    duel z axis problems
    609
    • chainbreaker2012undefined
      chainbreaker2012 @Phaedrux
      Hey,
      Thanks for all of the advice, sorry it has taken me a bit to respond as we have been dealing with a sick child and everything had to go on back burner for a few days. I will post config.g in the morning as soon as I get off work. I have the current turned up to stepper rated current and ptfe lube on the screws and linear rods. It all moves fairly effortlessly. I dropped speed way down for Z and did a side to side level at screws. Takes 6x before bed is even both sides and im ok with that. I then home it and do it again and it shows z axis off by .8mm again. Hopefully this is making sence lol. Also I am using the 0.9°, 180°C high temp stepper motors since this printer will be doing alot of PC and Nylon in a enclosure. Also wondering if the bltouch may be going bad, I have one of the ir sensors the dc designed that i got from filistruder so i may give that a shot also if its more acurate.
        chainbreaker2012
        homey.g homex.g homeall.g config.g bolded text
        this is my skew correction macro
        G30 P0 X20 Y200 Z-99999 ;
        G30 P1 X380 Y200 Z-99999 S2 ;
        G28
          chainbreaker2012
          cant find anything hanging up on z axis either bed drops from z0 down to bottom when unplugged on its own. just to be sure i put a small amount of lithium grease on the rods and the screws but still same issue
          Results of 2 back to back skew corrections;
          9/22/2020, 4:57:22 PM Leadscrew adjustments made: 0.033 -0.011, points used 2, deviation before 0.024 after 0.000
          9/22/2020, 4:57:12 PM Leadscrew adjustments made: -0.016 0.013, points used 2, deviation before 0.014 after 0.000
          9/22/2020, 4:57:02 PM Leadscrew adjustments made: 0.013 -0.009, points used 2, deviation before 0.011 after 0.000
          9/22/2020, 4:56:52 PM Leadscrew adjustments made: 0.005 -0.009, points used 2, deviation before 0.007 after 0.000
          9/22/2020, 4:56:41 PM Leadscrew adjustments made: 0.005 0.008, points used 2, deviation before 0.006 after 0.000
          9/22/2020, 4:56:31 PM Leadscrew adjustments made: -0.001 0.000, points used 2, deviation before 0.001 after 0.000
          9/22/2020, 4:56:21 PM Leadscrew adjustments made: -0.016 0.016, points used 2, deviation before 0.016 after 0.000
          9/22/2020, 4:56:11 PM M98 P"0:/macros/BED COMPRNSATION"
          Leadscrew adjustments made: -0.446 -0.475, points used 2, deviation before 0.461 after 0.000
          9/22/2020, 4:55:19 PM Leadscrew adjustments made: 0.005 -0.004, points used 2, deviation before 0.004 after 0.000
          9/22/2020, 4:55:09 PM Leadscrew adjustments made: -0.004 0.014, points used 2, deviation before 0.010 after 0.000
          9/22/2020, 4:54:59 PM Leadscrew adjustments made: 0.009 -0.017, points used 2, deviation before 0.014 after 0.000
          9/22/2020, 4:54:49 PM Leadscrew adjustments made: -0.010 0.030, points used 2, deviation before 0.022 after 0.000
          9/22/2020, 4:54:38 PM Leadscrew adjustments made: -0.015 -0.029, points used 2, deviation before 0.023 after 0.000
          9/22/2020, 4:54:28 PM Leadscrew adjustments made: 0.029 0.010, points used 2, deviation before 0.022 after 0.000
          9/22/2020, 4:54:18 PM Leadscrew adjustments made: -0.020 0.035, points used 2, deviation before 0.029 after 0.000
          9/22/2020, 4:54:08 PM M98 P"0:/macros/BED COMPRNSATION"
          Leadscrew adjustments made: -0.391 -0.421, points used 2, deviation before 0.407 after 0.000
            chainbreaker2012
            this was after skew macro above and running a mesh compensation probe then checking skew againsame result even when i turn accell and jerk way down.
            9/22/2020, 5:06:38 PM M98 P"0:/macros/1comp"
            Leadscrew adjustments made: -0.584 -0.620, points used 2, deviation before 0.602 after 0.000
            9/22/2020, 5:06:17 PM G29
            441 points probed, min error -1.314, max error 0.273, mean -0.467, deviation 0.413
            Height map saved to file heightmap.csv
              chainbreaker2012
              as requested M112
              Status
              Idle
              Mode: FFF
              Tool Position
              X
              360.0
              Y
              215.0
              Z
              13.85
              Extruder Drives
              Drive 0
              0.0
              Speeds
              Requested Speed
              0 mm/s
              Top Speed
              0 mm/s
              Sensors
              Vin
              24.1 V
              MCU Temperature
              41.6 C
              Z-Probe
              0
              Tools
              Extra
              Control All
              Tool Heater Current Active Standby
              Tool 0
              T0 - Load Filament Heater 1
              active 254.9 C
              255
              255
              Bed Heater 0
              active 100.6 C
              100
              0
              Chamber Heater 2
              off 24.2 C
              0
              0
              Temperature Chart
              Send code...
              9/22/2020, 5:10:46 PM M122
              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.0 running on Duet WiFi 1.02 or later
              Board ID: 08DJM-9178L-L2MS8-6J9D6-3SJ6N-19FUR
              Used output buffers: 1 of 24 (17 max)
              Static ram: 30516
              Dynamic ram: 92368 of which 32 recycled
              Exception stack ram used: 568
              Never used ram: 7588
              Tasks: NETWORK(ready,640) HEAT(blocked,1240) MAIN(running,1320) IDLE(ready,156)
              Owned mutexes:
              Last reset 26:11:57 ago, cause: software
              Last software reset time unknown, reason: User, spinning module GCodes, available RAM 8260 bytes (slot 3)
              Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
              Error status: 0
              Free file entries: 10
              SD card longest block write time: 56.9ms, max retries 0
              MCU temperature: min 35.5, current 42.0, max 43.2
              Supply voltage: min 23.8, current 24.1, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
              Driver 0: standstill, SG min/max 0/1023
              Driver 1: standstill, SG min/max 0/1023
              Driver 2: standstill, SG min/max 0/1023
              Driver 3: standstill, SG min/max 0/1023
              Driver 4: standstill, SG min/max 0/1023
              Date/time: 2020-09-22 17:10:43
              Slowest loop: 116.14ms; fastest: 0.09ms
              Hiccups: 0(0), FreeDm: 169, MinFreeDm: 109, MaxWait: 73489183ms
              === MainDDARing ===
              Scheduled moves: 1548, completed moves: 1548, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
              === AuxDDARing ===
              Bed heaters = 0 -1 -1 -1, chamberHeaters = 2 -1 -1 -1
              Heater 0 is on, I-accum = 0.0
              Heater 1 is on, I-accum = 0.7
              Segments left: 0
              Stack records: 4 allocated, 0 in use
              Movement lock held by null
              http is idle in state(s) 0
              telnet is idle in state(s) 0
              file is idle in state(s) 0
              serial is idle in state(s) 0
              aux is idle in state(s) 0
              daemon is idle in state(s) 0
              queue is idle in state(s) 0
              Code queue is empty.
              === Network ===
              Slowest loop: 104.03ms; fastest: 0.00ms
              Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
              HTTP sessions: 1 of 8
              • WiFi -
                Network state is running
                WiFi firmware version 1.23
                WiFi MAC address a4:cf:12:c0:1d:8c
                WiFi Vcc 3.39, reset reason Turned on by main processor
                WiFi flash size 4194304, free heap 25944
                WiFi IP address 10.159.204.148
                WiFi signal strength -41dBm, reconnections 0, sleep mode modem
                Socket states: 0 0 0 0 0 0 0
                Phaedrux Moderator @chainbreaker2012
                @chainbreaker2012 said in duel z axis problems:
                Well you are running a older firmware. I suggest you update to 3.1.1 by downloading this zip file and uploading it as is (don't extract it) to the sys folder in DWC.
                https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip
                  M671 X20:380 Y200:200 S10
                  X20:380 doesn't sound right for the location of your lead screws. -20 and 420 perhaps based on your M208.
                  M208 X400 Y400 Z500 S0 ; set axis maxima
                  Unrelated, but not sure why you would want to turn off interpolation on the extruder motor unless you like more noise?
                  M350 E16 I0
                  Your homeall calls the other homing macros, but you haven't included homez, so I can't see how you're actually homing the Z axis.
                  M98 P"homex.g"
                  M98 P"homey.g"
                  M98 P"homez.g"
                    Do you use bed.g/G32 or are you just calling this macro?
                      chainbreaker2012
                      just calling that macro,
                      I cant reach to the full 400 on bed due to the mounts for the linear rails hence why i am using X20380
                      I thought it was the newest firmware on there but ill go ahead and upload 3.1.1 This may be because I had the original sd card get corrupted and had to redo disk image on it.
                      M350 could that be because I turned off microstepping on that? I was told it didnt need it since it was the extruder. Its actually still really quiet lol
                      sorry for not including the home z I must have accidently double clicked it.
                      homez.g
                        chainbreaker2012
                        funny thing I have 3.1.1.zip on the sd card lol I corgot to upload it when i reflashed the image.
                          M671 is defining the location of the lead screws themselves not where you can reach them. The probe points are defined in your macro.
                          Well microstepping is the x16 part, so you're still using microstepping and you definitely do want that. Interpolation allows the drivers to take those x16 microsteps and convert them internally to x256 pulses for the motors for smooth quiet motion. So you definitely want x16 with interpolation on.
                          In your homez you should change the position where it probes to be the center of the bed. Right now it looks like you have it set to a corner.
                          G1 X35 Y17 F6000 ; go to first probe point
                          By correcting the M671 to use the actual position of the lead screw and then probing the center of the bed you should be able to improve the performance of the leveling routine.
                          Might be a good idea to review this
                          https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
                            chainbreaker2012
                            thank you I will adjust as instructed, Thank you for helping me with this. I did have it set to a corner but in my start gcode what I did was have it heat the bed and nozzle then do a G30 at the center just before it starts printing I will change that. Thanks again for your time. It is very much appreciated.
