    Fan Not working
    • aeroutaundefined
      aerouta
      I am having issues with running my layer fan. I get 12v across the FAN0 pins. However when i plug a fan in the voltage drops to 1.8V and no rotation on the fan. Any thoughts?
        What board are you using?
        What is your fan configuration in config.g?
        Does the fan work in the always on fan port?
        Do you see any damage to the fan mosfets? Is the fan fuse intact?
