New Duet WiFi firmware 1.19beta1
Firmware installation
12
38
5.0k
    elmoret
    Static IP should be set it in your wireless router using the Duet Wifi's MAC address.
      In 1.19 you can set up a static IP address in the connection parameters you give in the M587 command. See https://duet3d.com/wiki/G-code#M587:_Add_WiFi_host_network_to_remembered_list.2C_or_list_remembered_networks.
        cbusillo
        Is there a beta for the Ethernet board? I am on 1.19alpha and I am unable to get mesh leveling to work. It will probe the bed and even save the height map file. It is non compensating for my bed at all during the print and M122 says "Bed compensation in use: none". This is right after running G29 or G29 S1
          pkm
          I'm not sure I want to upgrade to 1.19. The web-server works OK for me.
          Can I just upgrade DWC to 1.16?
            I think DWC 1.16 should work with firmware 1.18 but I haven't tested it.
            There will be a new 1.19beta1 tomorrow or possibly later today. However, the changes in 1.19 are mostly to do with WiFi improvements and supporting new kinematics, do Duet Ethernet and users of older Duets are probably better off staying with 1.18.1 for now.
              pkm
              I think the switching method is a bit cumbersome. Besides, I suspect that running the web-server in ESP is better for stable printing, there won't be any lags when the web-interface is updated. I vaguely remember that the printer used to freeze for a moment when I connected to duet 0.8.5.
                minim
                I had a new crash today mid print on a small item. This is not the same code as last time.
                Here is the M122 output.
                1:57:59 PMM122
                Used output buffers: 3 of 32 (6 max)
                Static ram used: 20356
                Dynamic ram used: 95740
                Recycled dynamic ram: 2688
                Stack ram used: 1296 current, 3592 maximum
                Never used ram: 8696
                Last reset 00:00:33 ago, cause: software
                Last software reset code 0x4031, HFSR 0x40000000, CFSR 0x00008200, ICSR 0x00427803, BFAR 0x8b24b30e, SP 0x2001fe3c
                Stack: 0041a35f 00435340 21000000 400c0000 00000001 2001fee8 0041a471 0042b1a0 81000000 000003f8 ffffffe9 930db660 3f8ffd08 35793c76 3e1a39ef fffffc1e 00430351 00433746
                Spinning module during software reset: Network, available RAM 3560 bytes (slot 2)
                Error status: 0
                Free file entries: 10
                SD card longest block write time: 0.0ms
                MCU temperature: min 35.0, current 37.1, max 40.5
                Supply voltage: min 24.2, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0
                Driver 0: standstill
                Driver 1: stalled standstill
                Driver 2: standstill
                Driver 3: stalled standstill
                Driver 4: standstill
                Date/time: 2017-05-25 13:57:58
                Slowest main loop (seconds): 0.013393; fastest: 0.000034
                MaxReps: 0, StepErrors: 0, MaxWait: 0ms, Underruns: 0, 0
                Probe change coordinates:
                Bed heater = 0, chamber heater = -1
                Heater 1 is on, I-accum = 0.0
                Segments left: 0
                Movement lock held by null
                http is idle in state(s) 0
                telnet is idle in state(s) 0
                file is idle in state(s) 0
                serial is idle in state(s) 0
                aux is idle in state(s) 0
                daemon is idle in state(s) 0
                queue is idle in state(s) 0
                Code queue is empty.
                Network state is running
                WiFi firmware version 1.19-beta1
                WiFi MAC address 5c:cf:7f:2b:ec:d5
                WiFi Vcc 3.09, reset reason Turned on by main processor
                WiFi flash size 4194304, free heap 40080
                WiFi IP address 10.0.1.14
                WiFi signal strength -74db
                HTTP sessions: 1 of 8
                Socket states: 2 0 0 0 0 0 0 0
                Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                And version info:
                Firmware Name: RepRapFirmware for Duet WiFi
                Firmware Electronics: Duet WiFi 1.0
                Firmware Version: 1.19beta1 (2017-05-21)
                WiFi Server Version: 1.19-beta1
                Web Interface Version: 1.16
                  @pkm:
                  The setup mechanism is a little cumbersome right now, but the switching mechanism is automatic - it connects to the strongest network it can find that you have configured it to recognise.
                  The web server on the ESP was problematic. It was based on modified Arduino code for the ESP8266, some of which was of poor quality, and in some network environments it crashed repeatedly. Ths SDK for the ESP8266 is not open source. Overall, debugging and maintaining the ESP8266 code was a nightmare. That is why we decided to simplify it by moving the HTTP server off the ESP and on to the SAM. This also means that we are using the same architecture on the Duet WiFi as on the Duet Ethernet, so there is less code to maintain overall.
                  I think you will find that these days, even on the Duet085 you can connect a new web client without the print pausing.
                    pkm
                    Thanks David.
                    By "switching" I meant switching from older firmware to 1.19. I wish it was simpler.
                    Could you make some ALL-IN-ONE firmware file to update everything at once?
                      minim
                      Had a new crash today. This time inbetween prints so no ruined print. I had the printer printing for 2hours or so and then it was resting on for 3-4hours. When I came back and accessed the web interface it heard the fan spin up like it does when it boots and I got ajax error. This happened a few times and it was not possible to access the printer before I cycled power to it then it let me connect. Here is the M122 output. Looks like the software reset code is different this time so I'm posting it again.
                      [[language]]
                      Used output buffers: 3 of 32 (5 max)
                      Dynamic ram used: 95764
                      Recycled dynamic ram: 2664
                      Stack ram used: 1296 current, 5872 maximum
                      Never used ram: 6416
                      Last reset 00:02:14 ago, cause: software
                      Last software reset code 0x5001, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0440f80f, BFAR 0xe000ed38, SP 0xffffffff
                      Spinning module during software reset: Network, available RAM 8696 bytes (slot 0)
                      Error status: 0
                      SD card longest block write time: 170.1ms
                      MCU temperature: min 32.3, current 35.5, max 38.4
                      Supply voltage: min 23.7, current 23.8, max 24.6, under voltage events: 0, over voltage events: 0
                      Driver 0: stalled standstill
                      Driver 2: stalled standstill
                      Driver 3: standstill
                      Date/time: 2017-05-27 16:41:01
                      Slowest main loop (seconds): 0.171326; fastest: 0.000034
                      MaxReps: 2, StepErrors: 0, MaxWait: 20932ms, Underruns: 0, 0
                      Scheduled moves: 8, completed moves: 8
                      Heater 0 is on, I-accum = 0.0
                      Segments left: 0
                      WiFi flash size 4194304, free heap 40056
                      WiFi signal strength -71db
                        jgrouse
                        I updated to 1.19beta1 (2017-05-21) FW and Wifi server with 1.16 web interface today and I'm starting to find that the Duet Wifi board is now randomly resetting itself. The first time was in the middle of a small print and then not long after trying to start it again. It would be an incredible coincidence if my PSU is starting to pack it in directly after updating the FW?
                        I've always found that the 12V fans dip in speed as soon as either/both the heat bead/hot end are heating but that has never caused the board to reset in the past. The PSU is from a PC and is rated at 700W.
                        Just trying the small print job again to see if it can make it through without a reset….
                        Unfortunately, it reset mid job again. More of a crash considering I cannot get a wifi connection after that point and pressing the reset button fails to get the wifi back. I have to completely power down the PSU via the mains switch to get it working again. My biggest concern is that the 12V supply shuts off as well when it crashes which leaves the E3D heatsink without a fan and a hot end sitting at 240 deg. So I have to move quickly before the new Aero heatsink gets too hot for the plastic parts touching it.
                        Going to roll back to 1.18 now to see if the crash is unrelated to the PSU...
                          Firmware 1.19beta1 is now superseded by 1.19beta2. Those of you who were having problems with beta1 please try beta2.
                          36 out of 38
