrade DWC to 1.16?
                                            I think DWC 1.16 should work with firmware 1.18 but I haven't tested it.
                                            There will be a new 1.19beta1 tomorrow or possibly later today. However, the changes in 1.19 are mostly to do with WiFi improvements and supporting new kinematics, do Duet Ethernet and users of older Duets are probably better off staying with 1.18.1 for now.
