    DWC 3.2.0 beta-1 SBC: "M84 XYE" causes parser error
    Duet Web Control
    331
    • docboboundefined
      docbobo
      I just started my journey with RRF on a SKR 1.4 Turbo. Today, I switched from an ESP based connection over to the SBC integration. However, uploading some gcode that had worked earlier today, I received the following error:
      Failed to get file info for CaribouSKR_PETG_calicat_calico_0.2000mm.gcode
      Operation failed (Reason: CodeParserException in GetFileInfo: Failed to parse major M-code number (otors))
      It seems that the parsed had some issues with the very last gcode in the file, which reads
      M84 XYE
      However, the same gcode worked in the files when uploaded via ESP.
        Can you confirm that you are also running DSF version 3.2beta1 on the SBC?
        • docboboundefined
          docbobo
          $ dpkg --list | grep Duet
          ii  duetcontrolserver                    3.2.0-beta1+1                       armhf        Control server application for Duet 3 series
          ii  duetruntime                          3.2.0-beta1+1                       armhf        .NET Core runtime libraries for the Duet software framework
          ii  duetsd                               1.0.7                               all          Virtual SD card directory for the Duet software framework
          ii  duetsoftwareframework                3.2.0-beta1+1                       armhf        Meta package for the full Duet software framework
          ii  duetwebcontrol                       3.2.0-beta1+2                       all          Official web interface for Duet electronics
          ii  duetwebserver                        3.2.0-beta1                         armhf        Optional web server for Duet 3 series
            T3P3Tony administrators
            thanks for the report, this is one for @chrishamm
            • chrishammundefined
              chrishamm administrators
              I cannot confirm this problem. M84 XYE is correctly parsed by DSF and your error message suggests that you have an unescapted Motors expression somewhere in your file. If that is not the case, please provide the full G-code file and I'll look into it again.
              Duet software engineer
              • docboboundefined
                docbobo
                You are right, it seems to be slightly more complicated than that. Even though I cannot upload my gcode file here - upload always fails with an error (?) - I was able to reduce the problem to exactly one line:
                M84 XYE; disable motors
                A gcode file that just contains this line will produce the error. Adding a whitespace in front of the semicolon seems to fix this problem, btw.
                • docboboundefined
                  docbobo
                  Just checked - that even produces the same error when pasted into the GCode command box at the top of DWC.
                    Thanks for sharing those details. I'll fix it in 3.2-b2.
