BLTouch not responding properly Duet 2 Wifi
The wires seem fine... Could it have something to do with the BLTouch 3.3v logic bridge (as shown here)
In the video he says to test it with a multimeter? Here I'm guessing you test the continuity? And it's suppose so show 0? On my multimeter it doesn't shows that there is continuity, and I'm sure the bridge is gone... -
if you have the version 1.04 you do not need to cut the line anymore
what version bltouch is it?
with the bltouch you will not see 1000 because it just triggers it for a split second.
m115 FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.0 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-01-03b3
I believe the BLTouch is SMART v.1.0
The previous owner sold it with the BLTouch now working. He said it was a firmware issue on the original board.
I got a spare BLTouch with the deal, and both are returning the same error.
@TokeDK said in BLTouch not responding properly Duet 2 Wifi:
please update to 3.1.1 and try again
Now my endstops are not working... I tried to rebuild the config from the configurator with no succes.
First I got the error "failed to enable endstops", then I changed my config to:
; Endstops M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop M574 Z2 S2 ; configure Z-probe endstop for high end on Z
Now when it's homing the endstops doesn't work, so the stepper motors keep going...
TeVo Little Monster
thats a delta. you have 3 endstops for each tower
try
M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop -
@Veti said in BLTouch not responding properly Duet 2 Wifi:
M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstopPerfect! Now endstops are working. Although Z probe is still giving the same error:
Error: Z probe was not triggered during probing move
post a picture of your wiring
you really should recrimp your cables.
can you try without extension cables? like this
https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/KUDxTZSs3rnd3JVH.standard
Awesome, I set it up like you suggested and it works! So it is faulty wiring/connections. I will report back with my findings.
@TokeDK
i suggest you get a crimping tool (i use engineer pa09). that way you can crimp the cables with the connectors supplied with the duet. (if you got them) -
I suggest you get the proper connector parts for the Duet board and redo the wiring as needed.
This is the tool I use for crimping the them:
