Solved Court-circuit
Bonjour je débute avec une Duet 2 wifi et après avoir télécharger le firmware pour faire des test le Duet m'indique Erreur: court-circuit au sol signalé par le (s) conducteur (s) 5 6 7 8 9
Erreur: arrêt en cas de surchauffe signalé par le (s) conducteur (s) 5 6 7 8 9
de quoi pourrait venir le problème -
do you have a duex5?
driver 5 6 7 8 9 would be on the expansion card
post your config -
Yes i have a Duex5
; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Sep 27 2020 22:04:01 GMT+0200 (heure d’été d’Europe centrale); General preferences
M550 P"MonsterPrinter" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
M203 X9000.00 Y9000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M208 X-2 Y0 Z0 S1 ; set axis minima
M208 X780 Y500 Z400 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"duex.pwm1" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X0 Y18 Z2 ; set Z probe trigger value, offset and trigger height
M557 X20:760 Y20:480 S20 ; define mesh grid; Heaters
M143 H0 S150 ; set temperature limit for heater 0 to 150C
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
please post the output of m122
check that your wiring is like described here
https://duet3d.dozuki.com/Wiki/Duex2_and_Duex5_Features#Section_Wiring
observe the important notes there.@chris974M said in Court-circuit:
M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0tempyour themistor set it incorrect. B4138 is the default and wrong for your setup. you need to look up your specific thermistor settings
m122
1 ms, nombre maximal de tentatives 0 Température MCU: min 33,3, courant 33,6, max 33,8 Tension d'alimentation: min 24,1, courant 24,2, max 24,4, événements de sous-tension: 0, événements de surtension: 0, alimentation bonne: oui Driver 0: arrêt, SG min / max non disponible Pilote 1: à l'arrêt, SG min / max non disponible Pilote 2: à l'arrêt, SG min / max non disponible Pilote 3: à l'arrêt, SG min / max non disponible Pilote 4: à l'arrêt, SG min / max non disponible Pilote 5: arrêt de température! arrêt court-à-terre, SG min / max non disponible Driver 6: arrêt température! arrêt court-à-terre, SG min / max non disponible Driver 7: arrêt température! arrêt court au sol, SG min / max non disponible Driver 8: arrêt température! arrêt court-à-terre, SG min / max non disponible Driver 9: arrêt température! arrêt court au sol, SG min / max non disponible Date / heure: 2020-10-01 17:46:03 Nombre de succès des données du cache 2452080743 Boucle la plus lente: 12,45 ms; plus rapide: 0.07ms I2C nak erreurs 0, envoi des délais 0, réception des délais 0, finishTimeouts 0, réinitialisation 0 === Déplacer === Hoquet: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms Compensation de lit en cours d'utilisation: aucune , Comp offset 0,000 === DDARing === Mouvements programmés: 0, coups terminés: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 === Heat === Chauffe-lits = 0 -1 -1 - 1, ChamberHeaters = -1 -1 === GCodes === Segments à gauche: 0 Enregistrements de pile: 1 alloué, 0 en cours d'utilisation Verrou de mouvement maintenu par null http est inactif dans l'état (s) 0 telnet est inactif dans l'état (s) 0 fichier est inactif dans l'état (s) 0 série est inactif dans l'état (s) 0 aux est inactif dans l'état (s) 0 démon est inactif dans l'état (s) 0 file d'attente est inactif dans l'état (s) 0 autopause est inactif dans état (s) 0 La file d'attente de codes est vide. === Réseau === Boucle la plus lente: 200,58 ms; le plus rapide: 0. -
thats not how a console output looks like.
are you connecting via usb? if so please observe https://duet3d.dozuki.com/Wiki/USB_ground_loops
Non j'utilise en wifi
i am a bit confused. how are you getting french output from M122?
i dont see an option to change the language of the duet firmware. -
post a photo of your wiring between the duet and the duex
J'ai juste suivi les steps sur https://duet3d.dozuki.com/c/Getting_Started
M122 en Français et avec la traduction -
Can you change the line ending setting in YAT so we can see the full M122 report?
Comment je dois faire ? Désoler c'est la première fois que j'utilise une Duet
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later + DueX5
Board ID: 08DLM-996RU-N8PS4-6JKD8-3S06T-KBVRN
Used output buffers: 1 of 24 (1 max)
Static ram: 25712
Dynamic ram: 93528 of which 0 recycled
Exception stack ram used: 244
Never used ram: 11588
Tasks: NETWORK(ready,1448) HEAT(blocked,1232) DUEX(suspended,160) MAIN(running,3816) IDLE(ready,160)
Owned mutexes:
Last reset 00:00:33 ago, cause: power up
Last software reset at 2020-10-01 16:17, reason: User, spinning module GCodes, available RAM 11516 bytes (slot 0)
Error status: 0
[ERROR] Error status: 0Free file entries: 10
MCU temperature: min 21.1, current 24.6, max 24.8
Supply voltage: min 0.8, current 1.7, max 1.7, under voltage events: 0, over voltage events: 0, power good: no
Driver 0: ok, SG min/max not available
Driver 1: ok, SG min/max not available
Driver 2: ok, SG min/max not available
Driver 3: ok, SG min/max not available
Driver 4: ok, SG min/max not available
Driver 5: ok, SG min/max not available
Driver 6: ok, SG min/max not available
Driver 7: ok, SG min/max not available
Driver 8: ok, SG min/max not available
Driver 9: ok, SG min/max not available
Cache data hit count 106636381
Slowest loop: 1.07ms; fastest: 0.05ms
Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
=== DDARing ===
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is ready with "M122" in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 15.48ms; fastest: 0.00ms
HTTP sessions: 0 of 8- WiFi -
Network state is running
WiFi firmware version 1.23
WiFi MAC address f4:cf:a2:66:94:6a
WiFi Vcc 3.43, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 26176
WiFi IP address 192.168.1.122
WiFi signal strength -41dBm, reconnections 0, sleep mode modem
- WiFi -
En connection USB je n'est plus de court-circuit
@Veti said in Court-circuit:
post a photo of your wiring between the duet and the duex -
oui je post la photo des que je rentre in my home
Plus de court-circuit problème résolu merci beaucoup 1 fil était sorti du logement de la duex5
ok. but do adhere to the wiring as described in the guide. otherwise you will encounter more strange results.
