Court-circuit
Firmware installation
732
    Veti
    post a photo of your wiring between the duet and the duex
      chris974M
      J'ai juste suivi les steps sur https://duet3d.dozuki.com/c/Getting_Started
      M122 en Français et avec la traduction
        Can you change the line ending setting in YAT so we can see the full M122 report?
          chris974M
          Comment je dois faire ? Désoler c'est la première fois que j'utilise une Duet
            chris974M
            RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later + DueX5
            Board ID: 08DLM-996RU-N8PS4-6JKD8-3S06T-KBVRN
            Used output buffers: 1 of 24 (1 max)
            Static ram: 25712
            Dynamic ram: 93528 of which 0 recycled
            Exception stack ram used: 244
            Never used ram: 11588
            Tasks: NETWORK(ready,1448) HEAT(blocked,1232) DUEX(suspended,160) MAIN(running,3816) IDLE(ready,160)
            Owned mutexes:
            Last reset 00:00:33 ago, cause: power up
            Last software reset at 2020-10-01 16:17, reason: User, spinning module GCodes, available RAM 11516 bytes (slot 0)
            Error status: 0
            [ERROR] Error status: 0
            Free file entries: 10
            MCU temperature: min 21.1, current 24.6, max 24.8
            Supply voltage: min 0.8, current 1.7, max 1.7, under voltage events: 0, over voltage events: 0, power good: no
            Driver 0: ok, SG min/max not available
            Driver 1: ok, SG min/max not available
            Driver 2: ok, SG min/max not available
            Driver 3: ok, SG min/max not available
            Driver 4: ok, SG min/max not available
            Driver 5: ok, SG min/max not available
            Driver 6: ok, SG min/max not available
            Driver 7: ok, SG min/max not available
            Driver 8: ok, SG min/max not available
            Driver 9: ok, SG min/max not available
            Cache data hit count 106636381
            Slowest loop: 1.07ms; fastest: 0.05ms
            Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
            === DDARing ===
            Segments left: 0
            Movement lock held by null
            http is idle in state(s) 0
            telnet is idle in state(s) 0
            file is idle in state(s) 0
            serial is ready with "M122" in state(s) 0
            aux is idle in state(s) 0
            daemon is idle in state(s) 0
            queue is idle in state(s) 0
            Code queue is empty.
            === Network ===
            Slowest loop: 15.48ms; fastest: 0.00ms
            HTTP sessions: 0 of 8
            • WiFi -
              Network state is running
              WiFi firmware version 1.23
              WiFi MAC address f4:cf:a2:66:94:6a
              WiFi Vcc 3.43, reset reason Turned on by main processor
              WiFi flash size 4194304, free heap 26176
              WiFi IP address 192.168.1.122
              WiFi signal strength -41dBm, reconnections 0, sleep mode modem
              chris974M
              En connection USB je n'est plus de court-circuit
                Veti
                @Veti said in Court-circuit:
                  chris974M
                  oui je post la photo des que je rentre in my home
                    chris974M
                    Plus de court-circuit problème résolu merci beaucoup 1 fil était sorti du logement de la duex5
                      Veti
                      ok. but do adhere to the wiring as described in the guide. otherwise you will encounter more strange results.
                      18 out of 18
