M308 B-Value for Semitec 104GT-2 104NT-4-R025H42G
In the past I was using cheap China NTC thermistors for the Hotend.
Now I want to try a Semitec 104GT-2 104NT-4-R025H42G.How do I calculate the right B-Value.
At the moment I have this config:
; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M143 H1 S290 M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit I am using a Duet 2 with the lastest v3 firmware.
in the configurator when you click on the beta value a popup comes up that lets you select the semitec
https://configtool.reprapfirmware.org/Heatersits B4725 C7.06e-8
Ahhh... I didn't know that I can select the thermistor there too. I thought I could only enter the value there.
Thanks a lot.
I switched the Thermistor. Changed the values in config.g into the following:
M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; Semtec Thermistor ; M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp Re-Tuned the Hotend.
But now I get worse results in print than before: -
@xadox said in M308 B-Value for Semitec 104GT-2 104NT-4-R025H42G:
B4138
you were most likely printing at the wrong temperature with you chinese thermistor.
what temperature are you printing with what material?
try printing at 225
@Veti I think the Config-Generator seems to have a small bug.
Since the Semitec should have around 100KOhm at 25°C (Datasheet):But the Config-Generator creates it with 100000:
I measured the resistance at 25°C and it is about 100KOhm.
i am not sure i follow 100K = 100000
@Veti You are of course absolutely right.
I forgot that the data is in Ohm. -
Ok. I will try printing now with lower temp @225C.
@Veti You are a genius:
Printed @225C
so this tell you that the temperature with you china thermistor was off by about 20 degrees
